Old 11-12-2021, 11:43 AM   #3305
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Alright, I could use a little PC wizard help.
So here's how the story begins,
A few days ago, when I booted my computer up, it said the CPU was new and to begin the boot sequence. Initially I said no to it as I hadn't changed anything. It did it another time and then I said yes. After that all booted fine with no problems for a couple days. Then this happened again last night when my computer restarted after a windows update. Well this morning when I went to turn my PC on, it didn't post initially so I just restarted it. Then it brought up the 'Press DEL or F2 to enter BIOS' it usually does upon boot, but there was no circling Window's logo nor did it go any further than that.
I cracked open my computer and the Asus Mobo LED was red for the CPU. I figured, maybe with the windows update it needed a BIOS update. After I did the update, it posted the 'bios recovery mode' display for whatever reason. I shut the computer down and checked the BIOS I had flashed from my laptop and it was the right one. When I went to turn the computer back on again, the DRAM light came on. I took out one stick of RAM and then the white LED for the VGA light came on. Tried putting in my temporary video card to see if that maybe had something to do with the riser cable reverting to Gen 3 and not posting. Nothing came up and there was no post. Then the VGA light stayed white and nothing happened. I tried updating the BIOS again, nothing happened. No post, just the white VGA light.
So... I know this is a wild chase of mobo lights and not knowing what I did wrong. But if anyone has tips or suggestions I'd appreciate it.
MS, CSCS, TSAC-F, CPT
Old 11-12-2021, 11:56 AM   #3306
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Try clearing the cmos?
Old 11-12-2021, 12:00 PM   #3307
weederr33
weederr33's Avatar
That's the next step and I'm going to feel really stupid, but I can't find the clear cmos button or battery on my ITX board. So I may have to pull it out.
Old 11-12-2021, 12:11 PM   #3308
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
The RAM controllers are in the CPU, so any lights indicating a fault in DRAM could be a faulty CPU.
Old 11-12-2021, 12:23 PM   #3309
spcmafia
spcmafia's Avatar
If that doesn't work try another SSD. It could be that some files got corrupted and the SSD where the boot drive takes place got all messed up.
Old 11-12-2021, 12:26 PM   #3310
spcmafia
spcmafia's Avatar
This may help
https://forums.tomshardware.com/thre...klist.1285536/
Old 11-12-2021, 12:33 PM   #3311
weederr33
weederr33's Avatar
Ok, just downloaded the manual and found the clear CMOS header location and reset it. We are good to go... for now!
Old 11-13-2021, 09:47 AM   #3312
soundman98
ProCrastinationConsultant
soundman98's Avatar
i'm late, i know. so i'm compensating with bigger text.
you need a new battery!
real explanation of same symptoms @ 6:00
Old 11-13-2021, 09:57 AM   #3313
Yoshoobaroo
TRACKBREAD
Wait motherboards still have batteries?
Old 11-13-2021, 10:12 AM   #3314
soundman98
soundman98's Avatar
yep. despite all the fancy flashing lights and digital controls, we're all still stuck in a 1970 time loop.
Old 11-13-2021, 10:17 AM   #3315
weederr33
weederr33's Avatar
Well I found the battery under the Vram heatsink but after I used the clear cmos headers all is fine. However, my computer does not like being shut down and will boot back up, but not post. So yea... that's a thing now.
Old 11-13-2021, 10:23 AM   #3316
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well, there's also the supercap option. The problem with those is they lose charge faster.
Old 11-13-2021, 01:01 PM   #3317
soundman98
soundman98's Avatar
most likely cuplrit when computers don't post is usually memory
otherwise, it could be the default bios-- if you're using a wireless keyboard on a motherboard with ps/2 mouse/keyboard ports, sometimes the lack of a ps/2 keyboard will halt post
Old 11-13-2021, 01:10 PM   #3318
elBarto
elBarto's Avatar
Drives: Toyota GT86
Had that with a few pc's as well. Problably a correct shutdown will fix it. Try using the following command in the command prompt:
Code:
Shutdown /s /t 01
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
pc master race, u no have 3080
gamers lounge Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 25 01-21-2014 04:32 PM
GT Acadamy Gamers Banned from Britsh GT Pro-Am WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 16 02-11-2013 06:37 PM
