, dpfarr
Old 12-10-2018, 10:57 AM   #2913
gtengr
Drives: 2017 BRZ
Originally Posted by BirdTRD View Post
Interesting. I don't see anything in the Edelbrock installation that specifies belt life or replacement interval.
In the Cosworth thread it was mentioned that during R&D the belt wanted to jump off the pulleys in some circumstances, so they made a flanged idler pulley to help keep it aligned. Based on how your belt failed (edge of belt facing what would be the tall-flanged side of the Cosworth idler), it seems to me that it could have been experiencing intermittent stress in that regard and it shortened the life.
gtengr is offline   Reply With Quote
Old 12-10-2018, 12:23 PM   #2914
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
I've also been noticing these "lines" on the hood for a while, cleaned it off once or twice but this is the worst it's been. I assumed it was dirt or something being slung by the belt, not sure if anyone else sees the same thing without belt issues? Normal? Maybe it's an early indication that the belt is beginning to fail and come apart?
BirdTRD is offline   Reply With Quote
Old 12-10-2018, 03:59 PM   #2915
B T
I never had those lines until after installing hood vents. Do you still have the front under tray on the car? Looks like road debris getting slung up by the belt.
B T is offline   Reply With Quote
Old 12-10-2018, 04:17 PM   #2916
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Yep, still have everything intact underneath. The only thing different is the mustache removal/mesh grill mod I did this summer.
Old 12-10-2018, 06:38 PM   #2917
BertoFT
Drives: 13 FRS Firestorm
My car has stock hood and body panels. Those lines don't appear on my hood like what you are seeing. Almost 5k miles on my kit.
Sent from my SM-G9600 using Tapatalk
BertoFT is offline   Reply With Quote
Old 12-11-2018, 12:43 PM   #2918
B T
Maybe your belt is starting to wear out after all, I don't have all those other sling marks under my hood.
Old 12-11-2018, 06:01 PM   #2919
BirdTRD
Simply Forgotus
BirdTRD's Avatar
I suppose so.
Anyone else with over 20K on their belt seeing anything like this?
Old 12-11-2018, 07:39 PM   #2920
BertoFT
I suppose so.
Have you looked at the belt? Checked for irregularities with the width through its the length? Is there similar residue/debris anywhere else? I imagine a belt that's deteriorating will show physical signs of wear.
I planned on replacing my belt every year, since I do about 30k miles a year (a lot of highway pulls).
Old 12-12-2018, 04:36 AM   #2921
godzuki
godzuki's Avatar
Drives: frs
Seem to recall abbate recommending replacing the stock belt in one of her vids.
godzuki is offline   Reply With Quote
Old 12-12-2018, 10:53 AM   #2922
subielife
Subaru Ambassador
subielife's Avatar
Drives: 13 BRZ 18 Silverado
replace it with a Gates: P/N K060990rpm
subielife is offline   Reply With Quote
Old 12-12-2018, 11:35 AM   #2923
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Thanks but I already replaced it with Continental Elite 4060995 Poly-V/Serpentine Belt. Is one belt really better than the other or is it just brand/personal preference?
Old 12-14-2018, 04:18 PM   #2924
toast
Drives: 14 BSP Edelbrock BRZ
Got my kit yesterday. I never do the kind of things you're supposed to do, like check kit contents. On this I actually did and found that Edelbrock didn't give me the reducer for the MAF to throttlebody connection. Edelbrock's tech number said call back Monday. CSG is working on it for me.
As a note for anyone that orders the kit, there are several small metal brackets that are painted. Poorly. Many edges on mine already had some rust on them. Having nothing to do since I couldn't install my kit I blasted them and powdercoated them.
toast is offline   Reply With Quote
Old 12-14-2018, 05:53 PM   #2925
jflogerzi
jflogerzi's Avatar
Anyone in the socal area willing to meet up this weekend to give a potential buyer a ride in the SC car. Based on my reading I really like this kit. Couple used ones on the forums and if I like what I feel then I might just pull the trigger on one if I can get it for the right price.
2013 Series 10 FRS #553
Old 12-15-2018, 01:27 AM   #2926
jflogerzi
jflogerzi's Avatar
Also on a another question.. what are the different pulleys and there psi? Is it 8,15, and 20 psi or is there also a 12?..
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
