Old 11-08-2021, 02:24 AM   #323
brkdncr
Drives: 2017 86
I bought some 16” wheels off a 2006 outback and they came with 225x60 16” tires. Will these fit? I also have a 1” spacer lift kit to install.
brkdncr is offline   Reply With Quote
Old 11-08-2021, 02:00 PM   #324
Inferno5
Drives: 2019 TRD GT SE
Hey Sasquatchulator; I came up with this using the calculator you posted, before I order I just wanted to run by some of you much more experienced 86 owners to see if these will work? I'm learning a lot from you guys...so glad I found this forum!
https://www.tirerack.com/cart/HoldingArea.jsp
Inferno5 is offline   Reply With Quote
Old 11-09-2021, 06:43 PM   #325
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by Veypor View Post
I switched from a 17" OEM wheel Michelin X-Ice set up to a proper 15" Pirelli Ice Zero studded setup and never looked back.
Link to wheel directory post
+1
THIS is going to be my next winter setup after my current studded 16s are worn out. I assumed 15s wouldn't clear our brakes..
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 12-15-2021, 12:36 PM   #326
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
just mounted some new Hakka R3 215/45/17 on my OEM wheels
can't wait for first snowfall!!
RickyRacer is offline   Reply With Quote
Old 01-02-2022, 01:36 PM   #327
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
We finally got our first real snow here in the Denver area yesterday, so I was able to try out my Vredstein Wintrac Pros for the first time.
There was a nice icy layer at the bottom, so I was able to have some fun.
Overall I have to say that so far I am happy with them. Although if I wasn't permanently working from home and still had a daily commute I probably would have opted for something like Blizzaks instead.
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Old 01-02-2022, 02:50 PM   #328
brkdncr
Drives: 2017 86
Originally Posted by venturaII View Post
+1
I think that car has different brakes on it? AR-Racing and RR-racing BBK are brakes.
Old 01-03-2022, 05:46 PM   #329
Sasquachulator
Pavement Grey
been driving on the iceguards for a few months now.
My feeling is still the same with these tires.
they seem meh, not great on slippery/icey roads, but it feels like they've got some bite in the snow when i do get a chance to be on the packed snow.
Tirerack ratings for these seem to indicate they're quite good but not great. I feel like they're not as good as the ratings indicate though.
I also think some of it is getting used to a 50/50 weight balanced RWD car vs usually driving a FWD econobox with with a 60/40 F/R weight split. (drive wheels feel a bit lighter with less weight over them).
So far they do the job mostly fine. I wasnt wowed by these tires like i was when i first experienced the Continental DWS in the snow.
Old 01-03-2022, 08:25 PM   #330
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Just wanted to let people know if you didn't already that they make what are called "all weather" tires now. Not so much for your BRZ etc, but for your wife's car where you get snow from NOV-March but don't want to mount/dismount snow tires and rims.
I just ordered up a set of Michelin ClimateCross 2 for my Mazda 6. Expensive but by far the best reviews out there. Found out I have blackmarket tires on my car...IE: super old yet brand new tread. So I feel the rubber is super hard now and they are just General tires. In MN here I can stop worth a shit or start. I have a 6spd by the way.
Swift is offline   Reply With Quote
Old 04-17-2022, 01:17 AM   #331
matchaFRS
Drives: 2014 Scion FRS
Gislaved Nord Frost 100
205/55/16 on 2003 forester oem wheels.
Drove these nearly everyday during in Winnipeg, MB where winters are known to be terrible. Plenty of grip when you want it. Plenty of slide when you want it. These tires are studdable but I did not have them studded. Never really got stuck in deep snow.
These tires I know are on the cheaper side but worked great for me. (the worst winter tire is better than nothing). This was my first ever RWD winter experience.
matchaFRS is offline   Reply With Quote
Old 09-27-2022, 10:54 AM   #332
Pat
Pat's Avatar
Drives: 2023 BRZ
Does anyone have any information on 2023 snow tires? I'm in the market for some and wonder if there is any new tech in the world of snow tires I should aware of.
Old 10-02-2022, 06:21 PM   #333
jbug187
Drives: 2022 Subaru BRZ Limited MT
Hi guys. I live in the New York City area and need some advice about getting winter tires that I can use on the stock wheels of my 2022 BRZ from November to March. The streets I drive on get plowed pretty well and I only anticipate driving on snow / ice a few times per season at most. After looking through some forum posts I see that folks generally recommend staying away from 'all season' tires and going with a full on 'winter tire', but I'm not sure if they might live in areas with harsher winters. Should I be looking at winter tires like Blizzak or Michelin X-Ice? I can only find them in a 225/40R/18 size - and am not sure if they would be too wide for the stock wheels since the stock tires are 215/40R/18? Any advice is appreciated. Thanks.
jbug187 is offline   Reply With Quote
Old 10-03-2022, 04:49 AM   #334
churchx
churchx's Avatar
Drives: 2014 GT86
If, where you live, there is rarely any snow/ice and temps most of a time are non-freezing, even more so, with very few expected drives, then all seasons might be better choice. Then again, some (me included) prefer to "err on safe side", i'm willing to give up some grip where it's plentiful (like ice/snow-less clean tarmac roads) for sake of any extra grip available, when it's scarce, as i may push less on clean roads, but never be stuck in those rare times when they were not yet after heavy snowfall.
You should know better, what average temps and road state in winter, where you live, are, and if you do (don't do) driving from time to time to more nothern-ish states (for eg. skiing resort and/or visit friends or old folks). From your description/post it seems that all seasons might be better .. i'd get good/premium vendor ones though (conti/goodyear/michelin).
Very weird to hear sizing (non)availability for you of winter tires (which usually are available at even smaller and narrower widths then summer tires). For example i'm running studded X-Ice North 4 195/60r16. Only 18? Hard to believe.
Old 10-03-2022, 10:05 AM   #335
bucketfoot
bucketfoot's Avatar
I would definitely go with a winter tire, but I would stick with the stock size or even go down in width a size. I would not go up in size on a winter tire. A narrower tire will cut through the snow much better.
While I am a huge fan of both Blizzaks and Michelin, if you are going to do limited driving I would look for a less expensive tire. Bottom line is that the cheapest winter tire will be far better than even the best all-season tire in the cold/ice/snow.
Old 10-03-2022, 02:08 PM   #336
bucketfoot
bucketfoot's Avatar
Pat I don't think there is anything new on the technology front, as I suspect the next gen of many tire designs was delayed by COVID.
My two cents would be if snow/ice performance is the top priority it is hard to beat the Blizzak, X-Ice or Nokian.
When I went through this a year ago I wanted the best for a "sports car". The best of these do not come in sizes for our cars, so for me the top two options ended up being the Vredestein Wintrac Pro and the Pirelli Sottozero 3 (which I had on my BMW). I ended up with the Vredestein and have been very happy with them (granted it has only been one winter with them!)
Winter tire experiences? smbrm CANADA 10 11-06-2012 04:42 PM
What Winter Tire for NY Weather? ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 84 10-29-2012 07:02 PM
Winter tire Dub666 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 01:32 AM
Need some help picking a winter tire... jm1681 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 08-29-2012 01:14 PM
Contribute your review for California Scion/Subaru dealers DuMa Southern California 20 02-06-2012 11:59 AM
