Old 05-05-2016, 11:08 AM   #309
ajaxthebetter
Drives: 2014 Subaru BRZ LTD 6MT
Worse than that, they absolutley seem to provide no indication they are going to kick out. It strikes me as pretty sudden. I'm only on header/tune and trying to drive in anything but perfect conditions is a brutal exercise. Washington rain, etc. I got mine as a band-aid since I'd spent a healthy sum of money on wheels/suspension but I regret it almost every day haha. Drive safe.
ajaxthebetter is offline   Reply With Quote
The Following User Says Thank You to ajaxthebetter For This Useful Post:
DustinS (05-05-2016)
Old 05-05-2016, 11:18 AM   #310
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I haven't had much rain experience yet, as all the rain we have got so far has brought hail, so in the garage it goes. I bought mine as a Band-aid as well till the RS-R was available again, but it looks as though they are getting rid of existing stock before releasing the RS-RR in America. Trying to find a source for the new RS-RR is proving to be difficult.
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
ajaxthebetter (05-05-2016)
Old 05-09-2016, 01:58 PM   #311
DustinS
DustinS's Avatar
She got a proper wash and some Ammo Creme Wax for Cars and Coffee the next day. Plans are to get a good paint correction, and possibly a C-Quarts application.
Had some free time, so a friend helped me pull the rotors, clean the rust off, and paint them. He left the black paint at my house, so Silver it was.
Checking on Friends dogs as they were out of town, only to find they have a terrible driveway...
batlwagn (05-20-2016)
Old 05-09-2016, 03:26 PM   #312
Bamsterman
Drives: 13' Scion FRS
There's a new Kumho tire that seems like it might be pretty good...have you thought about checking it out? Ecsta PS91. At least I think its new...there's a new Firestone performance tire. Firehawk Indy 500. Both look pretty decent and at a fair price.
Bamsterman is offline   Reply With Quote
The Following User Says Thank You to Bamsterman For This Useful Post:
DustinS (05-09-2016)
Old 05-09-2016, 04:38 PM   #313
DustinS
DustinS's Avatar
Haven't seen those yet. Going to look into them. Thanks!
Old 05-16-2016, 11:24 AM   #314
DustinS
DustinS's Avatar
Quick Video A local Photographer did of my car. Loaded on Instagram is why it is so short.
[ame="http://youtu.be/q5jBX-_BdGE"]http://youtu.be/q5jBX-_BdGE[/ame]
Old 05-17-2016, 12:38 PM   #315
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
God damn that color looks good clean
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
DustinS (05-19-2016)
Old 05-19-2016, 02:07 PM   #316
DustinS
DustinS's Avatar
Trying to figure out the next step to take with the car. With a wedding in the works, fund are limited. I have probably one more semi-large purchase before I need to buckle down and toss the money into the wedding fund. Flex-Fuel for the turbo kit using OFT is getting super close to being released. If it is under $5-600 I may jump on it. Other options are a Wing APR GTC-200 (trying to find used), or some bushings/braces/hood vents.
Also looking into a boost controller for when the Flex-Fuel Kit become available. I have thought about just running a MBC. Simple enough. or Running a EBC. I have narrowed it down between the GFB G-Force II and the EBoost Street. Both are around the same price, and have similar features. Anyone running either of these?
Old 05-20-2016, 11:10 AM   #317
DustinS
DustinS's Avatar
New goodies coming in as a present from my grandpa:
I would have rather ran the Driveway Labs, but they are pre-order only, and I needed a way to cover the vents from rain due to the turbo sitting directly under the vent. Excited nonetheless
D_Thissen (05-20-2016)
Old 05-20-2016, 05:47 PM   #318
DustinS
DustinS's Avatar
Just purchased a 6 piston caliper that I think will work awesome (Should fit STI Rotors). I am in talks with my friend that is a machinist to make the brackets. If they work well, we may make the brackets available. If these prove to work, I will probably step up to a 350mm Rotor. This should all be had for less than the wilwood kit I was putting together.
Old 05-20-2016, 05:54 PM   #319
D_Thissen
D_Thissen's Avatar
I love this build man. Keep it up !!
The Following User Says Thank You to D_Thissen For This Useful Post:
DustinS (05-20-2016)
Old 05-21-2016, 01:59 PM   #320
SullyStyle
Drives: Hyperblue BRZ 2016
Did you have to get rid of your crashbeam when you put on the spd turbo? I'm looking to get it, but not sure if I want to get rid of my crashbeam..
SullyStyle is offline   Reply With Quote
Old 05-22-2016, 09:07 AM   #321
DustinS
DustinS's Avatar
I got rid of mine long before I went turbo. There are a lot of aftermarket solutions for crash beam replacement.
edit: A little more info on the brakes coming in. I made a mistake in some of my research and the caliper I have coming in has too much piston area. Unfortunately they are the cheaper of the two options. So I am going to have to buy the calipers I need at a later date (Got to make sure I have the extra funds for the OFT Flex-Fuel).
OEM Piston Area: ~11,503mm2
STI Brembo: ~11,668mm2
6 Piston Brembo: ~12,233mm2 (Ordered)
6 Piston Brembo: ~10,990mm2 (Need)
6 Piston Wilwood: ~10,449mm2 (Part of previous brake plans - Used on Wilwood kits currently sold for FRS/BRZ)
4 Piston Wilwood: ~10.649mm2 (Currently Running- Used on Wilwood kits currently sold for FRS/BRZ)
8 Piston Brembo: ~11,354mm2 (Really Want)
I did run a set of wilwood calipers with a Piston Area of 12,408mm2 for a long while (Originally pictured wilwoods at beginning of build thread) due to part number error on the link I bought the Brackets from. So I should be able to use the 17z caliper as a mock up (from what I can find the two calipers I am looking at mount the same).
Old 05-23-2016, 03:02 PM   #322
DustinS
DustinS's Avatar
Cockatoo (05-23-2016)
The reason I'm always broke - Dustin's Supercharged 86 Dustin Member's Car Journals 211 11-08-2015 11:57 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 12:43 PM
Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) Kuzuri Great Lakes 20 02-16-2014 06:23 PM
Engine Warm-up Time Chad86 Scion FR-S / Toyota 86 GT86 General Forum 44 01-10-2014 01:03 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 03:50 PM
