Old 08-19-2013, 06:14 PM   #295
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Said the guy who thought he could use his stock rotors with brakes from another car...
Yeah, but I would've figured it out faster than a week.
Old 08-19-2013, 06:22 PM   #296
OrbitalEllipses
Drives: Attitude
There was nothing to figure out....I scheduled an alignment before I did the install and the closest date I could get was later that week. noob.
Old 08-19-2013, 06:49 PM   #297
Racecomp Engineering
The veering to the right could still be alignment. The front of the KWs is slotted for adjustment too. Does this shop have Subaru experience?
- Andy
Old 08-19-2013, 06:53 PM   #298
FR-S Matt
- Andy
He's done a BRZ there before, and a few STi's.
Hawkeye alignment equipment by Hunter Engineering is what they use.
I'm going back tomorrow for the alignment since the camber bolts will be in. I'm going to do some checks here at home to see the brakes. I'll have it all looked at when its on the lift tomorrow as well.
Old 08-19-2013, 07:08 PM   #299
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Should've delayed the install then.
Old 08-20-2013, 02:00 AM   #300
As I mentioned MArch of 2012(pre-production car 4 day test)....this car is VERY square and is sensitive to corner weights, tire pressure, 1/4 tank vs full tank, and for CERTAIN....alignments. I drove a customer's car who cheaped out on tires....OMG it felt like crap with a side of crap !
Get an alignment.
Myles
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
chanomatik (08-20-2013)
Old 08-20-2013, 04:02 PM   #301
FR-S Matt
Okay, alignment should be happening today. 14MM camber bolts should help the front. Having the height checked all around, then aligning.
Can't wait to drive it afterwards....
Old 08-21-2013, 10:39 AM   #302
djdnz
1337
Drives: 2013 BRZ WRB S/C
How many threads does everyone have left under the perches? Going to fine tune mine today and alignment tomorrow.
I like the height right but I forgot to measure before I started, and I also changed wheels at the same time so it's kind of a wash now. I only have 8 threads below the perch in the front. In the rear, I have 25 threads below the perch. The rear seems marginally lower than the front currently.
Curious what everyone else has right now, and if they measured stock vs lowered so I can get a better idea of how low I actually put it.
djdnz is offline   Reply With Quote
Old 08-21-2013, 11:12 AM   #303
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I could check, but for me (with 17" wheels, 245/40 tires) i am all the way down in the front. I think in the rear, If i remember right, i'm about 31 threads up.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
djdnz (08-21-2013)
Old 08-21-2013, 11:12 AM   #304
Gopherboy6956
So what is the result???
Old 08-21-2013, 11:51 AM   #305
FR-S Matt
Drives well. Still brakes and veers right. I think my toe is off based off what came back from the shop. I'm fairly low and think I need to go the LCA route to correct it and if I'm really feeling it, Whiteline adjustable bushings.
Looking at the SPC kit with the toe kit included. Should fix the issue I'm having. I am trying to get a flush look like @Sportsguy83 has and I'm pretty sure the rear end is what is giving me the issue on a stock LCA.
As for the coilovers themselves... extremely badass. I can corner hard. Sometimes I hear a slight tap when I go over a hill or down one in the rear and front right. May need to check the top nuts on the coils and re-torque.
Overall, extremely satisfied. I will be really happy once I get it at the right height with the proper aligned specs with the proper suspension components.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Sportsguy83 (08-21-2013)
Old 08-21-2013, 11:54 AM   #306
djdnz
1337
Did you get the alignment print-out?
Old 08-21-2013, 11:56 AM   #307
FR-S Matt
I didn't, but I think they might still have it. I'll give them a call.
I'll probably need another alignment when I get my LCA as well to correct the rear camber/toe.
Old 08-21-2013, 12:06 PM   #308
Gopherboy6956
I had to re-tighten one of my rear top nuts after initial installation, as it clunked around on day 1.
I mean, i only did the Whiteline Rear Bushings - Which by the way, took my subaru dealership about 7 hours to install and align ... I ended up with about -2 in the rear, and -1.5 in the front.
Toe is 0 for all corners for me.
FR-S Matt (08-21-2013)
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-16-2013 11:02 PM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-13-2013 11:26 PM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 08:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 12:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 01:44 AM
