Old 09-14-2012, 12:02 AM   #323
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Catching fire after VVT failure, What in the actual fuck?
Old 09-14-2012, 12:32 AM   #324
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Originally Posted by 86BRZ View Post
For those owners like me don't have a problem yet, and worry about the CEL and shaking will come in any moment, looking at the rpm every signal stop...does any one know if there is a overall recall coming along soon?
From what I can gather there's been no mention of a recall circulating around the grapevine.
The best I can tell from reading around the net there's been approximately 6000+ FT86 cars sold and somewhere around 300-600 cars affected with VVT issues so far. From the "Cam Gear Related CELs - How many miles?" poll most of the cars affected developed the issue within the first 500 miles. There's a pretty good chance that if you've moved past that point you might be ok.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 09-14-2012, 12:44 AM   #325
Vb
Drives: Red frs
Im in the same boat as driving and checking - is it this stop? Can anyone just share who got it whether they were driving aggressive, overly passive, clogged air filter, whatever. Everyday i drive to work and back now feels like shit is gonna happen. I want to drive the car the way i want but i find myself too much babysitting it to avoid the cel. If the cel strikes as a lighting, i will accept that im at scions mercy, otherwise i want to extend this cel as long as they come up with a solution. I have a 6 cyl boxer in subaru tribeca and it has lights too. Clean air filter seems to help, but just temporarily, 3 months or so. Any warning pointers welcome. Stay cool my friends.
This car seems to have an inferior air flow. To me it feels it collects all the smells from other cars and i would not be suprised if not enough air gets into the engine when you drive slow but at high revs which would cause the fuel not burn up fully and kick out misfires from unburnt fuel. Thats why i wonder how people drive it leading to the cel.
Vb is offline   Reply With Quote
Old 09-14-2012, 01:40 AM   #326
86BRZ
86BRZ's Avatar
Drives: BRZ Limited arrived on 9/1/2012
I guess I will park the car away and start it once a week just to keep the battery going, until this CEL true cause and fix unfold. If/when the "CEL lighting" strikes my engine, I can roll to my dealer and know I will have a good fix waiting. From what I have read so far, it seems like a combination of lower tolerance of various parts, after broken in, will have this happen first...to your point, different field usage and driving habits can added to it...and a new ECU timing (wider the margin of the engine working) may be the true fix...that is also why I think eventually it will happen to all car produced (hopefully not, and hopefully I am guessing wrong here)
86BRZ is offline   Reply With Quote
Old 09-14-2012, 05:27 AM   #327
jesperswe
Drives: GT86
As of today my Toyota shop orderd new parts and haven't heard anything about a software update...
jesperswe is offline   Reply With Quote
Old 09-14-2012, 11:08 AM   #328
86'ing
Drives: Raven 6-MT
i tell you its strange, but my dealer told me all they were going to do is update the ECU with a software, and i quote the tech said he got word from a toyota engineer, direclty. becuz it just so happens that the lead mechanic at my dealership is in the champions program and those select few who are in the program have access to the actual toyota engineers!!!!!!!! maybe he was just sugar coating it for me and saying that they just need to update the ecu with software, but he noted that hes glade that he doesnt have to go into the engine. twist ur tech arm till they disclose to u about the software!!!!! ITS OUT THERE!!!!!!!!!!!!!!!
86'ing is offline   Reply With Quote
Old 09-14-2012, 11:16 AM   #329
Yruyur
Yruyur's Avatar
Can your tech reference a document that others may be able to use here?
Old 09-14-2012, 11:35 AM   #330
86'ing
Drives: Raven 6-MT
definitely as soon as they complete my car ill post the report.
Old 09-14-2012, 12:56 PM   #331
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
lol... and I had to raise my speaking tone up quite a bit to get the dealer to give me a rental over driving my fr-s the 2nd time it kicked the CEL/slip lights on....
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 09-14-2012, 01:35 PM   #332
Marrk
Drives: Honda Fit
Thanks for this info . . . because I haven't yet figured out how a hardware problem could be causing the idle issues. Unless it's something like a sensor that is suffering intermittent failures. But a cam sprocket?
Marrk is offline   Reply With Quote
Old 09-14-2012, 02:41 PM   #333
TurnOne
Drives: BRZ Ltd. WR Blue 6MT
Dealer called and said car is in the air and parts in hand. Replacing all 4 cam gears. No ecu.
Chris
TurnOne is offline   Reply With Quote
Old 09-14-2012, 02:55 PM   #334
jesperswe
Drives: GT86
Chris
What the? Gotta be the first car to have all 4 changed? Wonder why :o
They are only changeing the CAM gear giving error code on mine, also no ECU either.
Old 09-14-2012, 02:57 PM   #335
mact
Drives: 13 GTI
I thought the ECU was further down in the official repair flowchart and was a step to perform if the codes came back again? Replace ECU if the other components have been replaced..
mact is offline   Reply With Quote
Old 09-14-2012, 03:01 PM   #336
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
*** Major update for me.
Just got off the phone with my dealership to see what parts they were still missing. They said they received the cam gear and it came damaged. They called Scion HQ, and according to my service manager they told him that it's a good thing they didn't replace the cam gear/sprocket along with the other parts and that Scion has issued a service update which is a newer revised ECU & flash.
Omar GC
Instagram: 2jzus
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
