Old 09-29-2017, 09:26 PM   #323
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by C4RBON View Post
I ordered the muffled track pipe from Nameless 2 weeks ago for DS next year.
https://shop.namelessperformance.com...-pipe-brz-frs/
Would it be legal for SSC?
- It exists in one of the original locations.
- I'm not sure what their definition of a "track pipe" is.
- It is stainless steel.
- I would use the OEM midpipe.
- There is a 5" muffler, I am unsure of its internal construction.
I think their track pipe is in reference to non-muffled straight piped and deletes. The muffled one with a 5" muffler should be fine.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 09-29-2017, 09:26 PM   #324
M0nk3y
Track pipe in their definition is basically like a straight pipe. For example, an unresonated Perrin would be illegal because the mid-pipe is just a straight section of pipe...thus track pipe.
Anyways yes,that would be legal.You just need overall length
Kyle H. - #89 STX
Old 09-29-2017, 09:27 PM   #325
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
It sounds like it should be legal.
G_Ride is offline   Reply With Quote
Old 09-29-2017, 09:39 PM   #326
C4RBON
C4RBON's Avatar
Drives: '15 BRZ, '19 GTI
• Minimum Weight: 17 lbs., including:
o Wheel weights
o TPMS sensor if installed
o Tire valve (type unrestricted)
(For compliance purposes the specification tire will have a weight published in the tire section of the
Official Specification. The tire and wheel assembly can be weighed “all inclusive” to determine
compliance.)
This is interesting. How can there be a spec weight for a tire, and item that loses mass as it wears?
If the wheel spec weight is 17 lbs, and the spec tire weight is 23 lbs (the listed weight for a RE-71R, for example), the "all inclusive" weight would need to be 40 lbs. But if the tire is worn and weighs 21 lbs, now my wheel "weighs" 15 lbs and is illegal?
By this logic, the spec tire weight needs to be it's minimum, worn weight. Which means if I have new heavy tires, I can use lighter wheels...
I don't like where that path leads. The last thing I want to worry about is the weight of my tires. And I don't want to buy 19 lb wheels to account for worn tires.
It is also noteworthy that the wheel includes valve stems, TPMS, and wheel weights. The Advanti DST Storm S1 wheels weigh 16.95 lbs according to TireRack. I'm sure you could make up that 0.05 lbs with wheel weights, TPMS, and valve stems. (They are also on sale/closeout for $160 right now...)
C4RBON is offline   Reply With Quote
Old 09-29-2017, 09:48 PM   #327
blkwrxwag
Drives: DS FRS
I would think that Nameless track pipe is legal.
-Max H.
blkwrxwag is offline   Reply With Quote
Old 09-29-2017, 09:50 PM   #328
M0nk3y
It would not be under current rules because the rear muffler will have no baffled section
Kyle H. - #89 STX
Old 09-29-2017, 09:56 PM   #329
blkwrxwag
Drives: DS FRS
How the hell do you know what's inside the muffler?
-Max H.
Old 09-29-2017, 09:59 PM   #330
blkwrxwag
Drives: DS FRS
Wouldn't it count as a chambered section?
-Max H.
Old 09-29-2017, 10:17 PM   #331
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
TR has the equipment to shave an example of whatever tire gets spec'd down to the cords and then weigh that.
I still Don't understand why they made the exhaust restrictions tighter than street. I mean, people could spend a lot of money, sure. But they are not going to gain an advantage when they do.
Twinz is offline   Reply With Quote
Old 09-29-2017, 11:12 PM   #332
cjd
cjd's Avatar
Drives: 2017 BRZ
It's a spec class. The weight differences are not insignificant - even as outlined, but... without the restrictions they've put in place, chasing a (quiet enough for all sites) Ti setup would suddenly become a requirement.
As it is, I think people will be running fuel levels as low as they can when the going gets close.
C
Old 09-29-2017, 11:16 PM   #333
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
C
You don't already do that?
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 09-29-2017, 11:40 PM   #334
cjd
cjd's Avatar
Drives: 2017 BRZ
I mostly do, but the truth is I'm just not consistent enough for it to matter. Some day...
Old 09-30-2017, 12:36 AM   #335
Twinz
Twinz's Avatar
C
The drivers themselves will account for weight differences more significant than the available weight savings from a cheap street-class exhaust vs an expensive street class exhaust.
If they want cheap and quiet just specify steel and a resonator. Done.
Old 09-30-2017, 12:45 AM   #336
Twinz
Twinz's Avatar
The first ones I found have an offset that won't work for the class. What offsets did you find?
*edit* nvm found them.45mm
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 01:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 09:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 11:20 AM
