Old 11-21-2015, 12:09 AM   #309
Dr Speed
Drives: Red
Originally Posted by sato View Post
Old post: NA 2.5 RS breaking 300hp back in 2005...
http://www.rs25.com/forums/f5/t36040...300-na-hp.html
Sent using tapatalk
Fail. 300hp is a crank horsepower estimate, actual dyno in link is for 235whp and appears to be STD numbers not SAE numbers. No smoothing factor listed... Undoubtedly the car made 215-220ish rwhp SAE
Dr Speed is offline   Reply With Quote
Old 11-21-2015, 05:51 PM   #310
stevo585
Drives: White 2014 BRZ
Originally Posted by MattHoffman View Post
i broke that with 3500$.. just saying. but then again my car is just like 1000 other brzs this will be one of a kind for sure
Oh a I agree this is has very low hp/$ ratio. I would not do it myself. A simple super charger kit as you mentioned is more cost effective.
stevo585 is offline   Reply With Quote
Old 11-23-2015, 09:16 AM   #311
celek
Resident Gear Head
celek's Avatar
This is not the point to the build. Anyone can put FI on this car in fact thousands have already, or swapped in an engine. If you have never driven a built all motor car it is exhilarating. Additionally ask the FI guys how many transmissions they have gone through. The build is following the original grassroots AE86 origin.
celek is offline   Reply With Quote
Old 11-23-2015, 09:59 AM   #312
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Mr. Tsuchiya-san..NA build
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 11-23-2015, 10:22 AM   #313
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Old 11-23-2015, 03:09 PM   #314
stevo585
I know the point of your build is to be different and travel the path not taken. My point is still valid though but its your car and the results will be interesting.
FI guys do go through trannys but not until your over 400+ whp or so. A lot of guys local to me have not broke trannys with power in the 500+ range, thus some of it is driving habits.
I think we can all agree a mild FI build in the 250-325 whp range is going to pretty reliable.
Old 11-23-2015, 04:08 PM   #315
aaguirre123
Drives: sti 2012 sedan
if the average 210 whp that you quoted is accurate then Celek's build is promising because the increased displacement to 2.3 fa20 motor will have a higher whp due to fr-s/brz are rear wheel drive cars. I am assuming of course that the N/A engines that you mentioned are installed in an AWD cars.
my predicted assumption of higher HP result was based on youtube video, by /DRIVE, of Crawford stating that for the same turbo the EJ made 360hp vs. FA20 made 430hp. that's a 19.44% difference. if we apply the 19.44% on 210whp, that's 251whp.
am I correct on my assumption? I sure hope Crawford is not blowing smoke.
Originally Posted by Dr Speed View Post
I was going to reference some of the EJ25 builds that average about 210rwhp on full N/A builds, bored, oversized pistons, cams, ported heads, headers etc.
Engine/Power Modifications:
EJ251 bored over 100mm
Wiseco 12:1 pistons/rings
EJ257 crank/rods/oil pump
ACL RACE series bearings, std clearances.
EJ251 SOHC heads, ported by owner, stock valve sizes
Delta 3000 grind cams
EJ253 (AVLS) valve springs
06 2.5i intake manifold (big plenum/big runner)
70mm Ford throttlebody
440cc injectors
LinkPlus G1 standalone engine management
TWE prototype longtube header
2.5" aluminum non catted exhaust
2.5" DNA spiralflow muffler
^^^ All this got the owner 204 rwhp on a built 2.5L
aaguirre123 is offline   Reply With Quote
Old 11-23-2015, 04:29 PM   #316
swarb
Nope. FI and NA are two different ball games. EJ vs FA20 is very much like FA20 vs F20C(s2000 engine), guess who wins by almost the exact same margin?
Old 11-23-2015, 05:34 PM   #317
aaguirre123
Originally Posted by swarb View Post
Nope. FI and NA are two different ball games. EJ vs FA20is very much like FA20 vs F20C(s2000 engine), guess who wins by almost the exact same margin?
comparing performance difference between an I4 to H4 2 liter engines? that's how you want to show that you are correct? that's how you want to argue your point of view? what a ninny.
Old 11-23-2015, 05:35 PM   #318
Dr Speed
Drives: Red
no that was rwhp in my build. You are bench racing. Math and reality are not necessarily the same thing, and a manufactuer is more likely to inflate numbers for marketing, advertising and sales. Also Turbo potential hp figures vs N/A number potential is not equal. I'd divide your 19.44% by 2 or more realistically.
Old 11-23-2015, 06:05 PM   #319
aaguirre123
I am just quoting what Crawford was stating that the FA20 yields more HP than an EJ on the same turbo. Because of this I am concluding that a NA FA20 will yield more HP than an NA EJ. Granted percentage increase in HP will be different but FA20 will yield more HP nonetheless. Also I would like to add that Subaru used the FA20 engine because a NA EJ20 or EJ25 can not reach the desired goal of 200 crank hp on pump. May be if you modify the design of the EJ20/25; Longer stroke, higher compression piston, DI/PI fuel deliver and redesign the rods to achieve a higher reving motor.
But wait, Subaru did modify the EJ20/25 motor. It's called the normally aspirated high reving FA20 motor.
Old 11-23-2015, 06:06 PM   #320
Hawk77FT
Drives: GTS 86
How 'bout we wait and see, hey? that'd be great!
Hawk77FT is offline   Reply With Quote
Old 11-23-2015, 06:30 PM   #321
swarb
No! I'd rather bench race other motors and prove to the world that crawford(my favorite) says the fa20 makes more power than a ej20 on boost which means nothing on this thread. I just wanted to make a point that it does, and it means nothing.
Old 11-23-2015, 06:52 PM   #322
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Lol stop
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
