| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,101 | 85.22% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.78% |
| Voters: 3639. You may not vote on this poll | |||
#295 |
Drives: Skoda Yeti DSG diesel 4x4
#296 |
Drives: 2013 BRZ, 2002 WRX
I'm using the Lucas Oil variety because it's low-ash and smokeless. It's used in racing snowmobiles and the like.
Link: Lucas Oil 2-Cycle Oil I did get away with using 50ml (less than 2oz) of this as a fuel additive. That's nearly 1:1000 ratio to fuel. |
#297 | |
#298 |
give us this day
Drives: AE86 - FRS
how about toyota/subaru changing the hpfp to fix this issue..?
#299 | |
The Lucas oil sounds alright. Not sure what the air cooled spec means? I couldn't find the Valvoline racing oil we have here but the outboard version sounds ok. Premium base stocks are blended with a modern ashless detergent additive package to provide fortification for maximum performance in outboard engines. http://www.valvoline.com/products/co...-engine-oil/16 |
#300 |
give us this day
Drives: AE86 - FRS
like i mentioned cant royota/subaru just replace the hpfp?
#301 |
Spaceman
Drives: 2013 Firestorm Scion FR-S
That would prove expensive for all the vehicles shipped to the US by Toyota and Subaru.
My guess is that they are going to look for more of a precise, less costly fix first. I'm okay with that as long as it gets fixed.
#302 | |
Drives: Fast
Otherwise just get the pre-mix oil that Rotory heads use http://shop.pettitracing.com/fluids/...e/c-10262.aspx
| The Following User Says Thank You to Razz For This Useful Post: | cobrabyte (07-13-2012) |
#303 |
give us this day
Drives: AE86 - FRS
i think it should be really address now.. And they should act fast before they sell more of these cars with this problem.. im thinking toyota will find a solution and hopefully we can just get it fix as part of the warranty..
#304 |
#305 |
Drives: 2008 STi
#306 | |
I did the math and it looks like it'll only cost $0.65ish per fill-up if you purchase the 1 gallon container. It's a hassle and I gotta believe the guys at Toyota are going to address this with a warranty recall but, in the mean time... |
#307 | |
You said "Something came to mind when ethanol popped up and maybe the HPFP is causing the ethanol to draw in moisture in to the HPFP as it compresses the fuel and washing the lubrication from the fueling system. It may mean the use of a fuel stabilizer to keep the moister down and all parts well lubricated. It will only get worse when they up the ethanol to 15%." I pointed out the same process would then wash the extra 2T lubrication from the fuelling system as was the case with the lubrication in the fuel in the first place. Unless the extra lubrication is enough to overwhelm that process? |
#308 | |
Drives: 2008 STi
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 02:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 11:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) — General Topics | 49 | 07-02-2012 04:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
