#3179 |
Drives: 2012 gt86 Cosworth charged
#3180 |
Any input from RCE and CSG on the Ohlins R&T vs Monosport welcome
#3181 | |
I really liked the "old" Ohlins...we ran them on our own shop car for a while. I'll admit I have not tried the newer soft version but the spring rates are a disappointing especially with the limited bump travel they have. Yes you can get a car to handle well with soft springs, but those are reeeally soft. For a car on low grip tires they might make sense but if you've switched to even a decent summer tire, I would not prefer rates that soft. I would also consider Bilstein PSS10 if you're set on coilovers. Bilstein B6 + a good spring with a mild drop might be the easy ticket as well. I'm not sure what kind of springs you can get over there. - Andrew |
#3182 | |
That's a very simplistic way to look at it...but still useful. A larger front bar will especially help those that don't (or can't) run a lot of camber and/or run softer main springs. The faster response also "feels" good and most driver's are a little more confident when they don't have to wait as long for the front to settle into a corner. That's sometimes taken too far when people jack up the spring rates or bar sizes to the point where they're overloading their tires... It's also important to think about the phases of a turn and the balance of the car throughout the corner. You can improve handling on entry at the expense of corner-exit (or vice versa). Sometimes that means your faster overall, sometimes not. But I've driven plenty of poorly set up cars that both understeer and oversteer. Don't let that happen. ![]() - Andrew |
#3183 | |
Drives: 2013 Subaru BRZ
Were it not for rough roads the simplest solution to excessive body roll would be shorter and stiffer springs. Reduced camber change and more active weight transfer in one convenient step, until you hit the bump stops in mid corner and scare the bejeezus out of yourself. A stiffer front bar actually transfers weight transfer from the diagonally opposite corner I.e. Stiffer front bar moves weight transfer effects away from the inside tire on the rear axle and onto the outside front tire. It does this by increasing the spring rates at the front of the car, under compression the outside lever arm of the bar gets pushed upwards and the inside lever arm also gets pushed upwards. You can see that this effectively transfers some of the spring rate from the inside spring to the outside spring, in proportion to the spring rate of the bar, ie the twist rate. Since the bar is trying to lift the inside spring eventually, with a stiff enough bar the inside wheel lifts off the road entirely. Similar process occurs when you increase the bar rate, even box stock VW golfs lifted a rear wheel right from the original economy car release. They used a twist beam rear axle as the rear roll bar and it was quite stiff in roll. Roll bars "unlock more grip" to paraphrase Whiteline's excellent promo tagline. But, and it is an important but, they do not create grip that the chassis doesn't already have. By reducing the range of suspension travel and confining it to a narrower window, and by increasing the rate at which the outside tire gains load the right bar can unlock grip that was inaccessible due to body roll. Too much bar is worse than not enough. Part of the gain available from a stiffer bar can be had "for free" by cranking in more static negative camber to begin with. McPherson struts particularly benefit from this, to a point. Finally, note that Porsche makes its McPherson strut work so well by reducing suspension travel and fitting hefty roll bars. The ride penalty is severe compared to the BRZ stock setup. |
#3184 | |
Drives: '15 BRZ RA
#3185 | |
Ohlins are certainly on the list and im hoping to get some feedback from my contact there as too both the reasoning for the revised spring rates and also if the damper will take the old/higher rate without a revalve etc. Bilstein PSS10 are also a consideration as well and hoping for a ride in a car with those also, have you found the ride good on those ? I considered Koni dampers and some springs like yours but i think im going to stick with coilovers to fine tune things more if i can. Ian |
#3186 | |
- Andrew |
#3187 | |
Ohlins isn't providing crap, their setup just isn't for competitive driving, which is probably a better strategy for them, it's easy to forget most people don't drive this car hard at all. There's a reason SCCA classes the stock FR-S differently than one with TRD lowering springs, the body control is a noticeable benefit that can't be mitigated with dampers which are practically open under the street class rules. |
#3188 | |
I think there was a shift in focus but that shift was to move things closer to the "road" part of the spectrum rather than the "track" part of the spectrum in the Ohlins R&T name. Nothing wrong with that, just IMO they might have moved a little too far to the R. EDIT: and this is a good discussion! I do in general prefer a somewhat softer set-up than others. Dampers can be tuned in such a way to work with that, and it can be awesome for a fast and fun street car. And bonus, it's usually a little easier to drive quickly. But with stickier tires you will have some compromises and firmer springs will be faster. - Andrew |
#3189 | |
Drives: 2013 Firestorm FR-S
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#3190 | |
- Andrew |
#3191 |
Anti stance.
#3192 |
OH Shit, you just found Mclaren's problems!
![]() In theory, you're right, in practice no car goes around a corner with all four tires equally loaded, it's nigh on impossible, many fast cars lift an inside tire, there is often little benefit keeping that tire on the ground mid-corner. Rather it's better to have suspension compliance to maximize grip on the important tires in the important phases of the corner. A suspension stiff enough to keep all four tires on the ground in the hardest corner is likely to get upset by pavement irregularities and lose more time over a circuit than than a softer setup that lifts a wheel. The Civic is on display here, but note the RX-7's actually lift their front wheels off the ground on corner exit as well. [ame="https://www.youtube.com/watch?v=I9bQ1UGLLLg"]Honda Civic Vs Mazda RX8 13BPP - YouTube[/ame] |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
