#309 |
Drives: 2017 Toyota 86
I wouldn't doubt that the USDM version comes with a speed limiter. Oh well, when 2017s get tunes I'll do away with that.
#310 | |
Drives: 2015 Limited
Stock Stage 1 (Tune) Stage 2 (Naturally Aspirated Mods e.g. Header/Tune) Stage 3 Forced Induction (Turbo/Super) AT vs MT as well, since AT should be able to attain higher speeds. |
#311 |
Drives: Toyota GT86 Coupe Red (UK)
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
#312 | |
As my previous post (link) highlights, particularly in US and Europe speedometers are usually out by up to 10%, usually reading over, often deliberately to prevent owners suing manufacturers. Coupled with the only confirmed reports being of 149mph indicated (in Germany) could suggest the max top speed actually demonstrated is 149 - (149*10%) = 149-14.9 = 135 mph. I recall the original published figure from Toyota was 137mph. As to the electronic limiter suggested above, I believe this is far more likely to be wind with changes in wind speed causing sudden drops in the cars velocity as the power in versus aero drag out equation suddenly unbalances and the car slows. I believe the electronic speed limiters used as an agreement between German auto-manufacturers to stop the ever increasing autobahn top speed wars in the 1990s is set to 155mph.
#313 | |
Maybe speedometers are off a bit ...... but, the speedometer on my FR-S reads within one MPH of what my GPS indicates (at about 60 MPH)..... ![]() This has been fun ...... ![]() humfrz |
#314 | |
Dyno's are notoriously diverse in there results anyway. I read an article where a journalist took the same car to 10 different performance shops and got ten different readings, the spread across the results was significant. I can't remember the actual figure but it was something like 12%. Dyno's need to be calibrated carefully and often and most are not. Different performance shops are at different altitudes. Different weather / temperature etc make differences. The only useful Dyno results is when you switch some part of other and test on the same machine on the same day and even then the only reliable figure is the delta. The fact that your speedo reads accurately does not mean the one in the mentioned video is reading accurately.
#315 | |
What do you base your theory on, that a FR-S cannot exceed 140 MPH ......?? ![]() humfrz |
#316 |
All the official documents show a top speed of 140-145 mph (even the manufacturer can agree). Now of course that could vary a bit but there should not be any stock cars doing much more than that.
#317 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
I uh, did just post some video evidence of an Autobahn topout...can't really call BS on that.
-O/D
2016 FR-S, Hot Lava |
#318 |
Got a reference for that?
#319 |
Well, now @paulca ....... again I ask, what is your basis for believing a stock twin can't exceed 140 MPH ...... ??
humfrz - just another hot, smoky day in Puyallup |
#320 | |
#321 |
Drives: 2015 FR-S
#322 |
Of course I do. The old Scion site gave the top speed as 145mph but it is of course gone now. You will have to settle for the OFFICIAL Subaru documentation at 143 MPH (230 KPH) http://www.subaru.com.mt/13brz_spec.html
| Engine Speed vs Vehicle Speed for 6MT | DetroitJake | Engine, Exhaust, Transmission | 22 | 04-27-2013 06:56 PM |
| Need For Speed... Really? | Texas BRZ | Tracking / Autocross / HPDE / Drifting | 61 | 01-11-2013 11:59 PM |
| Top Speed | L3P47 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 12-18-2012 12:06 AM |
| top speed | JLMtm | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 10-30-2012 09:23 AM |
| speed | eindio | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-27-2012 10:59 AM |
