Old 09-10-2017, 03:41 PM   #2885
strat61caster
strat61caster's Avatar
Originally Posted by DeshuL View Post
Yes typo on the front toe, it's 1/10th toe out.
I'm going to try doing 8k springs in the rear also, and get the car realigned and corner balanced as well. I have another event in two weeks so I'll see how that improves.
Thank you all for the input.
Thinking back on the 19mm bar idea, if you don't have one already that you'd be putting on you could always go back to stock and if it feels too soft you know that a ~19-ish bar is closer to what you want. It would suck to spend ~$200 on a 19mm bar and you realize it's still too stiff for what you want, it'd be hard to test 'is it stiff enough' but at least you have one end of the spectrum tested for minimal investment.
Don't do too many changes at once, springs and alignment might be too many if you plan on changing alignment from what you had before.
Originally Posted by Silver Ignition View Post
Anyone know the legality of a front strut lift spacer for STX?
Looking at 14.5.B it seems like it may fall under "changes in suspension geometry" although that may pertain just to ball joint mounting points. Right after that it says it allows strut length changes to accommodate ride height and suspension travel (which is what I'm trying to achieve)
I'd say so, 14.8.A allows for adding spacers to modify ride height which is pretty much what you'd be doing by adding a spacer between camber plate and chassis.
What they don't want you doing is adding a spacer that creates an offset, for instance one that adds caster by having the damper mount further 'back' on the chassis. There's also allowances in 14.8.C acknowledging that camber plates will have different heights, it's inevitable without some annoying way to police damper mounting position for each and every chassis.
ineedyourdiddly
Old 09-12-2017, 02:53 PM   #2886
strat61caster
Putting this where it belongs;
Originally Posted by M0nk3y View Post
370 STU!
STX is rough, you need to be on your game or be prepared to drop several places. I blew the braking zone into the showcase and lost a considerable amount of time as well
Heh I've seen Mack and Justin mention it but y'all must be crazy thinking STU is going to be any 'easier' if Heitkotter is still going to be running it next year, even if he sticks with the 350 or they try building the E46. But I'm totally out of the loop so there's probably something I don't know.
But with the Wong's listing their car for sale and Tsang's maybe out of the picture that's -4 top runners from STX if all you care about is the finish placement. Wilcox has a FoRS he might go play with and Lugod is a codriver and with the new SSC, STX could be mighty thin next year. I hope it isn't though, I'd rather lose by an inch to someone who's top of their game than win by a mile, I'm psychotic that way. At least I'll still have PAX to measure against locally next year if a bunch of top guys migrate.
ineedyourdiddly
Old 09-12-2017, 07:24 PM   #2887
justinco
justinco's Avatar
Drives: 2022 GR86
I am not going anywhere...the competition will still be some of the best/toughest in STX next year (which I like). Plus I just love the BRZ and the ST rules. I drive what I like, not where I think it might be easier to win (I don't remember ever saying anything about STU).
justinco is offline   Reply With Quote
Old 09-12-2017, 07:49 PM   #2888
strat61caster
Others have, don't know why you thought I was implying as such, see you next year!
ineedyourdiddly
Old 09-12-2017, 09:18 PM   #2889
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
I love the competition, I am lucky to have BH in my region where I can see where I am if I do compete against him. And he'd definitely help out on setup like he had before when I had my STX e36. lol
[ame="https://www.youtube.com/watch?v=V7EGaeX9m-g"]Bryan Mike Justin Mack - YouTube[/ame]
tigermack is offline   Reply With Quote
Old 09-12-2017, 10:25 PM   #2890
justinco
justinco's Avatar
Drives: 2022 GR86
You said Justin and STU...I just realized you were probably talking about the other Justin
Old 09-12-2017, 10:52 PM   #2891
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
The faster Justin.
Old 09-12-2017, 10:53 PM   #2892
strat61caster
That's brilliant, I gotta get braver about asking for help.
I realize the confusion now
ineedyourdiddly
Old 09-12-2017, 11:32 PM   #2893
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
I am building my FRS for STX.
I built my 13 BRZ back in 2012 for STX,....should be fun to start over again.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 09-12-2017, 11:40 PM   #2894
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Simmons
Why not try SSC (Spec 86)?
14stu is offline   Reply With Quote
Old 09-12-2017, 11:53 PM   #2895
Simmons
Simmons's Avatar
TQ dip,....
Old 09-13-2017, 12:09 AM   #2896
M0nk3y
Simmons
Yes Simmons contingency without Pax!
Can't wait to make lots of money
Kyle H. - #89 STX
Old 09-13-2017, 05:24 PM   #2897
Simmons
Simmons's Avatar
That would require you to be faster then me
Simmons
Old 09-14-2017, 10:26 AM   #2898
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I'm probably doing a very light schedule next year... mostly locals, going to try my best though to make it to Nats in '18, but we'll see.
Also just wrote a letter to the SEB/SPAC... considering some different plans for 2019 and beyond... especially if STX participation starts to diminish.
This year was a blast. Even though midwest/east coast participation is much lower than west coast, it was always a fun battle. on a great season.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
