#2969 | ||
Drives: 2017 BRZ
Anything you've learned in your switch worth noting? |
The Following User Says Thank You to cjd For This Useful Post: | Shark_Bait88 (10-30-2017) |
#2970 | |
btr.life
Drives: 2022 GR86
Only thing worth noting is, make sure you have a piston spreading tool for when you change pads. I got this one, Disc Brake Pad Spreader Sorry about the car, good luck finding a new one! EDIT: And here are some pads that fit the AP Racing Sprint kit too. Took me a while to find the right part #'s. Hawk HPS pads for AP Racing Sprint kit Hawk DTC60 (track) pads for AP Racing Sprint kit
#2971 | |
Drives: 2017 BRZ
As for the rest - good info, but I was curious about the switch to the updated platform in general. I've mostly kept up, so I'm guessing there's nothing to speak of. I have a bit more of a winter project than planned so not searching to find the answers myself is me trying to be efficient. ![]() C |
#2972 | |
btr.life
Drives: 2022 GR86
1. The gearing obviously. You will want a higher limiter and probably 255/40 tires to get the most MPH out of 2nd gear. 2. The stock rear sway bar is 16mm, I put the older model 14mm on, and soon the Mann Eng adjustable. 3. The axle back connection is a different size flange. Probably a non-issue since you would normally install a full exhaust. 4. Stock airbox is different. Uses a different drop-in filter and 2017 specific Perrin inlet tube (if you go those routes). Other pre-2017 airboxes seem to fit fine. 5. ECUtek support has been pretty rocky for the 2017's. I think they are mostly through all the bugs now though, finally. 6. You get more chicks with the 2017+ cars. HTH
#2973 |
Drives: Fast
What is the set up to run 17x9 wheels and clear the BRZ Perforamnce Package Brembos?
What wheels/offset works or do you pretty much need to run spacers? |
#2974 | |
Drives: Car
Gram Lights 57CR - 17x9+38 Gram Lights 57DR - 17x9+38 Apex ARC-8 - 17x9+42 Ambit RE02 - 17x9+35 949 Racing 6UL - 17x9+40 |
The Following User Says Thank You to FirstWinter For This Useful Post: | cab33 (10-31-2017) |
#2975 |
Drives: 2013 Satin White Pearl BRZ
Are these tow arms stx legal. Are any tow arms stx legal? The rules aren't clear enough to me until recently I thought it was illegal but seeing them in the kit for ssc is making me rethink that.
I just want them to make the alignment easier. ![]() Sent from my Pixel using Tapatalk |
#2976 | |
There's some discussion from this post onward: http://www.ft86club.com/forums/showp...postcount=2853 I have the SPC arms sitting on a shelf waiting to go in sometime in the next few weeks, I'll measure the bushings to be sure they meet the 'no additional metal' rule. Edit: http://www.ft86club.com/forums/showp...postcount=2867 |
The Following User Says Thank You to strat61caster For This Useful Post: | jbailey8748 (11-13-2017) |
#2977 | |
APEXHNTR
Drives: 10 Series FR-S #1867
Interesting take on it...maybe we should write to SEB for clarification? I always read it as TL;DR "you can only change one arm" so we all choose the one that gives the most benefit; the LCA. I do my own alignments and I do them every two months or so, so a rear toe arm would be so clutch to me.
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#2978 | |
It's not a "take" and nowhere does it imply that only one arm can be changed (aside from upper vs lower) |
#2979 | |
This isn't difficult guys, no need to interpret rules one way or another. It's not legal
14.8.H.1 Quote:
Just because SSC has something that STX does not, does not automatically mean that it's STX legal now. Write a letter and ask Toe-Links to be legal
Kyle H. - #89 STX
#2980 | ||
There are three links that comprise the 86s rear lower multi link suspension. Two of them are lateral, one of them is longitudinal. Those two links also do nothing to control fore/aft motion of the rear wheel via their OE spherical bearings, the third link does. All of them are integral to the rear suspension. I will make no mention of SSC rules. This isn't interpretation, it's understanding the terms scca has written into their rules. It was never different, I have no idea how someone can read this as 'only one link can be non-OE' please elaborate further if I'm missing something. 1 a-arm = multiple links Edit: Quote:
#2981 |
So lets just go back to simplicity sake...
"If it doesn't say you can do it, you can't" You can't do toe-adjustments. They must remain OE.
Kyle H. - #89 STX
#2982 | ||
What do you mean by "they must remain OE"? I'm not installing a 'toe kit' I'm installing a piece of a 'camber kit' as sold by SPC. Quote:
I really do appreciate you fighting me on this, but the rules explicitly allow for multiple lateral links to be changed to achieve desired camber. The more I re-read it, the more I'm convinced. What should the clarification letter be? "Clarification on 14.8.H.1, can multiple lateral links of a multi-link suspension be changed from OE similar to what was clarified in letter #17733? This affects nearly all multi-link cars such as the 86/BRZ/FRS, WRX, Focus, Mustang, Camaro, non-trailing arm BMW's, 350Z/370Z, RX-8, etc. which typically already have some factory adjustment in one or more links and typically only require one additional modified link to achieve desired camber, however all cars would benefit from easier to adjust aftermarket lateral links in multiple locations where factory adjustment is deemed sub-par by the competitor." |
The Following User Says Thank You to strat61caster For This Useful Post: | jbailey8748 (11-14-2017) |
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
