10-06-2015, 11:11 AM | #295 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | bfrank1972 (10-06-2015) |
10-06-2015, 12:03 PM | #296 |
Drives: '13 10 Series FRS #1203
Actually happened to me the other day. I say goodbye to everyone, i pop my hood and my trunk and everyeone was looking at me like I was crazy adjusting them
The Following User Says Thank You to Shady195 For This Useful Post: | CSG Mike (10-06-2015) |
10-06-2015, 06:33 PM | #297 |
Drives: Silver FRS
Which edfc motor kit part numbers fit our cars or are all those pn included in the kit as a generic fit everything kit?
10-07-2015, 07:39 AM | #298 | |
I have a slight "clunk" and im trying to track it down. Not sure if its the suspension or something else but I can't seem to find what it is. I re-torqued all the other suspension bits. |
10-07-2015, 08:19 AM | #299 | |
Drives: BRZ Club blanc perle
See : http://www.tein.com/srch/edfc_us_ref...S4&ktk=0&sld=1
Collecteur et frontpipe Supersprint full décat - Catback Remus Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons |
10-07-2015, 01:35 PM | #300 | |
10-11-2015, 04:32 AM | #301 | ||
Drives: GT86
Frankly, I am a bit surprised I'm in the Flex Z thread and not the Flex A thread (here: http://www.ft86club.com/forums/showt...t=89113&page=2), even if rates and bump stroke are the same, the Hydraulic Bump Stop is what sparked my interest formost. (We can continue here or you can just quote this in the Flex A thread). Either way, my concern has also been, will I be disappointed with bump travel and will I be riding that (hydraulic) bump stop all the time? Without preload, the corner weight of 370kg, 6kg springs, I get a bump travel at the front shock of (93 - (370/6))mm = 31mm. A bump stop still has to fit in those 30+mm, so bump stop free bump travel is very little. This also means that rebound travel 62mm with complete unloading (no preload). The question now is, how much preload can you add before the car becomes unruly because there is too little extension and wheels loose contact with the ground before fully unloading the suspension? What does the installation manual state? If one can add 10mm preload, 41mm bump travel might just do it for me in combination with the hydraulic bump stop. By the way @Mars2, if ground clearance itself is a problem, why don't you just run you Flex Z higher up by extending the length of the body? And if there is a preload setting in the manual, also run them at max suggested preload (please let me know if you have figures on this). These measures should really improve things a lot, even if limited bump travel, you can increase ground clearance nevertheless! If I get Flex A, that is what I will do, run them at perhaps -10mm from stock to start... IF.... |
10-13-2015, 05:08 AM | #302 | |
Drives: WRX 2015 Subaru BRZ
Would it be a good idea to totally disassemble the driver side coilover and check whether the pillow ball nut and bearings are aligned and not buggered? I figure when the shock arrives I will have to do this anyway. |
10-13-2015, 12:18 PM | #303 | |
10-14-2015, 11:06 AM | #304 |
Having a bit of an issue hoping maybe someone can help with..
I've developed a slight "clunk" tends to happen on smaller bumps when the car is rocking a bit.. I checked the torque on the tophat nuts, Lower contral arms, sway bar endlinks, the front tophats and knuckles, all seems well... I saw someone mentioned earlier that the nut on the tophatt that connects to the shock comes loose.. How do I check the torque on that without spinning or putting leverage on the shock? The stock sturts have a cutout so you can use an allen key to hold it... what about these? I put a little pressure on them and it appears it just flexes the bushing. |
10-14-2015, 03:44 PM | #305 |
Drives: 2013 Scion FRS
Have this kit for a few days now and couldn't be happier with it. At its price point, it is an awesome kit for a daily driven car in my opinion. Significant improvement in ride and handling is easily noticeable. I think maybe even the steering got lighter. Even my wife felt the improvements and was happy with it.
Currently running with the recommended settings (7/8 clicks fr/bk) and it is practical for my daily route, comfortable but still responsive. I have also tried 5 clicks from stiff all 4 and I think it is a good balanced setting, will definitely feel road imperfections more but still comfortable enough. I'll definitely be playing with different settings soon. I'll never forget to thank the people at @CounterSpace Garage for hooking me up with a kit and answering my noob questions! THANK YOU CSG! |
The Following 2 Users Say Thank You to buruguduy For This Useful Post: | Bramick (10-14-2015), Trettiosjuan (10-15-2015) |
10-14-2015, 10:40 PM | #306 | |
Brown rice
Drives: 93' Supra TT, 13' FRS
10-15-2015, 09:00 AM | #307 |
10-17-2015, 01:19 AM | #308 |
Drives: 2013 BRZ Limited M/T
I get this too.
Similar Threads | ||||
Tein Flex A and Z!!! | breadcrumbz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 05-24-2016 03:44 PM |
Tein Flex Z | Bigmaxy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-27-2015 03:22 AM |
WTB - Tein Street Flex and some LCA's | Sugi | Want-To-Buy Requests | 1 | 01-25-2015 03:12 PM |
25% Off Tein Street Flex's!!! | RallySport Direct | Brakes, Suspension, Chassis | 0 | 12-31-2014 04:52 PM |
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 01:10 PM |
