Old 09-29-2015, 03:51 PM   #2927
TougeSlide
Drives: White '15 86 and '93 180sx SR20det
Continually updating two posts up. Anyone else experienced all this? Any advice? trust the dealer to make it right, or turn the screws with an attorney?
TougeSlide is offline   Reply With Quote
Old 10-11-2015, 03:30 PM   #2928
jprules
jprules's Avatar
Drives: Scion FRS 2013
Originally Posted by jeanfrancoc View Post
Hi, I'm from Peru, South America.
I just bought a Scion FR-S from US and I brought it to my country. It had around 11000 miles and cost me about 20K. It was fine until I made a long trip, took the car to 200 km/h and up to 7k rev.
Just as the previous comment, I did took the battery of the car and it reseted the ECU. Since then it's just fine, although I haven't driven it hard again, just in the city, where I can't go fast.
I'm a little afraid, I don't know if I must sell the car or keep it. It's by far, the funniest car I've driven. I don't have any warranty and I know you must be thinking how stupid I am for buying this car without doing any research about it's problems.
Jean Franco Carhuas
Scion Fr-S 2013
12,000 miles
I'm living the same problem as you, i buy one FRS from USA... I am from Central America...
jprules is offline   Reply With Quote
Old 10-12-2015, 08:11 PM   #2929
Billy_BRZ15
Drives: 2015 BRZ Series Blue
Anybody ever get anything on. CEL p219a?
Billy_BRZ15 is offline   Reply With Quote
Old 10-14-2015, 08:32 PM   #2930
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I just got the check engine and SL light. Threw P0171 and C1201 codes. Any help please?
MS, CSCS, TSAC-F, CPT
Old 10-28-2015, 01:59 AM   #2931
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I just noticed your car is modded, P0171 comes with an intake leak or exhaust leak in the flange so I would check there as well as make sure the O2 sensors are working properly. If it's an exhaust leak it's gonna be from the engine block to the flange of the header, might need a grimmspeed exhaust gasket upgrade?
If it's an intake issue which seems more likely with the supercharger, I would check all the intake pipes any loose hose clamp will leak air and then cause the maf to go full shit mode and think it's running lean
Old 10-28-2015, 10:26 AM   #2932
weederr33
weederr33's Avatar
Thanks for the info! It was the intake. I rechecked all of the clamps, and I didn't tighten them very good after changing my air filter. The exhaust is solid, I made sure of that! Plus I used grimmspeed gaskets from the start since they are the best.
Old 11-03-2015, 10:27 AM   #2933
guitarhero23
Drives: 2014 Subaru BRZ
Feel free to update mine. Mine went in another 3 times. Last night I brought it in, they updated ECM firmware or whatever, gave it back to me "fixed". 20 minutes of driving later it came on again. Unsure what the hell is going to happen now, they have my car and I'm awaiting word. I'm going to go for Lemon Law soon.
EDIT: New ECM needed, 2 available in USA, none on east coast. yay
guitarhero23 is offline   Reply With Quote
Old 11-03-2015, 11:14 AM   #2934
Same code?
Old 11-05-2015, 01:17 PM   #2935
guitarhero23
Same code?
Different but related. Still related to cam sensors, and now need another ECU. All in all I've had the following codes,
Visits to shop:
1:
P0018
P0021
2:
P0018 (again)
3:
P0021 (again)
4:
P00A
5:
They took it, explained on phone but I forget which code they said. Cam stuff as before. New ECM needed. Again.
Old 11-05-2015, 01:21 PM   #2936
Visits to shop:
1:
P0018
P0021
2:
P0018 (again)
3:
P0021 (again)
4:
P00A
5:
Have they done anything with the cam that you know of? They can throw all the ECMs in the world at it but nothing will change if they don't fix the root cause.
Hell cam sensors were such a problem in the early ones that there is a TSB for them.
http://www.ft86club.com/forums/attac...1&d=1378232133
Old 11-13-2015, 01:16 PM   #2937
jprules
jprules's Avatar
Hi Guys, no more Check Engine, Change O2 sensor Upstream and Downstream. My code was p0171.
Best regards
Old 11-18-2015, 08:09 PM   #2938
sw20kosh
Drives: 2013 Black FR-S
2015 BRZ 8k miles throwing P000C code along with odd idle dip....
what is going on?
Old 11-24-2015, 11:09 AM   #2939
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
2013 Scion FR-S 51k miles, throwing p0016 code.
Dropped her off about an hour ago, waiting to hear back. The dealership acknowledged the TSB and are taking a look. Signature symptoms of rough idle are apparent. *Crossing fingers*
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
Old 11-24-2015, 05:51 PM   #2940
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
what is going on?
Have you brought it in yet? It could be something like an OCV valve, and not necessarily ECU related.
jawn is offline   Reply With Quote
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
