Old 08-28-2014, 04:18 PM   #309
subieshanerz
subieshanerz's Avatar
Drives: 2015 Subaru BRZ Series.Blue
Originally Posted by DarkSunrise View Post
That's really odd. Here's the D-Sport article.
Does anyone know if this is for the 2.5" or the 3" CBE? Buying today and haven't decided between the two.
subieshanerz is offline   Reply With Quote
The Following User Says Thank You to subieshanerz For This Useful Post:
Lokenzi (12-08-2014)
Old 08-28-2014, 04:19 PM   #310
DarkSunrise
DarkSunrise's Avatar
That was for the 2.5".
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Old 08-28-2014, 05:21 PM   #311
subieshanerz
Thumbs up
Ok cool. Thanks!
Old 12-08-2014, 12:13 AM   #312
Lokenzi
Drives: 2015 Blue.Series.BRZ
Just curious, is it possible to remove these tips? I would like to use the blue series stock ones(tips)
Lokenzi is offline   Reply With Quote
Old 12-08-2014, 12:39 PM   #313
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Lokenzi, the tips are welded on, so you'd have to cut them off if you wanted to replace them. A muffler shop should be able to do that for you.
PERRIN_Chris is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
Old 03-29-2015, 03:58 AM   #314
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
Just an FYI about my install experience. I've always wanted to work on the cat but haven't done anything major in favor of not taking risks with warranty and stuff like that. (I know it doesn't make a difference now, but it was my mindset at the time.) Nonetheless I received my perrin CB yesterday and installed this morning.
This was my first major project on the car and I can say it was easily manageable. The hardest parts were taking off the hangers and the final adjustments. Aside from that it was easy.
As an overall experience, it was fantastic, I loved being able to do the work on my own as it adds to the overall pleasure of having the part in general for me. My car is at about 90K km and although the hangers were a bit stubborn, I managed to get them off on a day where the air temp was close to -15 C.
I used 4 Jack stands and followed a bunch of DIY procedures on this site and had no issue at all getting it done. So basically to those of you on the fence about doing the install, if you have the right hardware, you can do it.
Also incase you haven't heard this before, the system sounds awesome, should go great with my OFH
aghuman is offline   Reply With Quote
The Following User Says Thank You to aghuman For This Useful Post:
MJones_RB (06-08-2015)
Old 07-11-2015, 05:15 PM   #315
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Glad I decided to read through this thread; now I know how to fix the niggling "one tip sticks out farther than the other" issue. :P
Also, based on what I've heard and read, it should be fine--but I'm planning to move to California in a few months, and I want to make sure I won't be going over the exhaust noise level restriction, so I ordered an SPL meter to test it with. It should be here in a day or two. When it gets here, I'll do the test, and post the results.
SilverlightPony is offline   Reply With Quote
Old 07-13-2015, 02:06 AM   #316
SilverlightPony
Tested it today. I was eyeballing the distance and angles based on what I remembered from reading the SAE J1169/J1492 testing specifications, but I think I got it close. I also only ran the test once on the left-hand exhaust outlet, when an actual noise level inspection test would run it at least twice on each outlet, average the results from each outlet, then take the value for whichever side is louder.
The meter recorded 103 dB. :/
Now, there are a couple of factors that may help me out on an actual test. First, again, I was eyeballing it. I may have had the meter too close, or less than 45° off the axis of the exhaust outlet. Second, in addition to this exhaust, I've also got the Perrin 2.5" Cold-Air Intake and the Perrin inlet tube; noise-wise, these mainly affect the sound up front, but getting more, cooler air into the engine can affect the exhaust noise a little. I'd have to swap back to the stock intake to get it registered in California anyway (or switch to another intake I found that has a CARB E.O. approval sticker...but I've already got the stock one, no sense shelling out more money yet) which would hopefully drop the noise a bit. Would it make 8 dB of difference? Dunno, but it might.
Old 01-24-2016, 01:01 PM   #317
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
I must say, that article backed up all the talk about Perrin being one of the best (exhaust) performance options for the brz.
I initially wanted to install the Borla UEL header, then I heard bad things from the product and that you also have to do some tuning. So, I wanted to settle for the Berk muffler delete, which is extremely simple.
However, knowing that the Berk won't give much gains, now all I got on my mind is Perrin, after all the good things I've read up on.
ShadowReaper is offline   Reply With Quote
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
NEW! Perrin SS Catback Exhaust System Up to +9rwhp | In-Stock| FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 31 04-06-2013 09:05 AM
Review of ISIS Street Catback exhaust sirhc Engine, Exhaust, Transmission 24 10-29-2012 04:57 AM
