Old 04-29-2020, 10:26 AM   #281
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by SuperTom View Post
Its only a 2x4 sheet thickness determines the price more. Too be honest I could have went thicker to make it more "structural".
https://dragonplate.com/solid-carbon...&sFilters=8!45
I went 3mm, should've went to 4mm to be stiffer. The Economy sheets are Matte/unfinished on the backside, finished on the front.
Thanks!
I would of expected 3mm would be pretty solid. Plus if you wanna go structural, recommend getting trunk braces. They’re more structurally effective
Old 04-29-2020, 10:49 AM   #282
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Thanks!
well wanted to get structural without adding weight of metal bars + covering the rear seat area. Don't need to get that structural I guess its plenty strong
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
ichitaka05 (04-29-2020)
Old 04-29-2020, 01:31 PM   #283
RayRay88
Drives: 2017 86 860 Special Edition
If you wanted strength you should have gotten something with a nomex/honeycomb core. Sandwich panels will give you way more strength than just another few layers of carbon. At some point with the strength/weight ratio, the sandwich panel will be lighter.
RayRay88 is offline   Reply With Quote
The Following User Says Thank You to RayRay88 For This Useful Post:
SuperTom (04-29-2020)
Old 05-03-2020, 01:45 PM   #284
SuperTom
SuperTom's Avatar
Made a huge sacrifice to the car gods with one of the big weight reduction mods the LIGHTWEIGHT FLYWHEEL!!
Went with this Ebay Special FX Flywheel for $140. https://www.ebay.com/itm/FX-RACING-C...72.m2749.l2649
It had good product reviews on Amazon so that was good enough for me.
I reused the stock clutch/pressure plate.
I also put in the Upgraded TOB, Velox clutch fork, Velox Pivot, new Fork clips
Not going to post a install instructions as plenty of those are out there. My only advice is taking the time to remove the shifter completely instead of the unclipping from underneath shortcut. Taking the shortcut made it a pain to remove and install the tranny if your doing this in your driveway on jackstands. And jacking the front of the motor makes it easier to line up and slide in
So now onto the weights
Stock Flywheel 19.75lbs
FX flywheel 11.75 for a MASSIVE 8lb LOSS!
Stock Pivot arm .75lbs
Velox heavy duty arm 1lb 6oz, for a 10oz gain
Also added Torque Solution transmission mount + Aliexpress Shifter base bushing
I haven't pushed it yet as I want to honor the breakin period but everything seems smooth. And to be honest don't notice any driveability issues. I did have to adjust the clutch engagement for the pedal. Overrall a nice chunk of weight off the front of the car again!
The Following 3 Users Say Thank You to SuperTom For This Useful Post:
Berserker (05-31-2021), jflogerzi (04-16-2022), q335r49 (05-15-2020)
Old 05-13-2020, 04:34 PM   #285
SuperTom
SuperTom's Avatar
Just Finished my rear seat flat plate. Also used it to remount the battery here instead of the the trunk.
First the weights out of the way
The CF plate 2.25lbs + the black carpet covers 1lb =3.25
-minus old carpeted rear seat delete + stock center carpet = 2.5lb
Ill add in .25lbs for bolts so total gain is 1lb
I could shorten the power cable a bit and lose some weight but I left it alone for now
CF Plate
Carpeted pieces - pet slept on adding hair weight haha
-old Carpet pieces + stock piece
NOW ONTO The PICS!
Carpeted piece. Used Rivnuts into the stock side armrests for mounting.
Seat installed
Used 2 small braces under the plate, plate is riveted to brace as you can see under battery
The Following 12 Users Say Thank You to SuperTom For This Useful Post:
Berserker (05-31-2021), Iceman (05-21-2020), in_sherman (05-23-2021), MCTeeJ (05-13-2020), ML (05-14-2020), new2subaru (05-16-2020), PulsarBeeerz (05-24-2020), q335r49 (05-15-2020), RToyo86 (12-14-2020), sato (06-06-2021), Stonehorsw (06-01-2021), Wally86 (03-30-2022)
Old 05-31-2021, 09:06 AM   #286
jay_reef15
The rear cover looks amazing
jay_reef15 is offline   Reply With Quote
The Following User Says Thank You to jay_reef15 For This Useful Post:
SuperTom (10-19-2021)
Old 03-29-2022, 06:57 PM   #287
SuperTom
SuperTom's Avatar
Aliexpress steering wheel mod $40
Whats up everyone been gone for about 2 years. Spent that time away from cars. Mainly focusing on Crypto mining rigs. But now im making a comeback!
