02-25-2018, 10:12 AM | #295 |
Drives: Black 2015 Subaru BRZ, BlackDiamond
Just installed mine after having invidia catless fp and N1, put stock fp and cbe on, then gruppe-s op and headers. Also getting the rattly/hissing noise near the connection of the header and op. almost louder than the exhaust itself sometimes
02-25-2018, 10:44 AM | #296 |
Drives: frs
Chek for leaks, put soapy water in spray bottle and spray a little while engine running where leaks are suspected
02-25-2018, 02:27 PM | #297 | |
Drives: 2015 Subaru BRZ Series.blue
Sent from my SM-G950U using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
02-25-2018, 05:39 PM | #298 |
So that is what it would sound like? I tightened it as much as I could im pretty sure. I also used washers that came with it, maybe I'll take those out.
02-25-2018, 05:40 PM | #299 |
02-25-2018, 05:43 PM | #300 | |
I've had it 2 years, added 2 different fp/op setups, 2 exhausts, and installed a turbo and no headers sound that I've noticed besides that sexy subie rumble. Sent from my SM-G950U using Tapatalk
02-25-2018, 07:30 PM | #301 |
I really wonder if it's the hardware they sent like the gaskets. Where'd you get your gaskets from? Also should I use oem nuts and bolts?
02-25-2018, 10:56 PM | #302 |
I think i'm experiencing the same thing from the same area. This whole time I was thinking it was my front pipe since its my last stock exhaust piece, but I guess i'll go check that area. I checked for a leak and I don't think that's it. that raspiness/rattle only happens at cold start and sometimes when accelerating.
02-26-2018, 01:07 AM | #303 | |
02-26-2018, 07:28 AM | #304 | |
02-26-2018, 08:11 AM | #305 |
02-27-2018, 05:55 PM | #306 |
Update: I fixed it. It was just a leak because I didn't tighten the inside bolts well enough, and eventually one came off making it worse. Tightened with a crow's foot and extension socket bought at pepboys. Will be going to a friend of mines shop to make sure they're as tight as the others . IF ANYONE HAS THE FLUTTERING NOISE MAKE SURE THOSE BOLTS ARE TIGHT!
12-27-2020, 06:33 PM | #307 |
Drives: 17 Asphalt 86
Installed mine a few weeks ago. Initially I flashed OFT stg 2+ tune which I used for 600km or so. Then I got a custom tune done by Tomm.brz,[Thanks again]. The car feels noticeably quicker from 2000-5000rpm, and pulls strong to redline.
Video of cold start sitting overnight A few revs with the car warmed up Last edited by RToyo86; 12-27-2020 at 08:10 PM. |
02-22-2022, 02:46 PM | #308 |
Drives: 2013 BRZ Limited
Sorry if bumping this thread is a problem. I bought a new to me 2013 BRZ back in Dec. It had a way too loud TRD cat back which I have replaced with a stock system. According to the build/parts list from the ad, it has this header and a Berk catted front pipe. The gasket at the header to over pipe is blown out. What size do I need? Is a stock gasket to small? Or does it need to be bigger? I haven't been able to find much info so far.
Thanks
2013 BRZ Limited
Tags |
gruppe, gruppes, header, uel, unequal length |
Similar Threads | ||||
DIY X REVIEW: CNT UEL HEADER INSTALL | adamg | Engine, Exhaust, Transmission | 73 | 07-27-2023 09:58 AM |
P&L Header install, review and impressions | D K | Engine, Exhaust, Transmission | 54 | 05-30-2019 12:35 AM |
Top Speed EL Header Review, Install, and Pictures | tomaszjanczak | Engine, Exhaust, Transmission | 0 | 10-11-2014 07:27 PM |
Vortech Offical Owner Thread | cjsporl1996 | Forced Induction | 2 | 03-27-2014 12:50 AM |
**Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
