Old 10-09-2016, 04:32 PM   #281
ztrevs
ztrevs's Avatar
Drives: 17' CWP BRZ ------- 15' GLA45 AMG
Bump.
Looking to order these wheels in SBC in the near future to have them come summer time.
Planning to lower my '17 BRZ on Eibach Pro Kits (dont want anything too low for our winters).
Read through this entire post and i'm thinking 245/40/18 all around.
I shouldn't have a problem with rubbing correct?
And in order to fix the poke I will just have to adjust the camber?
ztrevs is offline   Reply With Quote
Old 10-10-2016, 02:20 AM   #282
tyler_win_photo
tyler_win_photo's Avatar
Originally Posted by ztrevs View Post
Bump.
I think you will if you're planning on using camber to fix the poke. You will rub on the spring perch for sure in the front with the amount of camber you will need to get it flush with the fender.
tyler_win_photo is offline   Reply With Quote
Old 10-10-2016, 03:20 AM   #283
ztrevs
ztrevs's Avatar
Any other suggestions for alternatives? I can size down the tires if it makes my life easier.
Old 10-10-2016, 03:33 AM   #284
tyler_win_photo
Either coils or don't worry about the poke. With the one inch drop the eibach pro kit is going to give you, you'll need around -3 degrees of camber to tuck in the front... and I'm not sure how you're going to get that much unless you get camber plates + camber bolts or control arms.
Old 10-30-2016, 03:18 AM   #285
mm10
Drives: '17 BRZ
Hey guys, I'm new to the forum and am having a hard time deciding whether to buy 17x9 RPF1's or 18x9.5 for my brz. I love the way the 18's look but am worried they will affect acceleration enough that I will feel it. Need some advice, thanks guys
mm10 is offline   Reply With Quote
Old 10-30-2016, 04:44 AM   #286
tyler_win_photo
NA you will notice the weight difference in acceleration, or at least I did.
Old 10-30-2016, 06:54 AM   #287
JamesssSmith
Drives: '15 BRZ
I didn't notice a massive difference in acceleration, but I did notice a lot more grip when accelerating
Sent from my Nexus 6P using Tapatalk
Instagram: jimmyjimmyjimmy_
JamesssSmith is offline   Reply With Quote
Old 10-30-2016, 06:56 AM   #288
mm10
Drives: '17 BRZ
Keeping it NA. Not tracking it or anything like that but I still want to have fun, the car as it is doesn't have a lot of power as we know so the last thing I wanna do is slow it down even more. Such a tough decision.
Old 10-30-2016, 07:40 AM   #289
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Plenty of options out there for boosting acceleration performance. I'm staying NA myself. As with most things in life it's just a matter of money.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 10-19-2017, 08:06 PM   #290
DarkSideFRS
Drives: 2013 pearl white FR-S
i really wish enkei made these in 18x8.5 and 18x9... 18x9.5 is too wide for my taste...
i am currently on TRD springs (1 inch drop) with -1.7F and -1.3R camber... reading the posts on this thread, it seems like i need -2 camber for it to not rub (prob going with 24/35/18 tires)?
DarkSideFRS is offline   Reply With Quote
Old 10-21-2017, 09:49 PM   #291
mikko86
Drives: Scion
Ok just to get a definitive answer lol 245/35 will clear on springs but are there certain tires to avoid that fit larger that cause rubbing? Im not worried about poke.
mikko86 is offline   Reply With Quote
Old 10-23-2017, 11:09 AM   #292
Anthonyc77
Drives: 2017 Toyota 86 Halo
Tried out a set of 17x9 +45 rpf1s, and on full lock they hit the outer tie rod. No big suprise there its been documented a bunch here, however with the 18x9.5 +38 it really only gives an extra 1mm more inner clearance. I have heard of people with the 17x9 +45 rpf1s running 3mm spacers and still not having enough clearance from the tie rod, so was curious why or how the 18x9.5 +38 didnt have any issues? Just the extra inch in diameter somehow move the wheel further away? Does anyone here have tie rod rubbing issues?
Anthonyc77 is offline   Reply With Quote
Old 02-15-2018, 01:54 PM   #293
Greenbean
Drives: 2017 series yellow BRZ
wheel fitment question
will the 18x9.5 +38 rp1 fit over pp bbk's? I plan on getting fortune auto coils but not any LCA's will i run into rubbing issues in the rear with 265/35 all around? or should i go safe with 255/35 all around
Greenbean is offline   Reply With Quote
Old 02-15-2018, 02:07 PM   #294
OAKOS Automotive
OAKOS Automotive's Avatar
Drives: '13 Limited BRZ, Satin White Pearl
Send a message via AIM to OAKOS Automotive
Those RPF1's will not fit over the PP Brembos. At least an 8mm spacer and extended lugs would be required.
-Nick
Oakos Automotive
OAKOS Automotive is offline   Reply With Quote
ft-86 speedfactory
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 11:30 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 05:53 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 02:52 AM
