Old 03-19-2017, 01:19 AM   #3095
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
So right now in my cart on ft86speed factory I have bilstien b8 full set, rce tarmac springs, whiteline front camber bolts and whiteline lcas for about the same price as greddyxkw coilovers. Between the two which is a better option. I'm running 17x9 +35 wheels with a 255/40/17 tire. The wheels and tires poke out a little and I want to correct that with adjusting the camber I guess? Also get rid of some wheel gap and not ruin the handling.
rcm47 is offline   Reply With Quote
Old 03-19-2017, 09:41 AM   #3096
Pat
Pat's Avatar
Drives: 2023 BRZ
If you want to get rid of tire poke address the root cause: Get narrower tires.
The Following User Says Thank You to Pat For This Useful Post:
Rougenite (03-20-2017)
Old 03-19-2017, 11:07 AM   #3097
rcm47
rcm47's Avatar
Thanks, but that doesn't get rid of wheel gap.
The Following User Says Thank You to rcm47 For This Useful Post:
Pat (03-19-2017)
Old 03-20-2017, 10:18 AM   #3098
Racecomp Engineering
Originally Posted by Insurme1 View Post
Guys I have a question regarding springs. I'm currently running KW V3's with the 200lbs springs that came on them. I'm now looking for more stiffness and flatter in the turns. Running -3.0/-2.0 camber. Do you have any experience going to a heavier spring with KW's? If so can either of you help me out on recommendation and/or sell me some? Car is for HPDE only. Thanks!
We can help, send me a PM. Got some KW springs in stock and can get Swift/Hyperco as well.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Insurme1 (03-23-2017)
Old 03-20-2017, 10:18 AM   #3099
A little camber will reduce that poke and help the car handle better.
What are your plans for the car? Any auto-x or track days or just back roads fun times?
- Andrew
rcm47 (03-20-2017)
Old 03-20-2017, 01:04 PM   #3100
rcm47
rcm47's Avatar
- Andrew
A lot of my daily drive consist of twisty back roads and I would like to try auto-x and tracking in the future. I think your GTworx/bilstein coilovers will be perfect for me.
Racecomp Engineering (03-20-2017)
Old 03-23-2017, 01:13 PM   #3101
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
@Racecomp Engineering -- Driving on canyon/backroads where I am running into mid-corner bumps, I feel like the rear of the car gets unsettled and I can feel the TCS wanting to kick in. It does not feel like the rear is bottoming out at all.
What can I try to do to alleviate some of this? Should I dial in a little more camber in the rear? Change damper setting ratio front to rear? Driver mod? Other suggestions?
Current setup:
  • Ohlins with a rear LCA that lowers the damper mounting point so the ride height setting is not set very low and and the pre-load is set exactly as described as per Ohlins instructions.
  • Damper settings 10/20 in front, 13-14/20 in rear (rear slightly softer)
  • Alignment settings are -2.3 front camber, -1.8 rear camber; 0toe front, .08 rear
  • 245/40/17 MPSS
  • No other suspension modifications.
Thanks!
asdf is offline   Reply With Quote
The Following User Says Thank You to asdf For This Useful Post:
Clipdat (03-23-2017)
Old 03-23-2017, 02:41 PM   #3102
Current setup:
  • 245/40/17 MPSS
Thanks!
Quick easy thing to try is to soften the rear a few clicks and see if it gets better. Unfortunately Ohlins don't have a lot of bump or droop travel so that could still be a problem on large bumps even if not set very low.
- Andrew
asdf (03-24-2017)
Old 03-23-2017, 03:29 PM   #3103
driggity
Drives: Silver Coupe with a Boxer
Current setup:
  • 245/40/17 MPSS
Thanks!
- Andrew
What are some good modifications for this type of driving/roads in general? I have similar issues but my car is stock other than wheels/tires (225/45 17 Firestone Indy 500s), rear subframe bushings, and front camber bolts.
My main complaints are wishing the car was more controlled in transitions and that the rear end gets unsettled mid-corner and corner exit as described by @asdf . And my normal driving is commuting ~60 miles round trip mostly on interstates with poor pavement quality so maintaining ride quality is important.
driggity is offline   Reply With Quote
The Following User Says Thank You to driggity For This Useful Post:
Old 03-23-2017, 04:51 PM   #3104
Cybmx
Drives: 2016 Hyperblue Brz
Just noticed that one of my locking bolt on my RCE t2's ride height adjuster is stripped. Any suggestions on how to fix it? Also just noticed that the adjuster is made out of plastic...
Cybmx is offline   Reply With Quote
Old 03-23-2017, 04:53 PM   #3105
Give us a call and we can send you a replacement. It happens rarely when it's overtightened. The perch is made of a composite so that it doesn't rust and get stuck like so many other coilovers.
- Andrew
Cybmx (03-23-2017)
Old 03-23-2017, 04:55 PM   #3106
The key is good quality dampers with adequate travel. Coilovers with excessive rebound will make things uncomfortable and reduce grip on bumpy roads. Stock the rear is a little travel challenged which doesn't help either.
- Andrew
driggity (03-25-2017)
Old 03-24-2017, 11:45 AM   #3107
driggity
- Andrew
That's what I figured it boiled down to. Is this a place where progressive springs can be advantageous for some extra compliance or does it still just come back to dampers that are well controlled and have a good amount of travel? Is this a situation where stiffer springs and a softer roll bar in the rear would make sense?
Are there any other items that can help improve compliance in the rear? Are there any bushings that bind up under these conditions?
In general I'm happy with the suspensions performance and for now it's a street only car. I'm trying to figure out how far down the suspension rabbit hole it makes sense to go.
Thanks
Old 03-24-2017, 12:51 PM   #3108
churchx
churchx's Avatar
Drives: 2014 GT86
Compliance / NVH in rear .. maybe try smaller diameter wheels with tires appropriately higher sidewall profile .. and maybe a bit less air pressure. Sidewall flex will increase, adding comfort/soaking some road imperfections, but of course it will be accompanied with less sharp steering & a bit more roll.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
