Old 10-05-2015, 06:20 PM   #2983
Originally Posted by LOLS2K View Post
Not a question per se, but I did pull the trigger on some RE71Rs thanks to this thread (and others). I'm going to pair with some PMU Club Racers for SOW CW next month. I'll be pretty happy if I can go 1:31.XX or quicker.
let us know when you want some pads and brale fluid
Old 10-05-2015, 06:33 PM   #2984
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Thanks! I actually have access to a wide range of parts thanks to good friends in the industry, however there are parts that you offer that I don't have "access" to. You have definitely earned that business. I look forward to supporting you, and the support that you offer. Hope to meet y'all at the track some day.
LOLS2K is offline   Reply With Quote
Old 10-05-2015, 07:12 PM   #2985
Come join us at 86CUP
Old 10-05-2015, 09:01 PM   #2986
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Dec. 5th looks doable.
Old 10-05-2015, 09:11 PM   #2987
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
I am working on trail braking at the track. My instructor, who also drives a BRZ, noted that my car was significantly more difficult to turn under braking compared to his. I always thought the effort was high but had no basis for comparison.
Any thoughts?
Setup: RCE Tarmac2, RaceSeng Cam/Cas plates, SPL rear LCA and toe arms, RaceSeng 1" rear shock mounts. -2.9 and -2.3 camber F/R, 0 toe all the way around, maximum caster the RaceSeng plates allow. No other suspension mods. Approximately 1" lowered.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
Old 10-05-2015, 09:16 PM   #2988
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Tires?
Sent from my XT1095 using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 10-05-2015, 09:20 PM   #2989
Any thoughts?
Tarmac 2's are heavily understeer biased with the default springs.
I'm gonna bet your instructor is stock, or has something closer to neutral.
Old 10-05-2015, 09:40 PM   #2990
Alan
Alan's Avatar
The instructor has Ground Control coilovers with 450lb springs. He didn't note any other issues with the setup.
Any suggestions other than replacing the Tarmac2s?
Old 10-05-2015, 09:58 PM   #2991
softer front springs, rear sway bar, tweaking the setup.
Old 10-05-2015, 10:53 PM   #2992
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
Im debating on which tire to pick out for my track wheels, Im going to be running a 18x9.5 +40 setup and I brought my tire choices down to two finalist. The Hankook RS-3 V.2 or Toyo Proxies R1R, has anyone had experience with these two tires? Im debating on either a 255/35R18 (Square all around) or 265/35R18 (Square all around) but i'm thinking a 265 size would be over kill on this car. Also my car is now running forced induction and will be getting a AP Racing sprint kit soon. Im just wondering which would be a good track tire, that will provide excellent grip for those autocross/track days? Thank you in advance.
R2RO is offline   Reply With Quote
Old 10-07-2015, 03:12 PM   #2993
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
It's me again. RE71Rs (225/45/17) just showed up and I need some advice on breaking them in. I will be making the 420 mile (one way) trip to Willow Springs next month. Should I:
A) Drive on them to the track?
B) Wait until I get to the track and break them in there? If so, how do you guys recommend I do so?
Old 10-07-2015, 03:13 PM   #2994
ScionOfHorus
I'd break them in on the way there
Old 10-07-2015, 03:15 PM   #2995
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
@ScionOfHorus that is what I usually do, however I am completely new to this tire and didn't know if there is anything special about the compound.
Old 10-07-2015, 03:25 PM   #2996
They're street tires. Other than getting past the release compound (which you will do the first couple corners), there's no break-in procedure.
Whether you drive up on them, or change at the track, is up to you and how lazy you feel
