View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 09-30-2013, 07:16 PM   #2871
JCasteli
Drives: Black FR-S
I purchased my Scion at Holman in Mt. Laurel, NJ. I have gone through 3 pumps. As mentioned in previous posts, they referred me to the National Center for Dispute Settlement. Holman didn't even have me speak to the Service Manager, they just immediately referred me to the dispute center explaining that Toyota won't replace them anymore. Now, they call it, "normal.
My arbitration hearing is scheduled for October 8. I have since moved to Kansas, so it will be at a random Toyota dealership. My argument is that how can they conveniently consider it normal after they replaced thousands of these on vehicles and even issued a TSB? Also, it wasn't sold making this sound. No one would be able to sell a new sports car that has a high pitched engine chirp. It no longer performs as it did when purchased. Sound is a part of performance. Manufacturers invest millions in engine and exhaust sounds. Toyota went so far to pump sound into their cabin.
I was told 2 months ago that I could wait for the new part to come out. I had little trust in that actually happening and here we are 2 months later and there either is a new pump that has the same problem or there isn't a new pump at all.
I assume once we reach an agreement I won't be able to disclose the results, but do know it's a case that easily warrants a dispute settlement and Toyota recognizes this if you indeed pursue it.
JCasteli is offline   Reply With Quote
The Following 2 Users Say Thank You to JCasteli For This Useful Post:
ericmpena (10-01-2013), totally (10-06-2013)
Old 10-01-2013, 02:27 AM   #2872
Kefuddle
Drives: Blue manual Toyota GT86
Hi Hunter (et al),
Originally Posted by HunterGreene View Post
But, if you are running E0, and you are still getting the chirps--makes me think operating temperature may be a bigger factor than people think.
I just wanted to revisit this. As I filled up with 95 again and the crickets have yet again disappeared. Not only that, but also I noticed that low RPM chattering that I think comes from the direct injection unit (could be wrong) is much much more subdued and the car just subjectively seems to be running smoother (which I perceived also last time I filled up with 95). Neither do I detect any lack of performance.
On the subject of Ethanol content in the fuel here in Dubai, I can't find any evidence of that.
But right now, it seems to me that either the quality of 98 fuel here is very low, there is Ethanol in the fuel, Toyota are wrong on the fuel recommendations or the car is just meant to sound like an old Cortina with a slipping fan belt!
Kefuddle is offline   Reply With Quote
Old 10-02-2013, 02:33 AM   #2873
ZZT86
ZZT86's Avatar
Drives: BR86
Originally Posted by DylanFRS View Post
I think he means that with a larger displacement engine they could get the same power output without the complex DI system.
Toyotas D4S system is meant to make the engine more efficient & thus its implementation on their cars & D4D in trucks. I'm all for more power & efficiency n all but to suggest a noisy & really annoying racket clearly coming from the HPFP is normal is not good enough & a possible deterrent to future sales.
Toyota are usually very good with these sort of problems & issues, imo it's only a matter of time before Toyota have a solution for it - I hope :/
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
Marrk (10-02-2013)
Old 10-02-2013, 04:41 AM   #2874
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
2k miles later after the 93 w/ethanol fuel I filled up with in Iowa causing crickets, crickets stopped after the next tank of gas (91 w/o ethanol). Win
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
Old 10-02-2013, 07:59 AM   #2875
ZZT86
ZZT86's Avatar
Drives: BR86
Originally Posted by Kefuddle View Post
Hi Hunter (et al),
Our RON98 fuel in Oz is quite strong, Shell VPower for example has been tested to be a minimum of 98, has NO ethanol and still I have the crickets at normal temps & at idle. Have tried other brands of fuel and same result, although I have never tried RON95 & it's a lot cheaper ! I will give the stuff a try & see what comes of it, the car has knock sensors, it should work just fine.
Old 10-02-2013, 08:15 AM   #2876
sierra
Drives: Skoda Yeti DSG diesel 4x4
You are the first to get the crickets in Oz that I have seen.
Are you absolutely sure it contains no ethanol?
sierra is offline   Reply With Quote
Old 10-02-2013, 08:28 AM   #2877
ZZT86
ZZT86's Avatar
Drives: BR86
VPower has no ethanol, it's the only fuel that I use & have used since Optimax was released all those years ago. My neighbour has just got himself an 86 GTS mt, I will consult him to see what he thinks of his but I'm fairly certain it's widespread - my technical advisor @ Toyota is aware of the problem & believes it's common by design default :/
Old 10-02-2013, 09:22 AM   #2878
sierra
It might be widespread in the US but I have never heard anyone even mention it here before.
I just did a search on our GT86 forum and found nothing.
Old 10-02-2013, 10:33 PM   #2879
Team_Kengai
Team_Kengai's Avatar
Drives: Firestorm Fr-S Build date(AUG 2013)
is it possible to put sound deadening materiel around the area or part to make the noise at least more tolerable ??? just a thought ..
Team_Kengai is offline   Reply With Quote
Old 10-03-2013, 08:27 AM   #2880
sierra
Just add a little 2T as has been posted many times.
It should be gone instantly.
Old 10-03-2013, 08:33 AM   #2881
ZZT86
ZZT86's Avatar
Drives: BR86
Im fairly certain I've read ppl in oz complaining about it, I'm also 100% certain that the racket from under the bonnet which comes on after only a few minutes of idling IS this problem of the HPFP as it's coming from the vicinity of the pump (so the engine fires & runs quietly at first then the clatter), what's more my tech advisor at the dealer (who I have known for almost 20yrs) is also aware of it !
Ethanol specifically is not the cause of this issue, it's something else, most likely pump design. Essentially it sounds like a diesel truck - I hate that, it's not acceptable. It's a good thing that I have the Perrin un-resonated exhaust otherwise I'd really be pissed ! As it is, I can live with it, the car certainly runs well, like the clappers even
Old 10-03-2013, 08:38 AM   #2882
sierra
If you listen to the many video clips of the crickets you will realise it's not the clatter that comes from the HPFP which they all have.
The clatter is normal for direct injection, the crickets are not.
No ethanol, no crickets. You don't have crickets.
Old 10-03-2013, 08:44 AM   #2883
ZZT86
ZZT86's Avatar
Drives: BR86
So what you are saying is that it's normal for the DI to suddenly become real noisy & at normal operating temp ? When I stop the car for 10-15 & then re-start the racket isn't there, then after a few minutes it's back. The HPFP is mechanically driven & is always running :/ I have followed & heard those clips, my car sounds the same !
Old 10-03-2013, 09:03 AM   #2884
Mikem53
Drives: FR-S 6MT
Yes.. That's normal.. The port injectors are used at idle first, then the DI kicks on and the noise/clatter starts.. That noise is normal and similar of all pumps producing 3000psi.
It's the high pitch chirping noise that the pump sometimes makes randomly and it's not the normal racket a HPFP normally makes.
Mikem53 is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
