Old 05-13-2024, 12:34 PM   #309
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Since the first gen and second gen ecu are a bit different how does that affect the performance and tuning ? Sorry if that's a noob question very new to these things lol
I am becoming more and more interested in doing a FA24 swap or maybe FA24 short block with FA20 heads over say a supercharger.
autoracer86 is offline   Reply With Quote
Old 05-13-2024, 01:06 PM   #310
Tatsu333
Drives: 2020 BRZ Sport Tech RS
The FA20 ECU would need to be tuned to run the FA24 properly.
Tatsu333 is offline   Reply With Quote
Old 05-13-2024, 01:12 PM   #311
autoracer86
Drives: Toyota GT86
Yeah I know it needs to be tuned but does the FA20 ecu have all the same tables and what not to run the FA24.
Old 05-13-2024, 05:01 PM   #312
Ultramaroon
not playing cards
Ultramaroon's Avatar
Practically any four cylinder engine can be modded to look like an fa20 for the ecu. It'll work perfectly.
Old 05-13-2024, 05:18 PM   #313
autoracer86
Drives: Toyota GT86
Cool thanks ! I should have a better read over this thread
Old 05-16-2024, 01:00 PM   #314
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
The short answer to this question, as the other guy stated, is that after making the necessary modifications the FA24 will appear no different to the 1st gen ECU compared to an FA20.
The more detailed answer depends on whether we’re talking about a 13-16 or 17-20. Broadly, the only sensor differences between the FA24 and FA20 are:
- Oil temperature
- Coolant temperature
- Evap purge
- Fuel pressure
- Crank position
- Cam position (only for 13-16, 17-20 is same as FA24)
The first four we can solve with connector repins since the sensor has changed, but the data it’s outputting has not. Crank position is also solvable via a connector swap on 17-20 cars, but requires a full custom solution on 13-16 due to the sensor type completely changing, which is what I’m working on. 13-16 also has an inverted camshaft position signal compared to what the FA24 puts out, which is what the metal trigger wheels pictured in my product photo are meant to solve.
removedonut is offline   Reply With Quote
Old 05-16-2024, 03:03 PM   #315
autoracer86
Drives: Toyota GT86
Thanks for the detailed explanation
Old 05-17-2024, 09:13 AM   #316
alphasaur
friendly
Drives: 17' 86
Originally Posted by removedonut View Post
Correct. 2017-2020 is a much cheaper option since we are able to use the FA24 as-is with just 4 adapter harnesses and a fuel pressure sensor swap, since the 17-20 ECU is already set up to accept a hall effect crank signal and shares the same cam reluctor pattern as the FA24.
(also hi. i am the one building those swap kits lol. happy to answer any questions about the swap)
So fa24 is effectively plug and play now?
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 05-17-2024, 11:53 AM   #317
removedonut
For 17-20, yeah. Plug in 4 adapters, replace the FA24 fuel pressure sensor with a 17-20 sensor, and you have a running FA24.
13-16 requires that you pop open the timing cover and replace the trigger wheels on the cam gears which I wouldn’t exactly call plug and play, but as far as engine swaps go it’s ez.
Old 05-17-2024, 12:10 PM   #318
alphasaur
friendly
Drives: 17' 86
time to bump my boost to the moon
Old 05-17-2024, 12:37 PM   #319
jflogerzi
jflogerzi's Avatar
Now we just need more wrecked Gen 2's to make the engines cheaper!
2013 Series 10 FRS #553
Old 05-17-2024, 01:09 PM   #320
alphasaur
friendly
Drives: 17' 86
everytime I see a wrecked gen 2 on reddit
Old 05-18-2024, 12:43 AM   #321
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
You can buy a crate motor. https://parts.bestbuysubaru.com/p/En...0100CE990.html
Drifter X is offline   Reply With Quote
Old 05-18-2024, 12:29 PM   #322
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The crank position sensor and reluctor are different on 17’+ as well. Innie vs. outie like the cam position and I believe the crank position sensor has an extra wire vs. pre 17’ cars.
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 08:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 12:33 AM
