#309 | |
2013-2014 factory recommend interval is 7,500miles. 2015(brz at least) is 6,000miles Suggested/recommend cut in half when running e85. But look at the test results, some people have good test results and some can run up to 10k on a stock setup. Do whatever you are comfortable with, get it tested and go from there. I would suggest 4k(your 3,500 ok too) and get it tested, good medium between 3k and 5k, while be a little bit on the safe side. |
#310 |
One & Done (AOZORA)
Drives: '15 Series.Blue BRZ (WRB)
Going to do my 2nd oil change at 5000 miles. I'm at 4600 right now. Did my 1st oil change at 2500 with Eneos Sustina.
For this 5000 mile change, i'm going with Royal Purple. Should be interesting!
"I have the need....the need for speed! - Maverick (Top Gun)
#311 | |
Poor College Kid
Drives: ~.~
#312 |
Drives: 2012 Toyota 86
#313 |
Drives: 2013 Brz sport-tech
I run 1 quart mobile 0w40 11.99$ and top up the remaining 4quarts with mobile 0w20 39.99. Oem filter , used to run amsoil 0w20 signature it burnt 1-1.5 quarts in a 5000km cycle, i also ran toyota 0w20 and the mobile mix i find keeps the engine very quiet and burns no oil at all, redline mt90 is my favorite in the trans keeps it quiet on idle and shifts silky smooth compared to oem or amsoil 75w90 gl4 mtf
#314 |
It nets me a 0w25 ish heavier 20 weight i prefer the one quart 0 40 to half half with 0 30 just outta personal preferance
#315 | |
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Shot some pictures off of Mobil 1's website on the oils for you guys. Furthermore, the link attached is a current rebate offer Mobil 1 is doing until 31-MAY-2015 on getting $15 off 5qts and 1 oil filter. It's a great deal ![]() https://apfco.net/secure/R8235W/Home/Entry
#316 |
Drives: 2022 BRZ
Which mobil 1 0w-20 oil do you recommend?
- Extended performance, super synthetic, or advanced fuel economy |
#317 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Monil 1 or royal purple. Ive seen how RP treats internals.
#318 |
That Striped FRS
Drives: 2013 Ultramarine FR-S 6MT
I use Royal Purple in everything from atv's to Diesel Trucks, always treated me well.
#319 |
Drives: 10 Series #974 6m/t
#320 |
Drives: 2017 BRZ Inazuma Edition
I'll just leave this here. Old thread I know, but none the less.
Japanese BRZ manual recommends up to 5w40. Maybe this is already known. [IMG]https://uploads.tapatalk-cdn.com/20170312/3***3ba488e958270564ce590744e5be.jpg[/IMG] Sent from my Nexus 6 using Tapatalk |
#321 |
This is also the high-performance specs for oil recommended by Subaru in Japan:
LES PLEIADES Zero 0w30. ![]() It's specs are just slightly lower than Mobil 1 Full Synthetic 0w40... Sent from my Nexus 6 using Tapatalk |
#322 | |
Senior gif poster
Drives: 2013 Asphalt FRS
