#323 | |
#324 | |
So, according to your data, the coolant temps are kept in check moreso by the fans than by air flowing through the front grill.
I suspect this is the case. If the fans turn on, coolant temps are kept in check. On a front mount turbo setup, I think the fans should turn on VERY early, or simply run ALL the time, because if the fans are off during times of boost, then the radiant heat from the hot parts will melt, or at least overly bake anything around them. With the fans on the radiant heat will be blown away from the fans and radiator. For track duty though, it is much more important to address the air exchange in the engine bay as well. This is where the skidplate, vented hood, fender vents, all come into play. For street use, I agree, probably most would not need to go to any extra lengths for cooling other than having the fans coming on early. More importantly for tracking is dealing with oil temps. Looking at data posted it seems coolant temps stay in check while oil temps steadily rise without an oil cooler. Quote:
#325 | |
Drives: 2022 BRZ Limited
#326 | |
#327 |
Interesting, I wonder where you guys have been reading from? what software/device did you guys use to log?
#328 |
There are two ECT tables for the radiator fan control in the stock map, along with a fan control table based on speed. I'm not sure where the two maps come into play but the lowest value in any map is 92c which is 197F. 100 is the highest value in one of the maps so my guess is it might be the temp the fans turn on full speed which is 212F.
| The Following User Says Thank You to xwd For This Useful Post: | glamcem (05-27-2014) |
#329 |
Drives: 2013 Black FR-S
#330 |
#331 |
Drives: 2013 Whiteout FR-S
Getting a lot of Lift Off Oversteer lately, any tips? Current setup is Front Sway (22mm) with KW Club Sports on Soft Setting and Z2's 255 Setup All Around. I did try disconnecting the rear sway and that did help a little. Do I just need to learn how to counter more confidently?
#332 | |
#333 |
It starts to under steer I suppose, here is a good example of what is happening
[ame="https://www.youtube.com/watch?v=ghxIto6sZt4&feature=player_detailpage#t=26 4"]GRIPFEST NCCAR Turbo FRS (May 2014) - YouTube[/ame]
#334 | |
Your steering wheels control the front tires, the gas pedal controls the rear tires. If you're coasting through a corner, you're only controlling half of your car. You got power oversteer there, after understeering from coasting through the corner. Balance the car with the throttle. Your suspension setup may or may not be prone to understeer period, while you just simply overpower the rear tires with sheer power, causing the oversteer. I can't diagnose without more information
| The Following User Says Thank You to CSG Mike For This Useful Post: | kanundrum (05-27-2014) |
#335 | |
Drives: Toyota 86
#336 | |
Drives: Toyota 86
@bli1tzkr1eg has an aftermarket grille which has a bigger opening which could explain the lower coolant temp. We have the same setup, Vortech SC, Koyorad and 6MT |
| going forced induction | ft86me | Forced Induction | 14 | 02-05-2014 09:23 AM |
| So who is running Forced Induction and tracking their car? | track_warrior | Tracking / Autocross / HPDE / Drifting | 88 | 08-20-2013 11:00 PM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 04:42 PM |
| NOS or Forced Induction? | v3rgil | AFRICA | 1 | 11-08-2012 08:17 AM |
| Forced Induction | Primo86 | Engine, Exhaust, Transmission | 11 | 05-29-2012 08:50 PM |
