Old 10-11-2013, 05:06 PM   #295
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Just loaded the 1.2v for stock intake before taking my car out for my lunch break. Can't say I've noticed anything different besides the slightly higher idle so far. Some hesitation at low rpm, but I think that's just the ECU adjusting to the new tune. Will do some more "testing" on my way back to the office.
Intent > Content
Old 10-11-2013, 05:23 PM   #296
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
I Just installed the Stage 1 map myself. My initial feelings were about identical to yours above. It Idles a little higher but it does idle so much smoother now, a lot less bouncing around. I also felt like when I was slowly rolling out or leaving from a stop it felt like it was more hesitant or willing to stall out, which it didn't... I took it out for about a 30 minute drive and by the end I have to say I am very happy with the results. The tune didn't really create a throw you back in your seat feel but after a number of good pulls I started to notice how much smoother it felt as it wound up. I also noticed that it felt more eager to take off as I was slowly cruising along. the power felt much more consistent.
Take it around for a bit let the ECU relearn itself a little and try to see if you can really notice the consistency in power and the slight increase in the greater RPM's.
toekneehair is offline   Reply With Quote
Old 10-11-2013, 06:37 PM   #297
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
keep those reviews coming! Im so on the edge to purchase this right now!
Furtive is offline   Reply With Quote
Old 10-11-2013, 06:51 PM   #298
Jvalich
Drives: '13 Subaru BRZ Limited
Ditto here. I'll just have to jump through a few extra hoops. As a 20 yr Windows Systems Engineer, I'm all OSX now. I'll have to bootcamp a version of Windows on my Macbook. Mac version in the cards for the future???
JV
White 2013 BRZ Limited auto6, Perrin LW Pulley
Manga Flow CB Exhaust, Motive Master Cylinder Brace
K&N filter, Meagan Racing Strut Bar, P&L Motorsports SS Brake lines
Jvalich is offline   Reply With Quote
Old 10-11-2013, 07:08 PM   #299
toekneehair
I highly suggest it. It's still new so not many maps yet but it's so easy to install and I can just see more and more maps coming out and the best part is its all open you can look at all sorts of maps. I'll be honest I don't know how to read them much now but I want to learn and this is a great platform for it.
Old 10-11-2013, 07:09 PM   #300
jamesm
I second that. Tunerpro for Mac would be great.
Old 10-11-2013, 08:43 PM   #301
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Grip Ronin View Post
anyone notice how to change the initial cold start rpm? sounds like the car revs to hell when i start it cold, with lack of oil pressure. i dont like it
In out OTS maps, we don't change the idle speed target during cold start conditions. We just change the final engine speed it eventually settles to when warm (750rpm vs 650rpm). So what you are describing is stock tune behavior as well.
Old 10-11-2013, 09:29 PM   #302
jeebus
Drives: 2015 Mustang GT (on order)
I got my oft today. Installed stage 1 stock intake v1.2. Feels great! I instantly noticed the extra torque. The whole powerband is smoother and it pulls harder up top. Almost sounds like VTEC post 4k heh. Totally worth the purchase. Looking forward to datalogging
jeebus is offline   Reply With Quote
Old 10-11-2013, 09:36 PM   #303
tiny41
Drives: Subaru BRZ Limited
A local tuner told me he would need datalogs to properly tune the car.
Can someone explain how would one tune a car if that is not available?
Would a tuner be using a wideband sensor or a gas probe?
I'm having trouble finding a tuner around my area because they either never tuned a BRZ before or is using ECUtek.
tiny41 is offline   Reply With Quote
Old 10-11-2013, 09:42 PM   #304
RC51ed
RC51ed's Avatar
Drives: 2013 Scion FRS
I know nothing about tuning but I believe in the olden days before data logs. Tuners would use dyno's and o2 sensors. Not even a wide range sensor. I wonder if something will come up if you google old tuning days.?
RC51ed is offline   Reply With Quote
Old 10-11-2013, 10:29 PM   #305
fstlane
fstlane's Avatar
Drives: BRZ Limited
You must allow the ecu to adapt. I too updated to 1.2v yesterday and thought I had mistakenly uploaded the stock tune. After a day of driving it's back to the same solid idling, snarling beast with the strong midrange torque that I enjoyed on 1.1v. THIS is how the car should run from the factory.
On a side note, I ran my 1st autocross on an OFT tune this weekend. The extra torque helped immensly with corner exit. It also allowed me to rotate the rear with the throttle instead of bogging down and/or downshifting in slower corners. The tune has really made my car more competitive and daily driving a lot more fun. Thank you and keep up the good work!
fstlane is offline   Reply With Quote
Old 10-11-2013, 11:32 PM   #306
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
even i currently have front pipe and exhaust, stock stage 1.2v work fine?
Old 10-11-2013, 11:34 PM   #307
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
ya, the idle is fine its just when you first turn the key it sounds like it revs to 4500+ then settles. i guess i just never noticed it before
IG-Joey_Soul
Old 10-11-2013, 11:43 PM   #308
solidONE
solidONE's Avatar
Yup! I believe my OFT just kicked in, yo.... I definitely feel a bit more pull right before it hits 3000 rpms at partial throttle. Going up this steep hill by my house it felt like it took less effort to accelerate up the hill. Another thing I noticed along with the higher idle is that when I let off the throttle completely and shift into neutral the rpms will drop and float or dwell at 1000 for a second before slowly decreasing to 750, rather than dip then shoot back up like it used to sometimes. Much smoother feeling. Haven't really wrung it out yet, but I'm sure it will be nice when I get to it.
Very nice work, Shiv and Vishnu Tuning!
Intent > Content
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
