Old 01-02-2014, 10:21 AM   #323
Originally Posted by balance View Post
Mike, Thank you for doing this for the community.
I have 3 questions:
1) Is there any bushing upgrade that you suggest for heavy duty track use?
2) For the NA power-level, what would be your choice of the tire width?
3) Would aero mods (especially, the rear wing) provide any substantial benefits to the NA car?
Cheers,
Sam
1) not yet, but only because we haven't tried any. The gains from spherical bushings are generally not worth the price, unless you're in a highly competitive class and/or a full race car
2) generally 225/40/17, but this depends on the specific track. A really tight track with little or no straights will benefit from a larger tire that can carry more speed in turns. The smaller tire is to preserve what little acceleration we have
3) absolutely, even if you never see speeds over 80 at the track. Just as with the car itself, suspension, and tires, make sure you balance out the aero, or you'll end up with an ill-handling car.
Old 01-05-2014, 06:30 PM   #324
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Cool, got one of my questions answered above so now my question is simply regarding a specific tire. I am looking at doing my first track day or two this year and DD my car. I drive a lot and need a very comprimising tire in regards to longevity. I plan on getting the Firehawk Indy Wide Ovals which are a high performance summer tire and have a tread rating of 320. Do I run any risk a tire like this not holdibg up well to track use (ie chunking or somethung that would make them unusable besides just tread wear)?
Old 01-05-2014, 06:53 PM   #325
Run your stock tires.
I have no idea what tires those are, but chunking is a result of bad alignment and badly overheating 1 section of the tire.
Old 01-05-2014, 07:00 PM   #326
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Track related mods currently installed
Apr splitter
Driveway labs diffusor
Mishimoto oil cooler.
Currently having tons of fun at HPDE but I will be looking into track rims/tires and the ap BBK upfront you referred me to.
The stock wheel gap is bothering me though and I have a new in the box set of eibach sport lines. Are there any shocks ud recommend pairing with them to keep me aggressive on the track? I've herd mixed reviews on lowering springs with stock struts. Also what form of camber adj do u recommend? Whiteline camber bolts front/rear?
FRSfan111 is offline   Reply With Quote
Old 01-05-2014, 07:55 PM   #327
finch1750
finch1750's Avatar
Stock tires are below the wear bars and getting replaced some time this week, which is why I am looking at new tires. i had just remebered something about heat and chunking and didnt know if it was related to an individual tire, but an alignment is definitely going to happen first for sure.
Old 01-05-2014, 08:04 PM   #328
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Brand new FRS/BRZ out of the dealership, you only have $1000 to spend for the first season, what are you mods for the track and autocross?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 01-06-2014, 01:12 AM   #329
Camber bolts, and entry fees.
If it's $1000 for mods...
Camber bolts, race pads (2 sets front, 1 set rear, cuz fronts go faster), brake fluid.
I need you to be more specific with your question, as I'm not exactly sure what you're asking and what I'm allowed to spend it on.
If consumables and entry fees are not counted, then:
Camber Bolts, set of RPF1.
Old 01-06-2014, 01:14 AM   #330
Don't cheap out on tires. They're the only part of your car that touches the ground and the tires you're thinking of are HUGE downgrade from stock.
Old 01-06-2014, 01:16 AM   #331
Apr splitter
Camber bolts only work in the front. At this point, I'd urge you to consider coilovers. You need to ask yourself, what is more important? Looks or performance? You can get both, but you'll need to spend the $$$.
Sell the diffuser (it's probably non-functional, except in the looks dept), and get some quality coilovers.
Old 01-06-2014, 02:21 AM   #332
finch1750
finch1750's Avatar
So you would recommend just getting another set of primacy hps?
Old 01-06-2014, 02:33 AM   #333
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
I know many of you take the driving element very seriously, but this car is the first one I think that'll actually allow me to really experience what a sports car is all about. That being said, I'm probably not going to set any lap records (unless it's for slowest) - but I want to ask if it was wise to:
* upgrade to 18" wheels (say, Enkei RPF1's in 8" width)
* Find a tire that I can take to the track maybe once a month or even less
leicaboss is offline   Reply With Quote
Old 01-06-2014, 02:42 AM   #334
FRSfan111
18s are just for looks. Bigger rim = more to rotate = slower car.
Honestly wont be a huge disadvantage but it won't help either. Enkies 17x8s would be better. Stock tires are better then you would think/people give th credit for. If u want a dedicated rim/tire set up, you have plenty of options. Hoosiers would be gluing ur car to the road.
Old 01-06-2014, 04:30 AM   #335
leicaboss
Coffee Snob
leicaboss's Avatar
Hey thanks for the reply - I think 17's might do the trick - they certainly look better than stock
I don't want to change the dynamics of the car too much by pushing the wheels out though, any advice?
Old 01-06-2014, 06:28 AM   #336
bukit
Drives: 2013 Subaru BRZ, 2011 VW Golf TDI
Running stock tires with race pads on the track can be problematic. I did it this past weekend with Carbotech XP10s. The increased braking overwhelmed the tires so modulation was key.
bukit is offline   Reply With Quote
