08-24-2020, 09:32 AM | #295 | |
Drives: 2016 Scion FR-S
AWD is not a magic bullet that allows a car to perform miracles, but it can be a big plus if set up properly. And with any type of adverse conditions like rain or snow, it’s very important. For track driving and even sometimes on the street. I know I know people will say “All you need is good tires!” And I know that is true no matter what wheels are being driven. I think there are really awesome cars in each configuration, but there are so many other factors to make a car fun or perform better. Like what Honda was able to do with the FWD Civic TypeR, it shouldn’t be able to hang with more powerful cars with AWD, but it does. To be fair, depending on the track the Golf R and Focus RS will be faster. Sent from my iPhone using Tapatalk |
08-24-2020, 11:11 AM | #296 | |
Drives: Q5 + BRZ + M796
I think if you look at all the metrics, the CTR outperformed all these competitors in most ways. If it can get to 100 the fastest, go fastest around corners and stop in the shortest distance then the only metric left is getting on the power sooner, but in their test, the CTR had the fastest time. The Focus RS has an extra 45hp and 55tq, but it also has to carry an extra 334lbs plus extra drivetrain losses. If the AWD sacrifices 10% more drivetrain loss over the CTR because of AWD then the Focus lost 35 hp and tq, which puts it closer to the CTR, yet the Focus is heavier.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | JesseG (08-25-2020) |
08-24-2020, 02:21 PM | #297 |
Drives: A mix
A couple of things here. I don't put alot of stock into ring times. The factory team was sent with the car, with a driver who knows the car well, and then they go to set the best lap time they possibly can.
I say this because the benefit about AWD in a practical sense, is that most of us can get better lap times using AWD, vs. RWD and FWD. So yes, the Type R can accelerate faster, go around corners faster, etc, but that's alot of work on those front tires. Having AWD, especially a system similar to the Focus RS or GTR, gives the car more control over the output and can make a zero look like a hero. Yes, AWD is heavier, and more drivetrain loss, but for 90% of drivers out there, they will put up better times in AWD than FWD or RWD for that matter. Also, Honda did a great job in controlling the power it has stock, but what happens when you start turning the power up? Again, AWD has its advantages. The Type R is a marvel though, and I respect it, and it's also a much newer chassis that had benchmark targets the AWD competition didn't have, it will be interesting what happens when the new STI drops. For me, I prefer RWD, and I'm not some great driver or whatever, but my brain seems to just understand how to make adjustments (oftentimes not in time, lol) with rwd better than FWD which to over simplify is get the car into the right corner speed and hold on. I feel like there's more opportunity for mid corner corrections and improvising than FWD. AWD in that respect is sorta similar. Again, this way over simplifying, I know that FWD isn't nearly as simple as I just made it out to be, I'm just trying to formulate a succinct point. That's the thing about magazine racing, it just looks at the highest possible lap time and not consistent lap times, without alot of controls. But if we must, then on Motortrend's hot laps done on the same track, with the same driver, without factory support on hand (IIRC), the Type R is not as dominant. https://www.caranddriver.com/feature...storical-data/ Still very impressive. |
The Following User Says Thank You to TheDonEffect For This Useful Post: | JesseG (08-25-2020) |
08-24-2020, 03:05 PM | #298 | ||
AWD really only has an advantage where traction is limited, but in every other situation it is a disadvantage, and I agree, that for the street, when traction is limited, and a novice is behind the wheel, and 0-60 matters because someone needs to beat the soccer mom off the line, then AWD matters. In that test, the CTR and Focus RS had the same time and beat the Golf R and STI (not the overpriced RA), so again, the Focus couldn't beat a car with 45 less horsepower and 55 less torque plus two extra drive wheels and an intelligent AWD system. I don't know of a better illustration to show how much weight matters. Looks fast, 11:47 at 127mph:
08-25-2020, 01:49 AM | #299 |
Drives: A mix
IIRC there was something said about it being harder to repeat the lap times and what not. It's also a newer platform so I wouldn't put too much stock into it. Still very impressive, just not my cup of tea.
