#323 | |
Drives: WRB BRZ
If header was already catless then it's likely ok it may make turbo spool a little different and possibly hit boost limiter but unlikely just log data and check but should be fine |
#324 | |
Drives: Yes
It was actually the stock catted header before, and now it's an aftermarket UEL catted header. Definitely spools differently and the gains have shifted toward the higher RPM end. Amazing on E85, and 91 feels like shiite by comparison (which is expected). Just wondering if there would be any benefit to re-tuning specifically at 91 but my tuner said as long as they adjusted the tune on E85, the rest scales automatically based on ethanol content level.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#325 | |
Drives: WRB BRZ
Yes unlikely anything with fueling will change tune will still target same afr and timeing dependant on load and boost The catless header will generally increase spool and in some cases could create a possible boost increase or overboost situation. Deliceous tunes will have an overboost safety if that's not tripping it should be fine but the only real way to tell would be to log ECU data check for any knock and confirm afr is ok.The E85 flex kit will work as normal |
#326 | |
PhoneFlash by EcuTeK
This will resolve a few things. 1. Should work on all Android OS 10.0 and up. 2. Fuel pressure will show the correct value again. 3. More stable bluetooth connection over time. Cheers, William |
#327 |
If my bluetooth reads the correct ethanol percentage but the ecu no longer sees a change at the O2 sensor plug, what might be the issues? No tuning changes have happened, the signal just dropped out one day.
#328 |
Drives: 2015 FR-S
Check the connection between Delicious box and O2 connector? that's how your ECU reads it. Could be lose connection/solder connection inside the box or bad connector
#329 |
Tried cleaning the connection, reconnecting all connectors. Ended up ordering a 2nd one just to rule everything out. It went out mid drive.
#330 | |
Drives: 2017 Toyota 86
#331 |
Anyone know how the v3 CAN bus kit installs in the gen 1 cars? The DT website shows how the gen 2 install goes, but not gen 1.
#332 | |
We have a couple options for the Gen 1 BRZ/FRS/86 Flex Fuel Kits: 1. The V3 CAN Bus integration which will require the latest EcuTek RaceROM patches. That can be found here: V3 CAN Flex Fuel 2. Classic / Universal integration for those looking to solely replace their kits, with no need for a tune as the older tune with rear O2 input worked fine for their needs. That can be found here: Classic/Universal Flex Fuel Kit Please note that the V3 Kit will support BOTH CAN and Rear O2 input, the only difference being the harness. So if you are looking for a replacement and not quite ready to upgrade to CAN integration this is a great way to do it. Cheers, William Knose |
| Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps | DeliciousTuning | Software Tuning | 1213 | 06-17-2025 04:02 PM |
| 200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) | DeliciousTuning | Software Tuning | 156 | 07-01-2014 08:37 PM |
| Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU | DeliciousTuning | Software Tuning | 19 | 12-07-2013 12:01 PM |
| Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-19-2013 05:58 PM |
| Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-13-2013 01:34 AM |
