Old 05-16-2016, 01:18 PM   #2941
strat61caster
strat61caster's Avatar
Originally Posted by Tokay444 View Post
Never. Maybe it might work for a cone dodger, but on a real track with a fast car? Never.
I was lazy so looked where I thought I'd find the fastest answer. The second post in this thread is from Jim Drago on setting up a Spec Miata. "Oh that's not a fast car, what a joke!"
Jim Drago hustled his Spec Miata around Laguna Seca in 1:45 to an 86's 1:51 with Pobst behind the wheel. That's a Miata with <130 horsepower and race slicks that are measley 205's, oh and 1/16"-1/8" toe out at the front according to him.
http://mazdaracers.com/topic/4636-to...ht-line-speed/
Ultimately setting up a racecar is done to the drivers taste, what works for one guy can be a nightmare for another, you can do whatever the hell you like, but saying shit like this is just downright silly.
And I decided to spend another 2 minutes googling and found this:
In general, an F1 car will have about 1 degree of toe-out on the front tyres and 1-2 degrees toe-in on the rear tyres.
https://thewptformula.com/2016/02/11/analysis/
In this post there's a spyshot of Raikkonen's test Lotus setup sheet showing 1mm toe out on each front wheel (along with an Arrows setup sheet that agrees):
http://f1framework.blogspot.com/2012...car-setup.html
I mean, if you know something that Renault F1 team (Edit: the same team that gave Schumacher and Alonso world championships) doesn't that would help a guy like Kimi Raikkonen go faster you could probably make some good money.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
OkieSnuffBox (05-16-2016), ScionOfHorus (05-16-2016)
Old 05-16-2016, 03:34 PM   #2942
Racecomp Engineering
Originally Posted by Shark_Bait88 View Post
So I'm looking to upgrade the springs on my SACHS coilovers. Current rates are 38N/mm in the front and a progressive rear rate of 20-45 N/mm.
I want to go to something stiffer, since those are pretty soft rates, and definitely switch the rears to linear.
Relevant info for the car: Daily driven with around 10-15 track days and as many autox events as I can possibly run in a season.
Current modifications (apart from the SACHS coilovers): No real power mods (only thing apart from suspension is a muffler delete and drop-in filter), 17x8 wheels with 225/45 ZII Star Specs, and original Whiteline LCAs. I'm trying to sort out my camber plate situation, but once it's finally figured out I plan to run F-2.5 and R-2 to start with.
Seems like, based on what I've seen RCE and CSG suggest/run, the cars tend to do quite well with 400-450 lbs/in squared or F 400 lbs/in R 450 lbs/in.
Given the info above I'm leaning toward Hyperco 450lbs/in springs all around, but would certainly appreciate any information/input from those with greater knowledge and experience on these matters than myself. haha
Will you be able to have the damper revalved?
- Andrew
Old 05-16-2016, 04:04 PM   #2943
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
- Andrew
I can have it sent out to be revalved.
However, in talking with the suspension guy at ZF Race Engineering he said that I should be good to add springs up to 200lbs/in stiffer without needing a revalve.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 05-21-2016, 10:28 PM   #2944
DaBrz
First timer...
Does bigger sear bars, end links, and rear lca cause more noise?
I'm.getting uhh by noises over smaller bumps like on brick roads.
Also, how much do you need to torque the rears of time flex Zs once it's on the car?
Thanks.
DaBrz is offline   Reply With Quote
Old 05-21-2016, 10:31 PM   #2945
gramicci101
Off Topic
For #1, something isn't tightened all the way. Check it all again and you'll probably find the culprit.
The Following User Says Thank You to gramicci101 For This Useful Post:
BRZHarley (05-27-2016)
Old 05-22-2016, 01:46 PM   #2946
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by DaBrz View Post
First timer...
Thanks.
2nded. Check and torque down all the hardware you touched on the install.
Intent > Content
Old 05-27-2016, 01:03 PM   #2947
ZionsWrath
Thanks
ZionsWrath's Avatar
My last set of tires had more wear on the edge. Got a new set and went for alignment.
I have stock suspension with Front Camber plate and rear LCA.
I asked the shop for increased camber and he asked what tires I was running. I am using 200TW street tires, right now AD08R. He said in his experience more than ~2.5 front/2.0 rear on street tires isn't beneficial. He recommended I get some suspension upgrades, at least stiffer springs and if coils he recommended RCE Tarmac 2. The reasoning being even if I increase camber the soft stock suspension is still going to cause edge wear on the tires.
Does this sound reasonable? I was hoping not to spend a lot of $ on suspension.
Old 05-27-2016, 01:57 PM   #2948
strat61caster
I was totally content running ZII SS with camber plates and everything else stock. I really liked the car running -3.2 degrees camber up front and OE rear (~1-1.5 degrees).
You're not going to break anything running what you've got, enjoy it, one of the best bangs for the buck imo.
ineedyourdiddly
Old 05-27-2016, 03:13 PM   #2949
dp1
driving smoother faster
Drives: Sold
I wonder how many track hours it takes to wear out OEM shocks
dp1 is offline   Reply With Quote
Old 05-27-2016, 06:35 PM   #2950
TEWwild
TEWwild's Avatar
Drives: 2015 Ultramarine FR-S MT
I'm wondering the same thing, I currently have 52 track days averaging 2 hrs of on track time per day and still going strong.... When I find out I'll let you know
Not the smoothest track around either...(Harris Hill Road)
TEWwild is offline   Reply With Quote
The Following User Says Thank You to TEWwild For This Useful Post:
dp1 (05-27-2016)
Old 05-27-2016, 07:43 PM   #2951
dp1
Drives: Sold
That's great! Anybody experienced (unexpected) premature OEM shock failure from track use?
Old 05-27-2016, 11:15 PM   #2952
OkieSnuffBox
Drives: '23 BRZ Limited
For example, Emilio of 949 Racing, talking about XIDAs (custom built ASTs for Miatas), he has said they should last 200 hours of HPDE/TT use before they see a noticeable drop in damping.
As a reference.
Like everything else, heat is what kills everything.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
dp1 (05-27-2016)
Old 06-04-2016, 10:56 PM   #2953
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
What's a good STX-ready/ performance minded rear alignment setting? I'm currently running a slight bit of toe-in, and one my RCE yellow springs my rear camber is a bit too droopy (and not even, so I've got a little camber wear on my back right). I'm going to install LCA's soon.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 06-05-2016, 09:30 PM   #2954
With rear LCAs, try around -2 degrees in the rear. Depending on the tire you're using, you might like a little a few tenths more.
Will definitely need around -3 up front.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Keenercarguy (06-05-2016)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
