Old 06-23-2022, 03:03 PM   #323
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
Does anyone know if the Subaru BRZ STI 17"x7" wheels work with the PP brembos? I looked in the list and the posts but don't recall anyone mentioning it.
Thanks in advance.
jbsali is offline   Reply With Quote
Old 06-24-2022, 12:34 PM   #324
TwinFTW
Drives: 17 BRZ w/PP & 08 STI
Thanks in advance.
I think they won't... I almost bought a set on FB but my research at the time was that they wouldn't clear the PP setup.
TwinFTW is offline   Reply With Quote
Old 06-26-2022, 12:27 AM   #325
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Rays Wheels Volk Racing CE28N 17x8.0 +44 WILL LIKELY FIT out the box.
This is based in test fit on Brembo GT (which is ~3mm wider/more outboard) plus 3mm spacer, yielding 3mm of clearance
Edit 7/4 correction. Wheels will likely fit
EndlessAzure is offline   Reply With Quote
Old 07-07-2022, 05:56 PM   #326
bubsterboo
Drives: 2019 BRZ Raiu
Does anyone know if the stock 2022 gr86 BRZ wheels clear the brembos on the older BRZ?
bubsterboo is offline   Reply With Quote
Old 07-07-2022, 07:04 PM   #327
clio
Drives: 2013 Subaru BRZ
Interested to hear this too
clio is offline   Reply With Quote
Old 07-07-2022, 10:46 PM   #328
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I believe so. The 2022 BRZ and GR86 should only differ in finish/color, and the BRZ wheels are on the list as FIT. I'm pretty sure I've seen photos of GR86 wheels over Brembos somewhere too.
Follow the build thread for my GR86!
timurrrr is offline   Reply With Quote
Old 08-04-2022, 05:59 PM   #329
lapsio
lapsio's Avatar
Drives: 2020 BRZ Final Edition, 1999 MX5 NB
I'm gonna add my entry:
OZ Ultraleggera 18x8 ET48. Fit with 225/40r18 tires with no rubbing against anything. Brakes clearance is quite small but I'd say it's comparable to OEM PP wheels:
MORE PICS HERE:
https://www.ft86club.com/forums/show...4&postcount=54
lapsio is offline   Reply With Quote
Old 09-04-2022, 12:57 AM   #330
EndlessAzure
Wheels for Brains
Rays Wheels Volk Racing TE37 17x8.0 +44 WILL LIKELY NEED 3mm spacer.
This is based on a test fit with Brembo GT (which is ~3mm wider/more outboard) plus 5mm spacer, yielding 2.5mm of clearance
Old 10-12-2022, 12:32 PM   #331
PikachuBRZ
waiting on yellow gas
PikachuBRZ's Avatar
Drives: 2017 BRZ Series.Yellow #247
Anybody know if Enkei TS-5 17x9 +45 would run into any interference with ppb and tein flex z? I can't really judge from the pics of the 17x8s how much clearance there is and don't know where rubbing might occur.
PikachuBRZ is offline   Reply With Quote
Old 10-14-2022, 11:56 AM   #332
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Based on the fact that the 17x8 in the same offset clears the brakes, I'd say brake clearance is most likely not a problem.
As for clearance / rubbing with your suspension, no idea, but it's likely to rub a bit. In a recent post on the CSG/RCE suspension thread, someone else mentioned that they're experiencing some rubbing at full steering lock (presumably on the chassis / wheel arches) with a 17x8.5" ET45 wheel, even when equipped with 10 mm spacers.
Tatsu333 is offline   Reply With Quote
Old 10-14-2022, 12:11 PM   #333
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
As for clearance / rubbing with your suspension, no idea, but it's likely to rub a bit. In a recent post on the CSG/RCE suspension thread, someone else mentioned that they're experiencing some rubbing at full steering lock (presumably on the chassis / wheel arches) with an 17x8.5" ET45 wheel, even when equipped with 10 mm spacers.
Link direct to the post please.
dragoontwo is offline   Reply With Quote
Old 10-14-2022, 02:56 PM   #334
Tatsu333
There were a number of posts from the individual, so you'd have to go back further in the thread to see all the info, but here was his most recent one: https://www.ft86club.com/forums/show...postcount=4259
My suggestion to him was that it was likely just an unavoidable consequence of the wheel/tire combo's specs, and that he use a steering rack limiter kit to reduce the full lock angle and eliminate the rubbing.
Old 10-17-2022, 09:31 AM   #335
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
You can't guess based on those numbers. Especially with Enkei's.
17x8 +45 RPF1's clear PP brakes, 17x9 +35 do not clear.
I do not know the answer for the TS5's.
Breezio is offline   Reply With Quote
Old 10-17-2022, 02:38 PM   #336
PikachuBRZ
PikachuBRZ's Avatar
That's why I was asking. I've also seen wheel manufacturer sites say that different widths may have different spoke contours for balancing
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 08:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 05:15 PM
