Sam Strano
Old 04-28-2015, 10:54 PM   #2955
ildylan
rolling over my sidewall
ildylan's Avatar
Drives: 15 FRS
http://www.ft86club.com/forums/showthread.php?t=84622
ildylan is offline   Reply With Quote
Old 04-29-2015, 08:54 AM   #2956
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Originally Posted by ildylan View Post
If the rulebook doesn't say anything, you probably can't do it.
G_Ride is offline   Reply With Quote
Old 04-29-2015, 09:52 AM   #2957
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
No sure why this would even matter. For pros, you pretty much dump at 4k, for non pro tours its mute.
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
The Following User Says Thank You to Laloosh For This Useful Post:
TrqlessWonder (04-29-2015)
Old 04-29-2015, 12:40 PM   #2958
TrqlessWonder
Drives: 2014 FR-S
This. Finesse and feel with the clutch is not particularly relevant to autocross, unless you're actively looking to torture your clutch doing the slow-release-while-holding-at-6-grand launch method.
For the idea of leaving that change done for the street and just not wanting to bother with undoing it for an event, I don't really know if that's kosher. If the rulebook doesn't offer anything on the topic, then you're at least in a gray area, and shouldn't be necessarily surprised to find out that it isn't.
Take a few minutes and send a letter to the SEB. That (and a protest committee) are the only rulings that matter. crbscca.com
For the idea of needing/wanting it for the street - the vagueness did bother me at first, but, a month of driving (and none of those DIYs) is all it took to develop a feel for the clutch.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 04-29-2015, 03:51 PM   #2959
scirocco78
Drives: Scion FRS
I have no idea how pissed off I would have to be to protest someone because they removed their clutch spring Maybe if the same person slept with my wife or clubbed a baby seal I might protest them.
scirocco78 is offline   Reply With Quote
The Following 3 Users Say Thank You to scirocco78 For This Useful Post:
ildylan (05-06-2015), Rampage (04-29-2015), Shark_Bait88 (04-29-2015)
Old 04-29-2015, 04:45 PM   #2960
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
The Following User Says Thank You to Locust For This Useful Post:
Old 04-29-2015, 04:52 PM   #2961
Jawnathin
Drives: Toyobaru FRZ
I too question the legality of the clutch spring mod. However, one could argue that this could fall under the comfort and convenience allowances.
Accessories, gauges, indicators, lights and other appearance, comfort and convenience modifications which have no effect on performance and/or handling and do not materially reduce the weight of the car are permitted.
Jawnathin is offline   Reply With Quote
Old 04-29-2015, 07:40 PM   #2962
RMP
Drives: 1992 Isuzu PuP, 2014 FR-S
I would like to start attending track days in addition to autocross and added an oil cooler due to documented issues with overheating. I don't believe this adds any performance in the context of autocross. I submitted a letter to the SEB asking for an allowance of oil coolers in the street classes.
I'd like to know what your thoughts are regarding this mod for the street classes. Would you object to having it be allowed?
RMP is offline   Reply With Quote
Old 04-29-2015, 07:48 PM   #2963
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Lemme get this straight... You want to track your car and because you want to track your car, you want to modify the rules for AutoX?
-Jack Burton
Old 04-29-2015, 07:53 PM   #2964
Jawnathin
I recall this was proposed or discussed, I think it was turned down.
In any case, allowing oil coolers in street class is a slippery slope. While it may not benefit an 86s at an autocross, some cars with conservative ECUs that pull timing based on coolant/oil temps would actually receive performance benefits from having aftermarket coolers.
For those cars/classes, an oil cooler would be required to be on the same playing field as other competitors.
The Following User Says Thank You to Jawnathin For This Useful Post:
RMP (04-29-2015)
Old 04-29-2015, 08:15 PM   #2965
Wheeljack
Wheeljack's Avatar
Drives: 2013 WRB BRZ Limited
I've thought about this as well. The way I figure it, if I can handle the added expense and wear from track abuse, I may as well make the jump to STX where those mods are legal.
Wheeljack is offline   Reply With Quote
Old 04-29-2015, 08:34 PM   #2966
G_Ride
G_Ride's Avatar
Not too long ago (two years ago?) oil coolers were allowed for Street Prepared and up. It's now legal for Street Touring, but I don't see it being allowed for Street. Oil coolers don't seem to fit the idea of what Street is supposed to be.
Old 04-29-2015, 08:35 PM   #2967
RMP
Precisely.
Old 04-29-2015, 09:28 PM   #2968
TrqlessWonder
Drives: 2014 FR-S
Yep. It got shot down recently. "not aligned with the philosophy" or something of that nature.
But, with a little extra expenditure on the way you join the lines and mount the cooler, I don't see how it would be an absolute disaster to make a removable one. Just keep those hoses pointed up when you take it back out.
-Mike
#24 CS/CSR
The Following User Says Thank You to TrqlessWonder For This Useful Post:
RMP (04-29-2015)
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
