Old 02-15-2018, 01:14 PM   #295
Greenbean
Drives: 2017 series yellow BRZ
BBK fitment
Originally Posted by OAKOS Automotive View Post
Those RPF1's will not fit over the PP Brembos. At least an 8mm spacer and extended lugs would be required.
-Nick
Oakos Automotive
Are there any 18x9.5 wheels that dont exceed $1500 that fit over the bbks? im not finding a lot.
Greenbean is offline   Reply With Quote
Old 02-15-2018, 01:22 PM   #296
OAKOS Automotive
OAKOS Automotive's Avatar
Drives: '13 Limited BRZ, Satin White Pearl
Send a message via AIM to OAKOS Automotive
18x9.5 in 5x100 is a tough size, more so with a BBK.
I believe the new Enkei TFR in 18x9.5 +45 may. They are a newer wheel so I do not have a ton of fitment info yet, but they are in that price range. I will ask Enkei if they have any insight on fitment.
-Nick
Oakos Automotive
OAKOS Automotive is offline   Reply With Quote
Old 02-15-2018, 01:30 PM   #297
Greenbean
-Nick
Oakos Automotive
I was on your site and for example the raijins would say rear only while the 18x9.5 +38 would say it fits just making sure but i appreciate all the help
Old 02-15-2018, 03:50 PM   #298
OAKOS Automotive
The fitments on our site are for Non-PP BRZ/86's, unless otherwise noted. We are still working on adding fitments for these cars, but we simply do not have enough information yet.
Enkei was unable to confirm if the TFR's would fit, but they said it would be close. That same wheel on an 04 STI requires a 5mm spacer, which has pretty similar fitment to the BRZ PP, although the PP Brembos are a little bit physically smaller than the STI version. We would not know without a test fit, and we do not have access to a BRZ PP unfortunately.
-Nick
Oakos Automotive
ft-86 speedfactory
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
