Old 05-16-2024, 03:24 PM   #281
M0nk3y
Oh and I see they were able to get around the recent ecutek restrictions? Or is this dyno plot from before the changes?
This was done yesterday. I have had this car tuned and revised starting last year, so unsure where/how restrictions would apply
Kyle H. - #89 STX
Old 01-10-2025, 08:27 AM   #282
AndreC
Drives: Fast track beast
Figured I'd post up my dyno chart as I'm also looking to convert to E85.
Would be interesting to see how much bump up I get in just switching fuels and retuned.
Mods list:
2013 Scion FRS - track only
built FA20, CP 10.0:1 compression piston, Manley rods, Behive valve springs
JRSC C30 with HB pulley, 12psi
AEM fuel pump, ID1050 injectors
stock rear end ratio
94 Octane, tuned by DoverLabs
AndreC is offline   Reply With Quote
Old 03-22-2025, 10:10 PM   #283
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
2013 Subaru BRZ
Stock Engine, Internals
700cc Deatschwerks Injectors
FBM Walbro 485 FP - E85 Moto East Flex Fuel (E71 on the sensor)
JDL v2.1 Turbo Kit (UEL header, GTX2860R GenII)
Link G5 ECU
7PSI - Hub Dyno (I forgot the brand - basically the same as Mustang Dyno I was told)
Conservative Tune since I race this car (I'm happy with how well it drives)
RongTurnRacing is offline   Reply With Quote
Old 05-21-2025, 12:36 PM   #284
RongTurnRacing
Originally Posted by RT-BRZ View Post
2013 Subaru BRZ
Link G5 ECU
I've had a chance to do more driving in the car. It's a total handful. It's so easy to get the car sideways. I'm guessing this is normal but I have a steep learning car to run this car for autocross at the least.
Old 07-29-2025, 06:00 PM   #285
B T
Today's result at 105 Deg F ambient temp
B T is offline   Reply With Quote
Old 04-07-2026, 05:18 PM   #286
Diddy Kong Had A Dong
Diddy Kong Had A Dong's Avatar
Drives: 2018 Subaru BRZ Ts
- DKHAD
- JDL V2.1 UEL turbo kit (Garrett GTX2860r Gen II)
- Flex Fuel (E81 on sensor)
- 7psi wastegate spring
- AEM 340lph fuel pump, ID1050x injectors, Delicious tuning flex fuel kit and AOS, JDL 2.5” track front pipe + over pipe, Invidia N2 catback, FBM Radiator, Setrab 19 row oil cooler, custom ducting and heat wrap on everything
- 323.9 hp / 246 tq, Tuned by CSG, ambient temp ~70°, will be dropping to 5psi spring to fit in NASA TT/ST4.
2018 BRZ tS WRB 493/500 | JDL UEL kit w/ gtx2860rs gen2
Diddy Kong Had A Dong is offline   Reply With Quote
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 10:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
