#323 | |
Drives: Crapcan
#324 |
Drives: 2013 frs base
I'll be curious to see how RS Motors handled the crank sensor. He said my motor will be ready in a few days.
#325 |
Drives: Crapcan
I figure just a new bracket to hold the first gen crank position sensor at the correct distance to read. The stock sensor is mounted to a little bracket already on the driver side at a little window in the block.
#326 | |
Drives: 2022 Toyota GR86 Premium 6MT
17-20 FA20 and 22+ FA24 both have the same hall effect waveform, the sensor and the size of the reluctor is the only change. So we can reuse the FA24 crank signal with an adapter harness. On the 13-16, we need to get a variable reluctance signal out of the FA24. That’s what my custom crank position sensor and bracket setup accomplishes. |
| The Following 3 Users Say Thank You to removedonut For This Useful Post: |
#327 | |
You’d need to bury the bracket waaaaay down in the bellhousing to get the sensor close enough, and at that point the bracket would probably interfere with the backside of the flywheel. They probably also settled on using a different variable reluctance sensor. If we both ended up with the Prius sensor I’m gonna laugh though. |
#328 | |
Comparison between my bracket w/ Prius sensor vs. stock FA20 bracket/sensor. You can see that their angle is much more reminiscent of the FA20 bracket versus mine which is modeled on the FA24 bracket. |
| The Following 5 Users Say Thank You to removedonut For This Useful Post: | blsfrs (05-19-2024), kmbkk (05-19-2024), NoHaveMSG (05-19-2024), Spankopotomous (05-19-2024), Teseo (05-18-2024) |
#329 | |
Drives: Crapcan
Your setup is interesting and I didn’t know about the 17+ and FA24 using VR for crank signal. I’ve never had a 17+ engine in my possession.
#330 | |
Drives: 2019 Toyota 86 TRD SE
I talked to the person who gave me that link and did his own swap. He didn’t have to provide the VIN. He said he explained to the dealership what he was gonna do with the motor. They said no warranty and sold it to him. I guess you might have to find the right dealer. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Drifter X For This Useful Post: | NoHaveMSG (05-19-2024) |
#331 |
Am I correct in assuming the Prius crank sensor reads/generates a VR sine wave like our 2013-2016 FA20s.
#332 | |
Yes. |
#333 | |
Pretty cool how we arrived at different solutions to the same problem lol. My solution is pretty indicative of the fact that I’m a wiring harness/electronics guy and chose to solve it electronically. Whereas Ronnie has an actual shop with fabrication capabilities and chose to solve it mechanically. |
| The Following 6 Users Say Thank You to removedonut For This Useful Post: | alphasaur (05-21-2024), autoracer86 (05-22-2024), CSG Mike (05-24-2024), T-Steve (05-22-2024), Teseo (05-21-2024), Ultramaroon (05-22-2024) |
#334 |
Back in the day, we would have laid the reluctor wheel on the floor and hit it a few times with a BFH.
Which wiring harness do you use? |
#336 | |
| FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 11:18 AM |
| FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 09:27 AM |
| Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 11:55 AM |
| FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 04:59 PM |
| Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 01:33 AM |
