| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#281 | |
Just because there is RTV it does automatically mean damage was done. If severely blocked the damage will usually be immediate and catastrophic. Besides, the point was that a baffle plate is not a solution since if indeed blocked enough to cause damage adding a baffle plate won't reverse that and if no damage had yet occurred then removing the blockage prevents it.
#282 |
Drives: Crapcan
You would be surprised the abuse these things can take NA. At my favorite track I probably get oil pressure dropout into the single digits a couple times a lap while under power. Gen 1 car, 101k miles. Around 35-40 track days.
If sealant plugging the pickup is killing them, they must be running very low pressure for a long time.
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#283 |
Drives: 2022 BRZ sport-tech
Both of you are correct hence pulling the pan is a gamble either way.
At this time, I still do not know if the excess RTV is from the oil pan, timing cover, other areas, or ALL of the above. And i still think compiling a list of failures with build dates will be useful.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
| The Following User Says Thank You to Petah78 For This Useful Post: | DocWalt (08-03-2022) |
#284 | |
Think that from what we have seen there is little doubt that the oil pan is the biggest issue but even a tiny piece introduced after the filter can destroy an engine without even having a single visible piece.
| The Following User Says Thank You to Tcoat For This Useful Post: | spcmafia (08-02-2022) |
#285 | |
| The Following User Says Thank You to Petah78 For This Useful Post: | spcmafia (08-02-2022) |
#286 |
If there is that much big stuff in the pickup it is a pretty safe bet there is some in the filter.
#287 |
As a datapoint, i changed my factory fill this past weekend @ 1k miles. I used a kitchen strainer as the oil drained but caught nothing. I still have the old oil filter and will perform surgery on it later this week and report back.
| The Following 3 Users Say Thank You to Petah78 For This Useful Post: |
#288 | |
Drives: Crapcan
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#289 |
@slothbrz on IG
Drives: Track BRZ - Supercharged
https://www.roadandtrack.com/news/a4...-repair-denied
looks like R&T put an article out about it, word is definitely getting out. they should've linked this post instead of that other one....but close enough |
| The Following 12 Users Say Thank You to jacobe38 For This Useful Post: |
#290 | |
Drives: '22 BRZ
#291 |
Drives: X5 35d, D90, CX-5 Turbo
Absolutely, only likely way that customers are going to be able to hold Subaru/Toyota's feet to the fire. Excess Silicon RTV should not be in the oil pan, claiming drifting causes the issue is just such utter BS.
How about driving on rough roads, that's not likely to break it loose? BS excuse Toyota.. |
#292 | |
Drives: Mini Cooper S
I mean this whole thing could likely be solved if the dealers just removed the pan and replaced the sealant when they get the car. Anyone know if installing a baffle plate would void the warranty? MM seems to say the dealer would need to prove that the plate contributed to the failure in order to void the claim. |
#293 | |
Drives: 2018 Subaru BRZ
Fck yeah, I applaud R&T for this.
#294 | |
Wouldn't "void" the warranty but could result in denial of coverage for any oil related issue. They just need to prove it contributed to the issue not directly caused it. As posted before the warranty language is clear that aftermarket or modded parts can result in denial of claim. You could of course argue it didn't but they just need to have one of their engineers state it COULD have contributed. They know the laws and trying to get around them with word play will not work. Doesn't matter what we, YouTubers, bloggers, random dudes in general think makes sense they simply have the resources to fight if they choose.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | JusTheG (08-02-2022), OkieSnuffBox (08-02-2022) |
| Tags |
| oh no not again |
| New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 02:15 AM |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 07:09 PM |
| Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 05:18 PM |
| Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 03:33 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 12:11 PM |
