Old 10-26-2012, 02:22 PM   #3305
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Roadstercycle View Post
I missed a lot on this thread, is there a fix? Didn't say it was a Visconti bug just wondering if there is a fix.
some people have had success switching maps repeatedly, others claim pulling the battery cable for a few minutes fixes it. It hasn't bothered me since there's always the digital readout of fuel level as part of racerom
xjohnx is offline
Old 10-26-2012, 02:27 PM   #3306
Roadstercycle
FRS Rear Mount Turbo
Roadstercycle's Avatar
Drives: 2013 FR-S Raven, Rear Turbo
Thanks I'll give it a shot. I believe I only have 1 map for the turbo.
Roadstercycle is offline
Old 10-26-2012, 02:28 PM   #3307
xjohnx
Grip>Slip
xjohnx's Avatar
ahh, didn't notice you were turbo. in that case i could see how the whole gas gauge issue could get annoying. good luck!
xjohnx is offline
The Following User Says Thank You to xjohnx For This Useful Post:
Roadstercycle (10-26-2012)
Old 10-26-2012, 03:39 PM   #3308
djliquidsteele
Drives: Scion FR-S
@john I've noticed the Injen intake seems to get the most gains. Have you had anyone with this intake and your tune that has seen additional gains? Or does a tune negate the fact the Injen leans out the AFR?
djliquidsteele is offline
Old 10-26-2012, 05:05 PM   #3309
boris
Drives: 2013 white scion frs
Hey john. Updated the form few days ago. Just wondering if I will be getting the correct file since the last race rom I got isn't the right one for canada and the first 4 digits are different from what has been posted on forum
boris is offline
Old 10-26-2012, 06:36 PM   #3310
bluecollarfrs
Drives: Ultramarine FR-S
Does anyone know what the three different Race Rom Maps are on an AT? When I hold the cruise control down and switch between Maps, I have 1, 2 and 3.
bluecollarfrs is offline
Old 10-26-2012, 06:39 PM   #3311
xjohnx
Grip>Slip
xjohnx's Avatar
I'm not sure what they are on the AT map, but it should be pretty easy to figure it out.
switch to your MPG gauge, it should be pretty easy to tell there whether it's showing your actual MPG, your AFR, the % of fuel in your tank, or a time (if it's a time, then it'll be either 0-60 or 1/4 mile).
The car has to be in motion for any of them to appear.
xjohnx is offline
Old 10-26-2012, 06:46 PM   #3312
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
These are the maps for the autos
MAP 1 = Fuel Economy Gauge
MAP 2 = A/F Ratio
MAP 3 = Fuel Tank Level
Area86 is offline
Old 10-26-2012, 07:17 PM   #3313
bluecollarfrs
Thanks guys! I appreciate the help
Old 10-26-2012, 08:17 PM   #3314
CharlieChaos
Drives: FRS
Ok noob question. Everything went through and it told me to turn ignition off an its sitting on
Please wait...
This will take 1 second
And in the programming took it says restarting ECU. How long does it normally take till you need to turn car on to idle?
_____________________________________________
http://genometuning.com
http://www.BlackHandGaming.com
CharlieChaos is offline
Old 10-26-2012, 08:25 PM   #3315
DSTL
Drives: 2013 BRZ Limited 6MT
Please wait...
Did you turn the ignition on and it finished successfully? Can you query ecu if so and it shows the correct time for flash? If so should be good to start it up and just led it idle for a bit before touching the accelerator.
DSTL is offline
Old 10-26-2012, 08:26 PM   #3316
DSTL
It will tell you when to turn the ignition back on btw. Should literally only be a few seconds when it says wait one second though.
DSTL is offline
Old 10-26-2012, 08:28 PM   #3317
CharlieChaos
Drives: FRS
Turned car on redline is at 7800 looks good just can't switch maps
Old 10-26-2012, 08:38 PM   #3318
DSTL
It has been sitting at the
Please wait...
This will take 1 seconds
Hasn't promted to turn the car on and it's been 10+ minutes
Never seen that. I would personally turn on the ignition but not start the car and see. That's me though, not advice. You try John on his cell? This is the kind of thing he generally wants calls for.
DSTL is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 10:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
