#295 |
Señor Member
I know it is somewhere in this thread but my search fu is weak today. Can some one link me to where air intake temp is related to knock? On the stock tune with the same tank of fuel I saw my aim go from .35 with intake temps of ~110f one day to .85 the next with intake temps ~65f.
1974 TA22 Celica
2013 86 GT |
#296 | |
Drives: UK GT86
Are you using my spreadsheet or the one in @vgi's utility? Either way, you want to look at your logs and determine the lowest MAFv which will pretty much be at lowest idle and max MAFv will be at maximum RPM. Always allow for a margin of error at the top end. I think for NA you'll need no more than 4.25-4.35v
.: Stealth 86 :.
#297 | |
two table work togeather IAT COMPENSATION and IAT ACTIVATION |
#298 |
Drives: UK GT86
@steve99 I've had a look through my logs after re-reading the post about PEKC. I can see nothing to suggest that the ECU is retarding a different value to the FBKC values set, which is what the guys on Romraider were seeing. I have a few logs where the FBKC retard value are set to -0.7 and -1.05 and at no point does the retard value change from that.
Maybe setting the FBKC to retard a daft value like -2 degrees and then if it retards less then you know we have the PEKC tables, however I believe that the transient retard tables are there to overcome the issue that was there on the older ECUs.
.: Stealth 86 :.
#299 | |
what got me curious was a -2 flkc correction in one of my logs. just one -2 only for one tenth of a second fbkc. usually you get a few hits in the log at 10hz refresh and the max i got anywhere else was 0.6 . was probabably a logging glitch. |
#300 |
Drives: 2015 Scion FR-S
I have some weirdness sinced the update to start doing data logging after my MAF Voltage issue was fixed by Shiv. My IAM yesterday was stuck at 1 with no movement; it doesn't matter what RPM or going WOT. This morning it was at .88 for the first time, which is weird. But, it doesn't move at all. Is that normal to see this kind of reading? Also, my Knock Correction is stuck at 0 degrees with no movement. I'm wondering if anyone has this kind of experience logging. Thanks
#301 | |
Drives: SWP BRZ
try different fuel and see it goes back to 1 |
#302 |
I had mine just stuck at 1 yesterday and this morning when I start the car at .88 without moving. This is the first time I've seen my IAM move after numerous cycles. Does it constantly changes or remains steady? The knock correction is always at 0.00 degrees without moving. I'm trying to make sure my tablet is reading correctly without addressing any more issues to Shiv.
#303 | |
Drives: SWP BRZ
#304 |
I appreciate for ensuring this. That .88 I'm guessing is because I have a low fuel tank. I use Shell 93OCT, which seems to be the optimal choice for reducing cricket noise and the rough idles for our cars. I haven't done much experience with Exxon or Sunoco yet. I'm avoiding BP because I always get the crickets from them and the rough idles.
#305 | |
Drives: SWP BRZ
#306 |
This morning on a cold start it was at .88 degrees. When I started driving, my IAM climb back up to 1, and it never once drop. So since the update from OpenFlash, my tablet is reading correctly with no more issues with CAL ID D00D. Appreciate for helping me out.
#307 |
Drives: 2013 "Hot Lava"
@steve99, in the section where you mention the need to pull timing if FLKC exceeds -0.7, is that true for both under load and not, whether or not FBKC stays flat? So, for instance, pulling to ~7200 RPM, all is well, throttle is lifted and engine load drops, RPM immediately starts to fall and it's in this immediate area that FLKC pulls down, though without any FBKC pull.
I guess this is the opposite of "tip in" where I've read you say several times a little knock is unavoidable, but "tip out"(?), right after getting off throttle at high RPM, is this also normal or something that might need attention?
2013 Hot Lava FRS :: OFT Stage 2+ :: JDL UEL Catless :: JDL Over-Frontpipe :: GReddy Evolution RS Catback :: Enkei "Tarmac Black" RPF1 :: Tein Flex-Z Coilovers :: 245/35r18 Conti DW :: RS*R R-LCA :: Racer-X Fab R-Toe Arms :: Mishimoto Intake Tube :: Mishimoto Oil Catch Can :: JDL FSTB :: Raceseng "Slammer" + RLO :: Diode Dynamics HID + Tail-as-Turn + DRL :: 5:AD Spoiler ::
#308 | |
if the knock is less than -1 its likely fine, but their is a delay between when knock occurs and when it shows up in logs so sometimes you have to pull a bit of timing in the previous cells. ie tat knock your seeing may have actully occurred under load if its imediatly after throttle lift off. but that is also what the transient retard tables do, howeverthey may not be defined in defs for your rom not sure |
| Knock Correction vs Knock Correction Learn values? | swift996 | Software Tuning | 19 | 11-03-2015 10:09 PM |
| Dynosty Fuel System Upgrades- Billet Fuel Rails!!! | Dustin@Dynosty | Forced Induction | 4 | 10-08-2014 10:00 AM |
| FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. | MmmDieselFumes | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 02-02-2014 08:19 PM |
| Fuel gauge misreading actual fuel in tank. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-09-2013 03:39 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
