#309 | |
I'm checking the brakes when I get home just to be sure, but I'm almost positive it isn't the brakes and it has to do with the rear settings causing me to slightly veer to the right. |
#310 |
Drives: 13 BRZ Limited WRB
Maybe there's something in-between your pads and rotor, causing them to bite more on that side...
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#311 | |
At least it will give me time to get the SPC LCA with the toe kit shipped and I can do all that on Monday. That should be enough adjustment for what I need. |
#312 |
Get a printout this time too when you have your alignment.
- Andy |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | chanomatik (08-22-2013), Sportsguy83 (08-22-2013) |
#313 |
1337
Drives: 2013 BRZ WRB S/C
Well I got my alignment done, not exactly what I had hoped for but it's not bad. Was hoping for more camber in the rear, but the guys there were having a tough time with the toe after adjusting camber - they did the best they could but I would probably go somewhere more experienced with this stuff next time.
Front: -1.5deg cam, 0.0deg toe Rear: -0.9deg cam, +0.1deg toe l/r I'm still pulling left on acceleration, right on deceleration quite substantially. I've been doing some reading and it could be a few things, bad tire, bad strut, bad bushing. I'm going to try swapping wheels left to right and see if the issue moves to the opposite direction - I guess the next step after would be to check the coilover. Is there any quick test to see if there could be an issue with one coil without removing them from the car? I don't really want to have to pay for another alignment unless I absolutely need to. |
#314 | |
Drives: Attitude
#315 | |
1337
#316 | |
I was like WHAT COULD IT BEEEEEE?
| The Following 2 Users Say Thank You to Gopherboy6956 For This Useful Post: | chanomatik (08-22-2013), djdnz (08-22-2013) |
#317 | |
Snow Don't Hurt!
![]() ![]() Sorry, totally off-topic! @djdnz, I'm glad you got it figured out! I was hoping it was just the tire. I had a bag plug last week on my STI wheels, making the car constantly pull to the left. Got it fixed professionally, though, and good as new! |
#318 |
1337
Thanks guys. FWIW I don't recommend the Continental ExtremeContact DW's. They feel so much more muted than the stock tires did. Next set I'll go with the set I should have picked in the first place, the Michelin PSSs.
#319 |
#320 |
Well, now my car is not driveable. Brake is seized up. Not sure which one yet, but I can't even move. Guess I'll find out what the seize is caused by when I get back on Labor Day. My vote is a brake line rather than a caliper. Might just replace the stock ones while I'm in there.
Things are just not going my way with this install.
#321 | |
1337
Did you possibly smash something while you were in there? Fingers crossed its not the caliper. |
#322 | |
If it turns out to be a bad caliper, I suppose new brake lines are on the list. |
| Racecomp Tarmac II Clubsport coilover | JoeBoxer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 11-16-2013 11:02 PM |
| Tarmac Zero Coilovers Specs? | tintumz22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 06-13-2013 11:26 PM |
| KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! | NJA | Brakes, Suspension, Chassis | 7 | 03-30-2013 08:26 PM |
| Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-12-2012 12:24 PM |
| Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster | knoxviue | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 35 | 01-20-2012 01:44 AM |
