Old 10-05-2014, 07:04 PM   #2857
RavnFRS
Drives: 2013 Scion Frs
Well fellas, i believe i have had the most significant issues out of anyone. Currently on 5TH ENGINE. ALL WARRANTY COVERED! First engine: 15,000 miles, threw a rod complete catastrophic failure. A month and a half later, nearly whole engine rebuilt(only one head though) 300 miles later boom second engine bit the dust. Oil control valves malfunctioned starving my engine of oil. Another month later car back and 1,100 miles later boom. Both second and third engine had low idle problems/crickets. First engine had zero issues until the day it blew. Oil control valves seemed to be issue again and the head they didn't replace had major damage. Total rebuild for my 4th engine and car died first day i had it back. Lets just say i was fed up. Corporate was now all over my case. Every single piece of engine oil ever touched was replaced, subaru engine specialist tuned my current engine as perfectly as he could. Now running trd cold air(which i received for free) and corsa catback which I'm in love with. have had car for 2,000 miles and no issues. Car idles beautifully, runs perfect and has zero issues. But like others of you, had oil control valves replaced every time, control arms, DI injectors, the list goes on and on and on. Total cost incurred to dealership was $28,000 dollars lol. Toyota will be contacting me and thanking me for my patience and probably getting me trd body kit. Now have 18" enkeii raijins, blacked out tails and rocket bunny wing. Car is sexy and i missed having her all summer. Hope none of you have to go through what i went through. will have to picture all the paperwork sometime for fun.
RavnFRS is offline   Reply With Quote
Old 10-05-2014, 08:08 PM   #2858
civdaddy
Drives: Slow
U must plan on keeping that car forever considering how much shit Uve put up with lol
civdaddy is offline   Reply With Quote
Old 10-12-2014, 10:27 PM   #2859
spyingwind
Drives: White '17 86
Getting CEL error thrown when driving aggressively. My 2013 FRS is waiting on an ignition coil to be replaced. The part was on back order. :/ I have just over 32k miles on my car. I live in TX.
spyingwind is offline   Reply With Quote
Old 10-26-2014, 06:59 PM   #2860
m3bassman
trying to give a shit
m3bassman's Avatar
Drives: The Black Pearl
How prevalent is this issue on bone stock vehicles? Having read through several pages, but not all 130, many of those I've seen effected have performance mods of some sort on their cars.
m3bassman is offline   Reply With Quote
Old 10-26-2014, 08:18 PM   #2861
Marrk
Drives: Honda Fit
We're seeing this as an engine and/or edu design flaw. All cars affected, not just modded cars.
Marrk is offline   Reply With Quote
Old 10-26-2014, 09:57 PM   #2862
m3bassman
m3bassman's Avatar
As someone currently shopping for a 2013 CPO FRS, this is disheartening to hear.
The Following User Says Thank You to m3bassman For This Useful Post:
Marrk (10-26-2014)
Old 10-27-2014, 12:16 AM   #2863
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
For those that are new to this platform (FT86) there hasn't been any big advancements in the mechanical features of this car. I'm sure when the first big overhaul hits a lot of the seen engine, transmission, high pressure fuel pump, etc will be address, or at least we hope. I honestly believe (and this is my opinion) that Subaru tends to take car of their customers more than Toyota; this could be because most of the parts tend to be Subaru's.
Bottom line as of now (and what I would recommend) is those that buy the car should consider enjoying the full 3-year warranty before modifying the shit of out it hahaha. Otherwise this little beast can become a [fun, enjoyful yet stressful] money pit. Otherwise, keep all your stock parts so when you need to bring it back to the dealer to fix... (fill in the blank). I can pretty much say I've gutted and built this car twice lol.
Go forth and do go work!
shiro is offline   Reply With Quote
Old 10-27-2014, 01:14 AM   #2864
WazzuGrad
WazzuGrad's Avatar
Drives: 13 FRS (sold) 23 GR86
Just make sure you purchase the extended warranty if you are planning to keep it past 3/36.
I was exactly in your shoes, and worrying about all the issues. Having the warranty gives you that piece of mind.
WazzuGrad is offline   Reply With Quote
Old 10-27-2014, 03:21 AM   #2865
m3bassman
m3bassman's Avatar
I am pursuing a certified preowned 2013. That will give me the 7yr/100,000m which is a lot of peace of mind. Still, it is not fun to read through this mess. Thank you though.
Old 10-28-2014, 02:20 PM   #2866
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
we had the p0016 code popping up on my built fa20 engine usually after a warm restart, after clearing the code. car runs perfectly fine with the code cleared, then goes into limp mode when the code is present. so limp that it wont even build boost. we disabled the code in the tune and the car drives perfect and has zero issues for the last month.
it does sound like the ecu is trying to read the cam position on immediate startup, but when the oil is hot the vvti does not respond quick enough, which logs the fault.
just something to think about.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Marrk (10-28-2014)
Old 10-28-2014, 10:56 PM   #2867
WazzuGrad
WazzuGrad's Avatar
That's exactly what i bought too. Bought a '13 FRS with 8400 miles for 21k. Than extended the 7/100k to platinum coverage for $1200 bucks.
Peace of mind for the next 7 years...not to mention the coverage is prorated, in case the ownership ends sooner i can recoup some of the money. From what i'm reading, most of these issues will either surpass or come very close to $1,200.
If you want the dealerships number that sold me the coverage, PM me.
Old 10-29-2014, 04:32 AM   #2868
m3bassman
m3bassman's Avatar
Ill keep it in mind as i continue shopping. Many thanks. Go Vandals.
Old 10-29-2014, 05:23 AM   #2869
alan.chalkley
Drives: 4wd zooks
Mine was running fine until the local subaru dealer did the 18 month 30 000km free service . When i drove it home it kept stalling on idle.
I took it back and they reset the ecu back to learn mode.
Now i have to drive it hard for the next 100km to get the throttle response back.
I suspect this happens when they start the engine with something unplugged (maf sensor).
Or maybe used too much throttle body cleaner and fuel additive.
alan.chalkley is offline   Reply With Quote
Old 10-29-2014, 05:37 AM   #2870
steve99
The ECU is always in "learn mode" it constantly learns fuel trims and knock correction adjustments . Reseting it just sets it back to default and it will get back to same state with or without a reset. A reset will just clear stored CEL codes.
Driving it hard to make it learn also seems incorrect. The ECU learns fuel trims only in Closed loop fueling mode, when your driving sedately with slow or no throttle movements. during aggressive driving its in Open loop mode and does not learn fuel trim corrections, just applies what it learnet in Closed loop mode.
My guess if it was stalling at idle the dealer left something unplugged or dislodged something during service likely an intake tube/hose/sensor, and they made up the "learning" rubbish to cover their mistake.
alan.chalkley (10-29-2014)
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 07:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 11:42 AM
Idle issue scioneric CANADA 23 08-24-2012 02:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 11:00 AM
