Old 03-17-2016, 02:17 PM   #3305
Originally Posted by Alltezza View Post
Is that with stock internals? 400whp with the C30
Yes, but we consider it a ticking time bomb. I'm actually surprised it hasn't thrown a rod.
Old 03-17-2016, 02:37 PM   #3306
jasonojordan
Drives: 2013 satin white brz limited
So is there a consensuses on what amount of hp/tq is "safe" on the stock block?
jasonojordan is offline   Reply With Quote
Old 03-17-2016, 03:37 PM   #3307
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
300 is the lowest I've seen anybody claim. Most say 350-400 depending on how you get there.
ScionOfHorus is offline   Reply With Quote
Old 03-17-2016, 03:41 PM   #3308
jasonojordan
Thanks. 350 is my target range on e85. 300 on 93.
Old 03-17-2016, 06:12 PM   #3309
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
How long is break-in? Can you perform it all in, let's say, a drive to your tuner if you don't make serious load or should you do multiple short trips without load?
Trefoil is offline   Reply With Quote
Old 03-17-2016, 06:58 PM   #3310
twag4
Drives: frs
@CSG Mike, what kind of power on e 85 with ace and regular pulley? I'm thinking of doing this. I know it is probably in here, but I am too lazy to look, and I was hoping you would just tell me.
twag4 is offline   Reply With Quote
Old 03-17-2016, 07:10 PM   #3311
We never tried, but I would expect maybe 8-10% less power?
Old 03-17-2016, 09:25 PM   #3312
kuidaore
Let me ease the mind of those who are on the fence. I've had the kit installed by CSG since last February so it's been over a year. The car is my daily driver. I have put approximately 22K HARD miles. I'm talking about hard driving in canyons almost every weekend, autocross, and a track day here and there. Sadly, only had an issue with my serpentine belt (keep a spare for emergency) that may have been defective from the factory--rare issue. Kit is still going strong!
kuidaore is offline   Reply With Quote
Old 03-18-2016, 12:07 PM   #3313
cgjeff
Drives: 2015 Scion FRS
Have to jump in here and share some excitement. Just ordered the C30 from CSG, along with the Delicious tuned ECU. Still debating on which ACE header to order so I can install everything at the same time.
BIG thanks for Mike at CSG and Zach at Delicious for all the awesome advice and patience with my continuous e-mails!!
cgjeff is offline   Reply With Quote
Old 03-18-2016, 02:19 PM   #3314
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
That's exactly what I'm going for lol I feel like I should go with the C30 over the C38 since I won't be able to use it to it's full potential anyways. Especially with a HBP
Alltezza is offline   Reply With Quote
Old 03-18-2016, 02:46 PM   #3315
strat61caster
strat61caster's Avatar
You guys better be talking crank, everything I've read is that 300whp is when stuff starts breaking under heavy usage.
If it's a dyno queen sure, crank >300whp out of it and baby it on the street. But if you're going to DD it, track it, autox it, flog it regularly and actually make use of the power you'll probably have to keep it below 300whp unless your wallet is feeling too heavy and you like replacing axles. Again, just based on what I've read, I wouldn't push a stock powertrain FA20 past 260whp unless I had a budget for the worst outcome sitting in the bank, and I haven't seen anyone with a failure running a CARB tune which puts out around ~240whp (on this, the Edelbrock, and the Vortech). That is right in the 300-350 crank hp range so maybe I'm preaching to the choir, idk.
ineedyourdiddly
Old 03-18-2016, 02:55 PM   #3316
ScionOfHorus
I'm talking wheel. Last I checked before getting the ACE header, I was at 263 wheel. And I flog my car hard. Includes track days. Last track day was after the header, car should be around 280-290 now. With e85 I'd be around 330-350.
Sent from my MotoE2(4G-LTE) using Tapatalk
Old 03-18-2016, 03:01 PM   #3317
SoCalArgento
Drives: 2014 Argento FRS
I just skimmed this thread but looks like they pushing 400+whp on turbos with stock drivetrain and internals... However they are breaking stuff 🤔
http://www.ft86club.com/forums/showthread.php?t=66968
SoCalArgento is offline   Reply With Quote
Old 03-19-2016, 08:45 AM   #3318
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Infamous Performance View Post
Like I said, we have had several customers snap rods at well below 300whp (measured on our Mustang dyno). I recently had to rebuild one complete long block due to a CATASTROPHIC failure of 2 rods. JRSC kt, e85. When I say CATASTROPHIC, I mean new block halves, new heads, new timing covers, new everything. Nothing was reusable. Car is making approx 285whp.
Have you seen similar issues with people running carb tunes or similar levels of power? (I'm not sure how much a typical carb tune would make on your dyno)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
