Old 06-02-2011, 11:38 PM   #309
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Originally Posted by blur View Post
Virtually all cars today are boring econoboxes. Doesn't mean that sport cars will become "very rare".
Well said.
We have got the same people arguing about how this cars needs emotion, connectedness, and feel but then at the same time they are looking ahead to autotragic gear boxes.
chulooz is offline   Reply With Quote
Old 06-03-2011, 02:13 AM   #310
Calais
Calais's Avatar
Drives: 2012 BRZ, now track car and GRC dai
Originally Posted by madfast View Post
audi and bmw also use wheel mounted paddles. maybe its a german thing? however the "german" lambos use column mounted paddles...
also the new mclaren mp4-12c is the only exotic off the top of my head that uses wheel mounted paddles vs column mounted. but also remember that they have a new rocker style paddle system where you can both upshift and downshift with the same paddle...
porsche brought that in at the end of last year: pull back to shift up and push forwardto shift down
Calais is offline   Reply With Quote
Old 06-03-2011, 02:34 AM   #311
madfast
Drives: 2010 Evo X MR-T
Originally Posted by celicajim View Post
Circuit Driving Instructors usually tell you to keep your hands on the wheel for maximum feel of where and what the front wheels are doing, so with that in mind you want the paddles to be on the wheel so you don't have to lift a hand off the wheel.
yes, however not all cars allow you to do this. cars with super quick steering ratios will allow you to do this, you may not need to turn the wheel much on a track. even on hairpins, you can probably get away with crossing your arms or slightly shuffle them.
but on other cars with slow steering, and 3+ turns lock-to-lock you simply have to turn the wheel more, and thats where you have to shuffle your hands. in this scenario, wheel mounted paddles are a stupid idea simply because their relative positions change with the wheel... if the car is a sportscar and you never have to move your hands, sure wheel mounted works best, but not all cars are like that...
ferrari and most exotics use column mounted paddles. i'd follow their lead...
madfast is offline   Reply With Quote
Old 06-03-2011, 04:19 AM   #312
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by Ryephile View Post
Here's my take: Your hands are on the wheel, not on the column, so I don't see why you would you want the paddles where your hands aren't.
Where are the paddles on a Formula1 steering wheel? Case closed!
F1 drivers almost never turn the steering wheel more than a quarter turn nor do they ever take their hands of the wheel (I'm guessing) so paddles fixed to the steering wheel works fine.
But on street-driven cars, as you lift your hands off the steering wheel hand-over-hand to make a turn, you'll be fumbling for the downshift paddle wishing it were fixed to the column.
Old 06-03-2011, 05:05 AM   #313
Dark
Elite Padawan
Dark's Avatar
this guy knows what I was talking about. paddle shifter on steering wheel is uncomfortable for a street car.
Dark is offline   Reply With Quote
Old 06-03-2011, 08:53 AM   #314
bofa
Drives: Ms. Daisy
How much shifting are you doing during half steering wheel (or more) turns? I guess I'm used to shifting as I enter the turns and as maybe I exit depending on the where I'm at in the power band.
BRZ before hoes
bofa is offline   Reply With Quote
Old 06-03-2011, 10:21 AM   #315
PAImportTuner
Turbo Mafia Presidente
PAImportTuner's Avatar
Drives: U Mad?
Something ya'll are forgetting is. Street cars with paddle shifters STILL have the center console shifter. They are not full paddle setup, you can still use either one.
If you track and autocross like me, you'll understand it does not matter if they put it on the steering column or wheel. You do your shifting before diving in and during exiting tight corners, long sweepers will still allow you to shift regardless of location. And you can always get paddle extenders.
"the FR-S is going to have to give me a blowjob every time I touch the steering wheel if all it can make me smile with is the handling." - Maxim
PAImportTuner is offline   Reply With Quote
Old 06-03-2011, 10:59 AM   #316
iff2mastamatt
Feeling Iffy?
iff2mastamatt's Avatar
Drives: it like I stole it
I can't really tell which brand those seats are, but they look too low to be comfortable.
iff2mastamatt is offline   Reply With Quote
Old 06-03-2011, 12:43 PM   #317
madfast
if you're going to use the console shifter exclusively, then why even have paddles? the point of the discussion is which paddle mount position is better. obviously you can still shift with the console shifter...
which brings me to my next point. most console shifters have their up/downshift positions reversed! it should be pull back to upshift, and push forward to downshift. that's how its done on a true sequential gearbox and that's how all console shifts should be. the push forward upshift that most cars have is based off of the old PRNDL or PRND321 sequence found in automatics, not based off of true sequential gearboxes.
off the top of my head, only suzuki, mazda, bmw, and mitsubishi's SST use the pull back upshift configuration...
Old 06-03-2011, 12:48 PM   #318
madfast
i'll give an example of why i like column mounted paddles.
im at a red light and have to make a turn once it goes green. im in manual mode. light turns green. i make the tight turn. now here's where i love my column mounted paddles. i can short shift mid turn or close to the end of it and keep the engine from revving too high, both saving fuel and not looking like an idiotic street racing ricer revving to 5k rpm on a low speed turn... since its a low speed tight turn, there is no way i can keep my hands on the wheel. i have to shuffle them. if the paddles were wheel mounted, i'd have no clue where they were while turning. i'd have to shift super early or let the engine rev and shift later. obviously not a huge problem, but every time this happens, im reminded about how much better column mounted paddles are than wheel mounted...
Old 06-03-2011, 01:05 PM   #319
Sabastian
will rain on your parade.
Drives: 2007 Mini Cooper, 1996 Mazda MX-5
Well said, sir. I had that exact problem the first time I drove a GTI with DSG. It wasn't the end of the world, but it was kind of annoying. To add to your point, column-mounted paddles can also be bigger since they aren't swinging around with the wheel.
Example:
vs.
All that said, a true manual solves the problem completely.
Sabastian is offline   Reply With Quote
Old 06-03-2011, 01:15 PM   #320
madfast
porsche's paddles are both wheel mounted and huge:
https://porschebahn.wordpress.com/20...addle-shifter/
i actually think they made them that way to LOOK like its column mounted a la ferrari/lambo... food for thought...
Old 06-03-2011, 03:16 PM   #321
Dark
Elite Padawan
Dark's Avatar
What I don't like about wheel mounted paddle is, when I steering to much, I'm confused which is the up and down shifter. Sometimes you have to shift when you turn, not only when steering is on the neutral position.
Like madfast said, you will look like an idiot revving 5K on the street.
Old 06-03-2011, 03:59 PM   #322
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Here's better way to save fuel and don't look like an idiotic street racing ricer, use keep it automatic instead of using the paddle. Was that hard to do?
North America to get Subaru version but not Toyota version? Ground N Pound BRZ First-Gen (2012+) — General Topics 42 05-29-2014 12:23 AM
Inside Line's Predictions (Subie Version) GT Engine, Exhaust, Transmission 13 05-23-2014 09:32 AM
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 10:27 PM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 09:22 AM