My first mod back is Aliexpress steering wheel mod
I ordered these for about $40
https://www.aliexpress.com/item/1005003611999757.html
https://www.aliexpress.com/item/1005002073638401.html
Used this guys video on how to do it.
I removed the horn/airbag and the steering wheel buttons. At the end used 3m double sided tape in the area near the steering wheel controls to pull, then tuck underneath
Before
During
After!
Old 04-02-2022, 04:04 PM   #288
AgentBlue243
Drives: 2022 WRB BRZ limited
It’s good to have you back! What are your plans to further lower the weight? You’ve done a lot already… maybe something radical like a K-swap?
AgentBlue243 is offline   Reply With Quote
The Following User Says Thank You to AgentBlue243 For This Useful Post:
Jdmjunkie (04-02-2022)
Old 04-06-2022, 07:35 PM   #289
SuperTom
SuperTom's Avatar
Well next round of mods will be adding in some weight for functionality. As far as swaps ill wait till the Gen 2 motor swaps become easy and available
Just added in the JDL catted/Resonated Front Pipe! This is about 5lbs heavier than my straight FP, but 2.5lbs lighter than stock. As a daily driver I could no longer bear the smell of being completely catless
Current weight 2349.5 lbs. As long as I stay under 2370 which would be 400lbs less than stock ill be good.
Wally86 (04-07-2022)
Old 04-07-2022, 07:11 PM   #290
SuperTom
SuperTom's Avatar
Aliexpress Day!
Added more weight (+3.5lbs)with this CF weave center console added today from ALiexpress. It slides right in and out (so I can remove it), also has this nice usb connectors.
Also added all these CF pieces from Aliexpress
Speedometer, Vents, Door pieces, HVAC area, Roof
Old 04-11-2022, 10:16 PM   #291
SuperTom
SuperTom's Avatar
Major Changes
So the past few weeks Ive been working on repainting my car. Literally used $5 a can Rustoleum Flat White. I neglected my car for 2 years so some of the dry carbon on the fenders ect had cracked other various cosmetic issues that would be costly to have entire car painted elsewhere. Im very happy with my rattle can results
Also added splitters, side skirts, spats. Painted anything matte black to a Gloss Black and 2k Clear and also added red pinstripe.
And got some New Konig Hypergrams in Carbon w/lip 17x9
Last good old pic from 2 years ago
NEW!
The Following 6 Users Say Thank You to SuperTom For This Useful Post:
Espi (04-12-2022), Jdmjunkie (04-11-2022), ML (04-12-2022), new2subaru (08-28-2022), villainous_frx (04-12-2022), Wally86 (04-12-2022)
Old 04-12-2022, 10:30 PM   #292
SuperTom
SuperTom's Avatar
Forgot to add my weight increases with the mods
Konig Hypergrams 17x9, nexen Nfura 245/40/17 = 38.5lbs
2lbs heavier than my 17x8 setup but much more grip and still lighter than stock
front lips 1.4lbs
SIde skirts 2.7lbs
rear spats 1.1lbs
Old 04-20-2022, 10:52 PM   #293
GabeoHuncho
Drives: 2013 FR-S Vortech V3
Car looks awesome, good work on the paint
GabeoHuncho is offline   Reply With Quote
The Following User Says Thank You to GabeoHuncho For This Useful Post:
SuperTom (04-22-2022)
Old 04-14-2025, 09:34 PM   #294
SuperTom
SuperTom's Avatar
Back again after a 3 year hiatus!
Well the flat paint experiment didnt last long without a matte clearcoat. In the process of painting again a color called Blazing Bonfire.
In the process of taking all the panels off I will be redoing a few areas of the car to strengthen chassis a bit to eliminate small rattles and some areas more OEM quality. Mostly from the Perrin Mounts. Weight will be added in a bit my goal is to stay under 2400lbs still!
My First mod back is Injen Evolution Intake something I wanted to do 5 years ago. Always liked the straight shot into the throttle body. This added 3.25lbs over my stock/Perrin tube setup.
Since I dont have a Front Crash Beam had to improvise the Ram air mounting using some leftover Alumunium and Rivnuts into the bumper base plate and side headlight mount
All done! Engine bay will be getting recolored to match new color scheme. The strut bars are a hint of the new color
KMA KiCKz (04-15-2025), StraightOuttaCanadaEh (04-15-2025), villainous_frx (04-18-2025)
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 06:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 03:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 02:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 08:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-02-2013 12:45 AM
