#295 | |
Benz Tech
Drives: 2017 BRZ Premium
![]() We have trans pan and engine cover bolts made of aluminum, they torque to like 5nm, as in not a lot. I can't count how many times I've had to help those guys back out a broken bolt with a pick. It's a different mindset with these younger guys. They find humor in mistakes, laughing when a screw driver goes though a $1000 radiator. We all just shake our heads and try to keep the shop in one piece. I would assume a Toyota shop is primarily younger guys. We only have 2 to contend with. Last edited by maslin; 03-15-2019 at 12:48 PM. |
#296 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Teseo (03-15-2019) |
#297 | |
Benz Tech
Some states (cities?) have requirements. "Mechanics Licenses" and such. Never needed one myself, worked in 4 shops across 3 states. I held a State Inspectors License in VA until I moved out west, only required to perform state safety inspections. |
#298 |
Drives: 13' Lightning Red Brz
Update: Didn't even want to talk with the techs at the dealership anymore and have escalated to SOA. Got my diagnostics back from them stating that the noises are coming from my left head. Stated in order to fix the main cause they would have to remove the head, change my camshafts, and adjust my valve stems. Just so nobody has to go back and read, this dealership also stated that my headgaskets were bad so they invoiced me at $1100 to repair that. Yesterday I receive a call from the dealership stating my valves were bad. That I needed to replace my rocker, cams, etc. They also stated that with the work done on the valve springs and headgaskets, they did not touch any of those parts stated above and they will not be covering any issues at the moment on their behalf. So pretty much I'm shit out of luck is what they are saying. Within the time they had my car, they were able to put 0 miles on the vehicle mind you not.
#299 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
I sure as hell would not be taking my car in for recall until this is resolved.
The Following 3 Users Say Thank You to SuperTom For This Useful Post: |
#300 | |
The College of Trades monitors progress very closely and if there is any discrepancy in an apprentice's documentation, log books (they have to record everything they do) or school records they can and will pull them from the program and they will never legally be in that trade. This is what they have to go through: https://www.collegeoftrades.ca/wp-co...rvice-Tech.pdf
The Following User Says Thank You to Tcoat For This Useful Post: | maslin (03-15-2019) |
#301 | |
Drives: 2013 BRZ 6MT
Wow. That’s impressive- My new plan’C’: move to Canada ![]() Sent from my iPhone using Tapatalk |
#302 | |
Drives: 2013 FR-S Series 10
this doesn't make any sense. |
#303 | |
Panda Trueno
Drives: No twin now.
THIS is that dealer trying to get you to take your car off their lot. They're hoping that you go away, or after its gone they can claim YOU did something after the fact. Fact is, they screwed up when they changed your headgaskets (if they even did this) and now they're wanting to take advantage of you or have you go away. Do NOT let this go, be calling every hour until someone rectifies this, start a conversation with a lawyer, contact a local new source that helps identify fraudulent businesses in your area. Don't just let this go. |
#304 | |
The Following User Says Thank You to Ichima For This Useful Post: | Tcoat (03-15-2019) |
#305 | |
Panda Trueno
#306 |
Forgot to state that my car was way too low apparently. It's on OEM suspension. But i don't understand how any of these statements will affect my motor in any way or form. Isn't there some sort of act that must state these parts must be the actual reasoning for damage on the vehicle?
#307 | |
Removing the head, taking apart to put valve springs and doing something wrong is what causes a head to fail. |
The Following 4 Users Say Thank You to ka-t_240 For This Useful Post: |
#308 | |
Tags |
brz, failure, frs, i cant even, j02, recall, so much glue |
Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
