#295 | |
Drives: 13 GBS BRZ
#296 |
Drives: 2013 FR-S, 18 Colorado ZR2
Best lurker checking in, I'm very interested in this kit. Here's a good install video i found this evening made by a vendor on here, i don't know how to alert them to see this post. @titanmotorsports
[ame="https://www.youtube.com/watch?v=Vk4pFiWOMPQ"]Edelbrock E-Force Supercharger FRS / BRZ Install - YouTube[/ame] |
The Following 8 Users Say Thank You to sumgai For This Useful Post: | BigFatFlip (11-06-2015), itsibarra (11-09-2015), j123ic (11-07-2015), new2subaru (11-07-2015), Shankenstein (11-06-2015), shiumai (11-06-2015), Yoda (11-07-2015), zigzagz94 (11-06-2015) |
#297 | |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
It gets hot in SA, and I want a reliable SC (+tune). Does it mean sacrificing a few hp? |
#298 | |
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
Sent from my XT1575 using Tapatalk |
#299 | |
It's also a case of availability here... We don't get e15/85 at the pumps, so I'd need to make another plan. I'm wondering if a simple octane booster is an option!? |
#300 |
Drives: Scion FR-S (Hot Lava)
Oil Cooler Update
As some of you who have been following this thread have known, folks with the Jackson Racing oil cooler (NA Version) are required to relocate the the heat exchanger. The JR oil cooler original position is in the same area that the Edelbrock Low Temp Radiator (LTR) will reside. Reference Post
Initially, the natural idea was to relocate the cooler forward and below the crash beam to make room for the LTR. Reference Post Although this method is not completely unorthodox, the obstruction the oil cooler has become for the Edelbrock LTR is more substantial than expected. In cruising conditions, I was logging almost 40°F higher Intake Air Temperature (IAT) than ambient. Highest peak IAT during autocrossing in 82°F ambient was 153°F. This was costing me ignition timing and ultimately power. Looking for yet another alternative location for the oil cooler I noticed that there is a decent amount of flat real estate just in front of all of the other heat exchangers. In my line of work, I've seen heat exchangers mounted flat in the past. I was thinking that there should be a pressure differential between the front opening of the bumper and the high speed air flowing beneath the front of the car, it seemed reasonable the oil cooler could operate laying flat. Drop down brackets from the crash beam to the oil cooler. ![]() ![]() ![]() ![]() ![]() I may make a mesh grill to protect the cooler and I still need to create a better seal around the opening and the oil cooler, but so far I have seen a noticeable improvement. I've observed a drop in cruising IAT temps of 11-20°F! I still need to log more and see what my temps peak at during autocross or canyon driving but the change has shown promise. In addition, oil temps have only displayed about a 6°F increase. Again, I still have more data to gather, but I'm convinced that you do not want to obstruct the Edelbrock LTR if you care about IAT's. -Aaron |
The Following 13 Users Say Thank You to Nitro22 For This Useful Post: | BigFatFlip (11-10-2015), Cesium Rainbow (01-16-2019), clayrush (11-10-2015), CxG (11-10-2015), EJ. (02-22-2016), Fever (11-10-2015), Freeman (11-10-2015), j123ic (11-11-2015), MaximeT (11-10-2015), NotSoJDM (11-10-2015), sato (11-10-2015), Summerwolf (11-10-2015), Trefoil (01-30-2016) |
#301 | |
Drives: '13 BRZ | '04 E55
#302 | |
Yes, there is definitely a added risk of damage. I'm possibly looking into adding a mesh grill to give some protection. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Nitro22 For This Useful Post: | NotSoJDM (11-10-2015) |
#303 |
Drives: Dodge Patitas
Also had a problem with a piece of a semi truck tire... Very damaging to my car. Try to have the strongest protection you can think of
Sent using Tapatalk |
#304 |
Let us know what you decide to do for protection in that area. It is a really great idea, especially in terms of space savings. I just really worry about hanging something as critical as my oil supply in a spot that susceptible to impact. Having a nice robust solution in that area would be awesome.
The Following User Says Thank You to NotSoJDM For This Useful Post: | Nitro22 (11-10-2015) |
#305 | |
Oh btw, I just found this online. It is a trans cooler on the 2016 Camaro. Not as critical as oil, but nice to know the idea isn't too far fetched. ![]() Thanks, -Aaron |
The Following 4 Users Say Thank You to Nitro22 For This Useful Post: |
#306 |
Panda Trueno
Drives: No twin now.
There was a product for corvettes that had a little scoop on the skidplate. It directed air at the intake. Maybe not so dramatic, but something like that could help cooling and maybe provide a little protection.
The Following User Says Thank You to Summerwolf For This Useful Post: | NotSoJDM (11-10-2015) |
#307 | |
Drives: GT86 Cosworth
Problem you might have is that some air is being pushed down and out, rather than through the intercooler/Water/AC radiators.... |
#308 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
This is exactly what I was about to suggest for a cover except facing backwards since the air will be flowing into the front, down and out.
The Following User Says Thank You to BigFatFlip For This Useful Post: | sato (11-10-2015) |
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
