Old 08-08-2017, 04:57 PM   #3347
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by Racecomp Engineering View Post
The T0 are plenty firm enough for most and are a good match for Michelin PSS. Adjustment is nice to have, but not a must have IMO if the basic valving is good. In terms of performance the T2s would be at the top, and I'd put the T0 and Greddys above the Teins. The Teins are just valved quite soft.
FYI the Greddy coilovers use the same galvanized finish as the ST coilovers and not the inox stainless like RCE and KW. I think you know that but just pointing it out.
- Andrew
Have you guys had experience with the Greddy x KW? Just not a lot out there but they seem like a decent choice for a DD/canyon car that sees the track a few times a year.
Old 08-08-2017, 05:12 PM   #3348
No first hand experience. Dyno plots look okay. I would be concerned about not having the KW stainless finish though, at least where I live.
- Andrew
Old 08-10-2017, 11:19 PM   #3349
Benzin
Benzin's Avatar
My stock suspension is toast due to a crash, so I'm looking for a smoother street ride. I have about 69,000 miles on the stock suspension and it is STIFF and ROUGH. Also looking to lower the car, but not too much. I'm not gonna go lower than 2 inches, and may get enkei rpf1's in the future. I drive the car HARD everyday.
What would you recommend for $1,600 and under for the smoothest ride?
Benzin is offline   Reply With Quote
Old 08-11-2017, 02:20 AM   #3350
churchx
churchx's Avatar
Drives: 2014 GT86
2 inches IS lowering much for ours, already rather low cars. Enough to need lot of other parts to fix problems with geometry, eg. roll center adjustment, or longetivity, eg. diff risers for bearings to not fail sooner. It will add up to costs, most probably past your stated budget or you'll need cut budget on coilovers. Also it will make hard to increase DD comfort, if you reduce shock travel that much, especially at that price level. After all, common thing to do with decreasing shock travel is to accompany with stiffer springs, to not bottom out all the time. And unless one still drives within legal limits, driving HARD is possible only on track.
Old 08-11-2017, 02:28 AM   #3351
Benzin
Benzin's Avatar
Originally Posted by churchx View Post
2 inches IS lowering much for ours, already rather low cars. Enough to need lot of other parts to fix problems with geometry or axle angle it causes. It will add up to costs, most probably past your stated budget or you'll need cut budget on coilovers. Also it will make hard to increase DD comfort, if you reduce shock travel that much, especially at that price level. And unless one still drives within legal limits, driving HARD is possible only on track.
Sorry, you misunderstood, I meant to say I don't want to go lower than 2 inches. Main thing for me is DD comfort and to reduce "skipping" when I'm driving hard in the canyons from the suspension being too stiff for the shitty roads. I'm fine with stock height, but would lower only for aesthetic purposes (get a lot of dat wheel gap comments).
Old 08-11-2017, 04:48 AM   #3352
churchx
churchx's Avatar
Drives: 2014 GT86
Benzin: better keep lowering within 1 inch, if you don't want extra spendings or go for compromises to comfort. Our cars are rather low and have rather short dampers travel even stock. And lowering >1" brings in unwished changes that are needed to fix.
Old 08-11-2017, 01:09 PM   #3353
Benzin
Benzin's Avatar
What LCA and coilovers combo would you suggest to be the best for DD comfort?
Sent from my Nexus 6P using Tapatalk
Old 08-11-2017, 01:30 PM   #3354
Pat
Pat's Avatar
Drives: 2023 BRZ
If you're going for comfort you don't want to be too low. If you don't want to be too low you don't need aftermarket lower control arms.
Old 08-11-2017, 01:40 PM   #3355
Benzin
Benzin's Avatar
I understand that. Maybe I'll go 0.5-1 lower in the future. My front passenger LCA is bent from crashing into a boulder. (Hit a coyote, and went into a canyon wall) They would have to be replaced anyways. Question is OEM or aftermarket.
Old 08-11-2017, 01:47 PM   #3356
DarkSideFRS
Drives: 2013 pearl white FR-S
A set of SPC 14mm camber bolts for the bottom hole on the lower strut mount. Move the OEM bottom bolt to the top.
- Andrew
i did this along with SPC LCAs to go with my TRD springs. What alignment specs do you recommend for stability? i was thinking -1.5F and -1.3R camber and 1/32 toe in all around
DarkSideFRS is offline   Reply With Quote
Old 08-11-2017, 09:54 PM   #3357
churchx
churchx's Avatar
Drives: 2014 GT86
Pat: but having adjustable LCAs 1) adds adjustment range to not just dial it to somewhat passing numbers in stock overly broad ranges, but allows to get them dialed in precise/even. There is limit to "range" how much can be adjusted with just slacking all bolts, bending/pushing parts, retorqueing them back. 2) makes alignment job much quicker & easier (=if shop does it & is paid by hours, also much cheaper).
And if one later in future changes thoughts on wished alignment (for eg. track purpose) or for different lowering, LCAs will need to be bought anyway. So why not do it Right [tm] and get LCAs from very beginning? Cheapest ones like SPC/Eibach/Whiteline are not really THAT expensive.
Old 08-12-2017, 10:04 AM   #3358
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Originally Posted by Benzin View Post
Main thing for me is DD comfort and to reduce "skipping" when I'm driving hard in the canyons from the suspension being too stiff for the shitty roads..
I get the skipping on my crappy mountain roads too. Basically I'm loosing traction on the rough patches when the rough happens on a curve. So outside of dropping speed, what's the solution? Softer springs? Lower tire pressures at the expense of wear?
Pointmutation is offline   Reply With Quote
Old 08-12-2017, 09:54 PM   #3359
Christianb
Drives: noneyet:(
Hi guys,
Searched this thread for a good DD, canyon car, and track car. Frequency of canyon driving would be every other week and track driving would be every other month or so. My workplace is only 2 miles from my house, and my school is another mile from my work, so my daily drive is not far. The conclusion I have came up with is the following setup. I am just looking for feedback regarding tire wear, comfortability, etc . Coilovers are Fortune Auto 500 Series V5 and I have SPC LCAs in the rear. Im currently running the stock Primacy's, but have some 225/45/17 Goodyear Eagles waiting to be installed and I get a pretty good deal on Federal 595RSRR's if those arent enough grip.
Front Alignment Specs:
Height- -1.2 in
Camber-~3*
Toe- 0
Damper: Soft to mild
Rear Alignment Specs:
Height- -1.0 in
Camber ~2*
Toe: 1/16
Damper:Mild to hard
Thanks!
Christianb is offline   Reply With Quote
Old 08-12-2017, 10:16 PM   #3360
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by Christianb View Post
Hi guys,
Height- -1.2 in
Camber-~3*
Toe- 0
Height- -1.0 in
Camber ~2*
Toe: 1/16
Damper:Mild to hard
Thanks!
Spring rates? Stock swaybars?
Alignment looks generally good for good grip while turning, etc - it's where I'd recommend people start for a performance oriented setup. What do you want the car to do differently?
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
