Old 10-25-2015, 04:41 AM   #3011
dj2020
Originally Posted by LS1M View Post
I am having a heck of a time getting my JSRC with Delicious flash-n-go tune to complete the obd readiness tests. Is there a trick to getting them to pass? Delicious sent me an update with "all the tests turned on" (apparently the evap and o2 tests are disabled unless you ask for them). After 100 miles (since reflash) of mixed city & hiway, I still have yet to complete three tests: evap, catalyst and o2 sensors. Do the twins have a certain "driving cycle" that forces all the tests to run?
Thanks
-Mark
I'm also having a hard time getting my DT Flash n Go tune on my JRSC to pass all OBD readiness tests. I flashed the non flex fuel tune with all tests turned on as well and plugged my rear O2 sensor back on. My original CARB tune took about two tanks of gas or roughly 400 miles to show all sensors ready. I'm about 500 miles in right now and still showing non ready for O2, catalyst, and evap. Since we can't force readiness with Ecutek, what is the official 'drive cycle' for a 2013 BRZ to get these tests to complete?
dj2020 is offline   Reply With Quote
Old 10-25-2015, 05:36 AM   #3012
SPCorBUST
SPCorBUST's Avatar
There is a specific cycle, I did it before my testing at the referee station. Post 24 and 25 from mad_sb and foobar in this thread should help:
http://www.ft86club.com/forums/showt...t=34704&page=2
Sent from my SM-G925T using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 10-25-2015, 12:15 PM   #3013
dj2020
A drive cycle always begins with a cold start?
Old 10-25-2015, 01:13 PM   #3014
SPCorBUST
SPCorBUST's Avatar
Not sure about always, but I do remember beginning from a cold start and it eventually setting all of mine to ready except for the rear o2. (which was turned off anyway)
Old 10-25-2015, 02:42 PM   #3015
LS1M
Drives: 2015 BRZ
Can anyone with the flex fuel kit comment on how it affects your obd readiness tests? With the rear O2 sensor unplugged and being used for the E85 sensor instead, which tests don't get complete?
Here's a list of the available ones, per Torque:
Misfire
Fuel System
Components
Catalyst
Evaporative Sys
O2 Sensor
O2 Sensor Heater
EGR System
You can only have one "incomplete" to pass emissions testing, at least here in Texas
Thanks
-Mark
LS1M is offline   Reply With Quote
Old 10-25-2015, 02:51 PM   #3016
SPCorBUST
SPCorBUST's Avatar
Misfire
Fuel System
Components
Catalyst
Evaporative Sys
O2 Sensor
O2 Sensor Heater
EGR System
Thanks
-Mark
I can confirm that only one is left not ready, and I believe it says something like o2 sensor not ready. California has the same standard of one code allowable and I passed with that code still on the ECU at a referee station.
Old 10-25-2015, 09:49 PM   #3017
LS1M
Drives: 2015 BRZ
Excellent, that's just what I wanted know. Although I don't know how it can pass catalyst efficiency without that rear sensor. I've had a lot of old cars in my life and getting that #^!&!#@!! sticker has been a pain in the arse on many an occasion! I wanted to make sure I'm not setting myself up for a struggle come renewal time. Those rules can be ever so inflexible...
ugh... government
Old 10-25-2015, 11:48 PM   #3018
dj2020
ugh... government
No luck with getting the proper drive cycle down to getting O2, catalyst and evap sensors to show ready today. I did two cold starts and drove around today, at least 15 minutes each time with 1/2 tank of gas, steady slow acceleration and constant speeds. I agree, with the rear O2 sensor plugged back in, I should at least get O2 sensor and catalyst to show ready, especially with a stock catted exhaust manifold still present.
I'm just antsy and wanting to plug the DT flex fuel kit back into the rear O2 port and run e85 again. Just need to pass emissions...thank goodness I'm starting this process early.
Old 11-04-2015, 11:09 AM   #3019
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Has any JRSC owners gone with the high boost pulley yet? If so, definately want to see the dyno numbers on them.
Instagram: trevor.parque
Old 11-04-2015, 12:09 PM   #3020
BRZ'13
BRZ'13's Avatar
Drives: subaru
me too... im waiting on another results before i purchase mine. E85 i saw 370whp but i want to see pump gas (93/94)
BRZ'13 is offline   Reply With Quote
Old 11-04-2015, 12:18 PM   #3021
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
I seem to be getting more of a belt whine at or near idle? not sure what is going on?
Jmonty is offline   Reply With Quote
Old 11-04-2015, 12:19 PM   #3022
Parikh1234
Drives: Subaru BRZ Limited
Mine should be going in very soon (less than 3 weeks). I had to wait for my amuse exhaust system which took forever to get.
Also debating the e85 thing because theres almost no gas stations that sell it near me. I might add a meth kit though because I sometimes ship the car out west where 93 doesnt exist.
Will keep everyone in the loop.
Parikh1234 is offline   Reply With Quote
Old 11-04-2015, 12:24 PM   #3023
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
My tuner pretty heavily recommended e85 for high boost for its detonation resistance and cooling.
Sent from my XT1095 using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 11-04-2015, 12:59 PM   #3024
SPCorBUST
SPCorBUST's Avatar
The gains are with e85. It's a requirement along with a tune, I think. My dyno is 370, my 91 pump numbers were 290. (I think, I don't have it in front of me) I'm assuming that 93/94 would be marginally better.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
