Old 06-10-2012, 10:55 PM   #3347
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by Allch Chcar View Post
I had to look that up because I know the first gen Insight didn't have ultra capacitors. It looks like they used it on the J-VX concept after a quick google search.
Must be senility setting in. I have this solid but apparently incorrect memory of Honda putting ultracapcitors in the Insight, and that was part of keeping it light.
Stupid brain
Because titanium.
Dimman is offline
Old 06-10-2012, 11:46 PM   #3348
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Originally Posted by blur View Post
Anyone know of a guide to properly setting up track suspension?
What's your driving skill level and experience, and what are you planning on doing with the car?
old greg is offline
Old 06-11-2012, 12:25 AM   #3349
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Friends and family threw me a surprise graduation party today. I was genuinely surprised too! Had quite a good time!
- The Ancient BRZ Sacrament
by Zaku
Guff is offline
Old 06-11-2012, 01:33 AM   #3350
serialk11r
Drives: '06 AM V8V Coupe
Yea that's what I thought, no one has used ultracapacitors yet, Li FePO has only recently become standard, and they're talking about ultracapacitors only recently.
I'm starting to wonder what can be done to the stock 1ZZ motor in the MR-S...afterall, it's got the same displacement as the 2ZZ, and the rod stroke ratio is a healthy ~1.6. I'd imagine that no one gives a crap about that motor though, so upgraded parts would be hard to get :/ Maybe force feeding it to ~200Nm should do the trick?
serialk11r is offline
Old 06-11-2012, 01:54 AM   #3351
Dimman
Kuruma Otaku
Dimman's Avatar
I believe TRD made a SC for it. But my memory's not having a good run today...
Because titanium.
Dimman is offline
Old 06-11-2012, 03:34 AM   #3352
serialk11r
I think they did, but I wonder if a SC is DIYable...buying the compressor and shit is pretty cheap, and maybe I'm wrong but I think machining chunks of aluminum to make brackets and stuff isn't too hard?
At any rate, that 6900rpm rev limit on the 1ZZ is unacceptable and needs to go up :P I imagine new rods would really hurt the wallet though :/
Say, how hard is it to rebuild an engine anyways? I saw someone doing it in a Youtube video sped up, in their garage...
Old 06-11-2012, 08:54 AM   #3353
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
Little to none, going to AUTOx this weekend, HPDE after that, then time attack. I'm just trying to find out what kind of spring rates and sways my car will feel neutral on. Right now I'm fighting understeer... and the only solution I know of is a bigger rear swaybar. Front is 26mm, Rear is 17m... my weight distribution is roughly 60/40.
I wish I was cool enough to have an FR-S
blur is offline
Old 06-11-2012, 01:11 PM   #3354
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Do you think, having a massive sore is a good excuse not go to work?
prob not LMAO
ichitaka05 is offline
Old 06-11-2012, 01:33 PM   #3355
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Little to none... Right now I'm fighting understeer... and the only solution I know of is a bigger rear swaybar.
Leave it more or less stock for the time being, but upgrade the brake pads, lines and fluids before you go to the track. If you feel a burning desire to throw money at your suspension right now, get an adjustable rear sway bar.
The important thing is going to be getting enough experience to be able to reliably troubleshoot your setup. First and foremost you need to know where you're understeering; Corner entrance, a quarter of the way in, mid corner, a quarter of the way out or corner exit, and on what types of corner; hairpins, sweepers, decreasing radius, increasing radius, etc. All of which are going to have different solutions which will need to be considered in conjunction with the way the car is behaving on the rest of the track; Is it stable under braking? Through that high speed chicane? etc. Everything effects everything else and no one setup will be perfect on every part of a track, much less every part of every track.
Anyway, step one is go out there and drive the damned thing.
old greg is offline
Old 06-11-2012, 01:45 PM   #3356
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
Typical response for some asking help with suspension tuning. It understeers EVERYWHERE. A 20mm swaybar should have been a factory accessory. You must understand, I know how the car feels and that's why I am concerned about tracking it. The only burning desire I have is not wasting money on a 20mm when I really need a 24mm. Like I said before, I am looking for a neutral setup, not a perfect setup.
I know that driving the car around a track isn't magically going to help me understand what spring rates my car needs either. I dont know why anyone without track experience asking for help with suspension always gets shot down. Do you have any track experience with a FWD double wishbone?
btw; brakes are being done this weekend. I'm well aware of their limitations.
blur is offline
Old 06-11-2012, 02:46 PM   #3357
ichitaka05
Site Moderator
ichitaka05's Avatar
Hm... some local guy is selling RWD GF8... VERY tempting
Old 06-11-2012, 02:48 PM   #3358
M-17
Ninja Cat Mod
M-17's Avatar
So much hype this past weekend leaving so much disappointment to all.
M-17 is offline
Old 06-11-2012, 02:49 PM   #3359
Dimman
Kuruma Otaku
Dimman's Avatar
It's not, if you know what you're doing. The difficulty from a DIY perspective is access to a mill and/or lathe plus all the tooling. If you have a LOT of time, patience and attention to detail, you can substitute a drill press, bandsaw and files for a mill. But after one time, you'll never want to do it again...
This has been a source of endless frustration for me over the past 3 years.
Because titanium.
Dimman is offline
Old 06-11-2012, 02:59 PM   #3360
Trolling through Netflix last night looking for a comedian to watch. Ran across Sinbad's Afros and Bellbottoms" special from HBO circa 1993. My 15 year old was literally ROFL from it.
Some of it was a bit dated (references to Rodney King) but I had forgotten how funny Sinbad could be. Reminded me of a more "hip" Bill Cosby, hillarious and relatively family friendly.
Very bad VHS-DVD transfer (even the credits had the VHS stutter thing going) but worth a revisit. Be patient through the opening vignette though, it was pretty lame. Once the actual standup part starts its much better.
Dadhawk is offline
