Old 08-20-2015, 02:55 PM   #2787
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
I believe virtually everyone that runs E85 does it with a Flex Fuel kit, so that you can freely swap fuels or mix them, however and whenever you want.
If you're unsure, you can always start with pump gas, and add on the other components later. There's no "additional" work by doing it in two steps, as you don't need to disassemble ANY of the JRSC to get E85 working.
Awesome! Cant thank you enough Mike
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
The Following User Says Thank You to ck-GT86 For This Useful Post:
CSG Mike (08-20-2015)
Old 08-20-2015, 03:26 PM   #2788
Let us know when you're ready to order
Old 08-20-2015, 03:53 PM   #2789
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Originally Posted by dj2020 View Post
I believe I've found a solution for our inaccurate outside temp reading post JRSC install. Mine was reading easily 20+ degrees F after 10-15 minutes of driving when located behind the radiator, oil cooler and intercooler.
First, I ended up relocating my outside temp sensor to the passenger side vertical air guide that I had initially removed for the JRSC install. I simply dremeled the air guide to fit around the new intercooler piping and drilled two holes into the guide so that I could zip tie the temp sensor against the guide. The sensor now sits away from the radiator and oil cooler. When viewing from the front, it sits just below and slightly behind the intercooler exit piping. The temp wiring harness is just long enough to accommodate this. This setup gave me temp readings that were consistently 5 degrees (F) higher than the geolocated temp reading from my iPhone's weather app after 10 minutes of driving. Typically the outside temp reading stabilized after 10 minutes of driving: car was at normal operating temp and enough air had been blowing across the sensor.
Attachment 107435
Attachment 107436
Attachment 107437
The final step was using the Techstream Software and calibrating the ambient temp sensor to -3 degrees C (5.4 degrees F). This gave me outside temp readings that were within 1-3 degrees F of my weather app! Ambient temps in Las Vegas have been hovering between 45-85 degrees and the temp sensor has been pretty accurate within that range. The real test is when we start hitting triple digits in the summer months.
I realize this has no effect on the performance of this kit but just more of a fix if anyone was annoyed with the hugely inaccurate outside temp reading post install. YMMV. Hope this helps!
Attachment 114404Attachment 114405
Where can I find the Techstream Software for calibrating the ambient temp sensor? Is this something in EcuTeck?
Jmonty is offline   Reply With Quote
Old 08-20-2015, 04:00 PM   #2790
dj2020
This is were I found the techstream software. It also recommends which cable to get as well. I had to use a Windows XP laptop to do this. I could not get the software to work on Win7. The "outside temp" calibration is not via EcuTek.
http://www.ft86club.com/forums/showthread.php?t=35530
dj2020 is offline   Reply With Quote
The Following User Says Thank You to dj2020 For This Useful Post:
Jmonty (08-20-2015)
Old 08-20-2015, 04:18 PM   #2791
Jmonty
wonder where I can take it to get it reset?
Old 08-20-2015, 04:51 PM   #2792
dj2020
Maybe not understanding your question... I simply downloaded the software and bought the cable on eBay for the temp calibration. The followed the thread above exactly.
Jmonty (08-21-2015)
Old 08-20-2015, 05:14 PM   #2793
ck-GT86
ck-GT86's Avatar
Hey Mike, should I get the TIY kit if I likely will have intention on going to E85 later down the line?
.ck
|| My Build Thread ||
Old 08-20-2015, 05:23 PM   #2794
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
.ck
I would go with the Factory Tuned kit since you are in California. You get the CARB Legal Status, and so you don't have to pony up for a tune now, and one when you go E85. You spend about the same in the end.
JDMChris is offline   Reply With Quote
Old 08-20-2015, 05:27 PM   #2795
.ck
Unless you already own EcuTek, you should get the Factory Tuned kit; it'll let you run the kit out of the box with no additional work or tuning (with your stock header and front pipe), and also get you the CARB sticker.
Old 08-20-2015, 05:58 PM   #2796
ck-GT86
ck-GT86's Avatar
I have a Delicious ECUTEK tune for all of my bolt-on's. It's way too late for a stock header and front pipe, everything is pretty much changed sans supercharger.
.ck
|| My Build Thread ||
Old 08-20-2015, 06:11 PM   #2797
Xuningshen
Drives: Subaru BRZ
.ck
the carb tune wouldn't work for you, get the TIY kit and then get a flash and go tune from delicious along with their MAP sensor.
I've been loving the delicious flash n go tune v16.20.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
The Following User Says Thank You to Xuningshen For This Useful Post:
ck-GT86 (08-20-2015)
Old 08-20-2015, 06:19 PM   #2798
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
.ck
^This, unless you are planning on putting back your stock header and overpipe to be CARB legal, in which case, its easier to get the CARB kit to have the sticker ready when the time comes.
The Following User Says Thank You to BigFatFlip For This Useful Post:
Old 08-20-2015, 06:21 PM   #2799
ck-GT86
ck-GT86's Avatar
Thank you, thank you! I am sold!
|| My Build Thread ||
Old 08-20-2015, 06:26 PM   #2800
.ck
In that case, get the TIY kit. If you want a CARB sticker, you'd need to buy the CARB tune separately (we need your dongle/license ID). If the CARB sticker doesn't matter to you, then TIY + tune and you'll be good to go.
We can also supply you with the Delicious FNG tune + MAP sensor as well.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
