#323 | |
I've done something in your mapping to help prevent explosion if the load get too high... Since then you asked me about it but never got one? |
#324 | |
Drives: Perrin/VORTECH Supercharger TestBRZ
any ecutek tune can have this, I havent overtly checked with Perrin on what he has me running at the track, but overboost just isnt a concern in my setup with a SC |
#325 | |
![]() I was saying I think John is the only one who utilizes it, not that he's the only one who can. |
| The Following 2 Users Say Thank You to 2forme For This Useful Post: | Huehuecoyotl (04-10-2013), Sportsguy83 (04-10-2013) |
#326 |
I Love custom Turbo kits
Drives: Limited BRZ
Yeah, its either the MBC is installed backwards or the Actuator is shut down too tight.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Huehuecoyotl (04-10-2013) |
#327 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | Visconti (04-10-2013) |
#328 |
Drives: 2013 Black FR-S
Connect a pump (even a bicycle pump with a gauge) and apply pressure to the wastegate nipple. Observe the wastegate actuator arm. Make sure it is opening at the correct psi. If that works then the problem might be the boost controller or the vac line going to the gate.
| The Following User Says Thank You to sw20kosh For This Useful Post: | Sportsguy83 (04-10-2013) |
#329 | |
Drives: Limited BRZ
#330 | |
That Guy
Drives: 2013 asphalt FRS MT
#331 |
I have had nightmarish problems with internal wastegates. I once had an internally gated turbo where the flapper door was not able to open more than 30% because of machining tolerances being off......... Boost spiked up to 24 psi when we first boosted on the dyno. Luckily it was a 9:1 CR motor lol.
| The Following User Says Thank You to sw20kosh For This Useful Post: | Calum (04-10-2013) |
#332 |
Boostin'
Drives: FRS-T
@Visconti
Hi John! i am finally ready to order my tune. ive been driving my car around for a couple of days with the wastegate open to make sure that everything was good and working properly with no oil or coolant leaks. A friend of mine has an ecutek cable so i wont need one for now. I tested my wastegate actuator on the bench and it starts to open at 7.5psi and is fully open at 8psi. i also have a 4 bar map sensor. I always run on 91octane but if i need to run 94 i can get access to it as well. I am using stock injectors for now... i believe that 8 psi was the limit for these but correct me if i am wrong. i also have no catalytic converter between my 2 o2 sensors so i dont know if you can do something about it... i currently have a cel because of that. i would also like to have launchcontrol if possible! please hit me up soon with all the info that you need and where to send you the funds! i would like to chip the car this comming saturday!! sincerely, Max
#333 |
Drives: Limited BRZ
Sounds awesome! I think the best way to get in contact with him is either PM here, or submit a support ticket. Hopefully you hear from him soon!
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Silverdub (04-14-2013) |
#334 |
Drives: Pile of junk
he will more than likely have you do a support ticket or call him
| The Following User Says Thank You to Frs300 For This Useful Post: | Silverdub (04-14-2013) |
#335 |
Boostin'
Drives: FRS-T
Support ticket?
#336 |
Boostin'
Drives: FRS-T
Yeah in his sig got it
| The Following User Says Thank You to Silverdub For This Useful Post: | Sportsguy83 (04-14-2013) |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 11:18 PM |
| Visconti Tuning - Who wants to run on e85? or 100 Octane | Visconti | Engine, Exhaust, Transmission | 174 | 05-21-2013 04:00 PM |
| VISCONTI TUNING WILL BE IN PHX JAN 18-20 WHO'S READY | Visconti | Southwest | 9 | 01-06-2013 02:40 AM |
| Visconti Tuning Stage 1 Tester #3 (I think) | ruskymx | Engine, Exhaust, Transmission | 46 | 09-15-2012 05:29 AM |
| Visconti Tuning NA STG1 Group Buy | Visconti | Groupbuys | 683 | 08-24-2012 12:28 PM |