08-25-2020, 06:57 PM | #300 | |
I agree the CTR is incredible, not many FWD cars have ever been able to accomplish what it has. And it’s a good daily driver. The Golf R is probably the “best” daily driver, and the Focus RS and STI falling somewhere outside of that on the opposite side. And performance wise they all sort of reflect that. I would be surprised if a CTR could consistently outpace the Focus RS or STI. Maybe in a hot lap scenario. AWD can be a blast, especially a setup like the STI has. It adds weight of course, but you gain traction. So if you combine that with a powerful engine, voila! All that being said I would probably choose the STI with the CTR being a very close second. Since I’m a Subaru homer. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to JesseG For This Useful Post: | Irace86.2.0 (08-25-2020) |
08-26-2020, 03:20 PM | #301 |
Drives: '12 C63 P31, '23 GRC
When I look at anything with the Type R badge I think track use, and if I were to spend that much on a performance car it would almost certainly be my track car (Cayman is my current track car). The CTR is a crappy track car. It destroys its front tires and overheats easily. AWD would only make the overheating a bigger issue, but would help A TON with tire wear.
Hard pass.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
08-26-2020, 08:25 PM | #302 | |
It’s probably a little unfair to compare the CTR with cars like the Focus RS and STI, but it doesn’t have anything else to go up against. And the Focus RS doesn’t even exist any more. Overheating is an issue with pretty much any car on the track, they weren’t designed for hard track use. Some are worse than others though. Sent from my iPhone using Tapatalk |
08-26-2020, 10:17 PM | #303 |
Drives: 2013 frs red
I predict the new car will have very slightly improved performance numbers but will be more drivable in terms of power delivery. Might even be a touch slower on the spec sheet but more enjoyable to the average driver
08-27-2020, 07:42 AM | #304 |
Drives: '23 BRZ
I've tracked a buncha modded and non-modded cars over the past 25 years, including a 550hp LS3 FD and a 255rwhp 3.1 240Z (with stock 260z rad) and overheating has almost never been an issue. Only once really, '11 2.9 Cayman at Thompson Motor Speedway at ~100F, without the recommended 3rd radiator. Would start to overheat after about 5 laps, manageable by backing off a bit (less than a second), no problem to run 3-lap time trial. Other than that, never had overheating issues. |
08-27-2020, 07:57 AM | #305 | |
Drives: 2018 Subaru BRZ Limited with PP
08-27-2020, 10:19 AM | #306 | |||
08-28-2020, 12:39 AM | #307 | |
I haven’t spent much time on the track so it’s always good to hear first hand experience. I’ve done some AutoX but that is all done at much slower speeds. I had issues with brake fade on my GTI, but a pad upgrade mostly fixed that. And being FWD I noticed front tire grip would get worse as I drove. I took my WRX on many spirited drives, usually with other WRX owners. I remember one guy almost caught his brakes on fire. I immediately got better pads for my car. And I installed the intercooler water spray. EJ20’s tend to get hot because the top mount intercooler gets heat soaked quickly. Most cars will show weaknesses when you push them. Something like the Cayman I would expect to do better than a CTR after multiple laps. Sent from my iPhone using Tapatalk |
08-28-2020, 12:51 AM | #308 | |
Hopefully they can get it sorted out and set up a TSB. I still think it’s a bada** car, and getting over 300HP from a relatively small 2 liter engine is impressive. Any time you are trying to push the envelope of performance, it’s inevitable some issues will reveal themselves. I would buy one without much concern about overheating. You’re right, Honda did extensive testing with this car, and wouldn’t have released it with overheating issues. Driving it within reason of course, it’s not a true race car. Sent from my iPhone using Tapatalk |
Similar Threads | ||||
2022 Toyota Tundra spied | vh_supra26 | Other Vehicles & General Automotive Discussions | 87 | 07-30-2022 02:51 PM |
All-New 2022 Toyota 86 Reveal Delayed | gymratter | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 238 | 04-07-2021 08:17 AM |
"Harrop FRS Hustles Mclaren" - Click bait title, but still cool | Takumi788 | Tracking / Autocross / HPDE / Drifting | 3 | 04-03-2020 09:50 PM |
My nomination for most entertaining click-bait article ever | Dadhawk | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 10-16-2019 11:40 PM |
