Old 02-01-2016, 10:17 PM   #267
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Originally Posted by Rafi@RR-racing View Post
I do inside first, then outside, but I also alternate a few times, and I tap the calipers with a plastic mallet to make sure all the bubbles rise to the top. You never bleed the lower bleed screws.
Rafi
Which fluid do you guys recommend? The Willwood fluid, or something mkre dependent on application/use?
Kostamojen is offline
Old 02-02-2016, 10:43 AM   #268
Rafi@RR-racing
Rafi@RR-racing's Avatar
Drives: Toyota GT86
Originally Posted by Carlos_M View Post
@Alan,
I'm also located in DE and wanting to jump up to the RR-Racing setup this year. Would be awesome to meet up with you and pick you brain on it!
-Carlos
PM, email, or call us and we'd be happy to help you out.
For street cars with occasional track use I like Wilwood 570 fluid, it is very good and not expensive. What most people dont realize is that many of the top end expensive race fluids actually pick up moisture more quickly that a high performance street/track fluid. So they may initially have a dry boiling point higher than something like a Wilwood 570, but the boiling temp will drop off much faster. Keep in mind, race cars get bled before every event.
Rafi
Rafi@RR-racing is offline
The Following User Says Thank You to Rafi@RR-racing For This Useful Post:
Carlos_M (02-02-2016)
Old 02-02-2016, 09:11 PM   #269
acro
Drives: GT-86
I use the project mu brake fluid. But plan to switch to the torque rt700 brake fluid.
See this thread here.
http://www.ft86club.com/forums/showthread.php?t=47686
acro is offline
Old 02-10-2016, 11:38 AM   #270
Traktor
Drives: Subaru BRZ Limited
I find the differences of opinion on Brake Bias quite interesting.
On the one hand you have one of the industry's most highly respected companies (Essex) deem the factory bias fine, to the point that they have elected to not pursue the development of a matching rear kit to their no-compromise front kits.
This is interesting as it is in their commercial interests to sell rear kits, regardless of the actual value to the consumer.
On the other hand RR Racing are adamant that the factory bias is too far forward even for cars not running downforce, and have specifically developed kits to change it.
I for one would love to see some back to back track data comparing the AP Sprint/OEM combo against the equivalent RR kit, though I am guessing that's asking a lot.
I was actually looking at matching an Essex Sprint kit with a rebuilt WRX 2 piston fixed caliper on the rear (same brake torque as single piston BRZ OEM) that I picked up cheap. But I do like the look of the RR front kits, and the fact that the smaller of the 6 piston setups will fit under OEM wheels. This would allow me to run a more aggressive tire on RPF1s for track days without having to fit spacers or extended wheel studs for OEM wheel fitment (my car is also a daily driver).
Traktor is offline
The Following User Says Thank You to Traktor For This Useful Post:
Pat (02-10-2016)
Old 02-10-2016, 01:32 PM   #271
DAEMANO
Time Traveller
I added extended studs front and rear and it really wasn't a very big deal to install (H&R 50mm front, ARP 60mm rear). Also, the aftermarket studs seem to be harder than the stock studs which people have reported tend to strip/cross thread on repeated use (don't know if this was simply user error though). Guess my point is that aftermarket studs might be a worthwhile swap anyhow.
DAEMANO is offline
Old 02-15-2016, 09:59 PM   #272
Kostamojen
If I order one of these in a custom color, how long is the wait for them to be shipped?
NVM I have a couple months, plenty of time :P
Order placed!
Old 02-22-2016, 04:24 PM   #273
stevo_12v
stevo_12v's Avatar
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Originally Posted by DarkSunrise View Post
@Rafi@RR-racing
This is a picture of the stage 2 front template and Wedssport TC105N 17x8 +42 wheels. There is about 6 mm clearance towards the bottom. Assuming there is some thermal expansion at track temps, how much space would you recommend at a minimum? Thanks!
Hullo
Just confirming fitment for some wheels, these will CLEAR.
Suprisingly(good), the Weds clear without the need for a spacer.
Weds TC105N 17x8, 42 offset
Volk TE37SL Black Edition 18x9.0, 45 offset
TWS T66-F 18x8.5, 42 offset
[CENTER]
Build thread
stevo_12v is offline
The Following 2 Users Say Thank You to stevo_12v For This Useful Post:
brandonblt2 (05-23-2016), DarkSunrise (02-22-2016)
Old 02-22-2016, 04:36 PM   #274
DarkSunrise
DarkSunrise's Avatar
Originally Posted by stevo_12v View Post
Hullo
Thanks very much! I figured it was enough space so I went ahead and bought them. They look awesome on your car btw.
2022 BRZ Build
2013 FR-S Build
DarkSunrise is offline
The Following User Says Thank You to DarkSunrise For This Useful Post:
stevo_12v (02-22-2016)
Old 02-22-2016, 04:52 PM   #275
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
For people concerned that they clear but are really close, the general rule of thumb I've seen in other threads is to give yourself at least 2mm clearance. I've even seen stock brake systems on other cars with only about 2mm clearance before.
Lynxis is offline
Old 02-22-2016, 05:05 PM   #276
2.superslownj
Drives: 2014 Raven FRS
Any forum discounts??
2.superslownj is offline
Old 02-22-2016, 08:31 PM   #277
Kostamojen
Are you kidding??? These brakes already ridiculously inexpensive!!!
The Following User Says Thank You to Kostamojen For This Useful Post:
DustinS (02-29-2016)
Old 02-29-2016, 01:10 PM   #278
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
So I've tried a few wheels on my stage 1 callipers and my friend's stage 2 callipers so that anyone interested in this kit can have an idea for what wheels have confirmed fitment!
Desmond Regamaster 17x8 +35 - Clear stage 1 with about 14mm clearance
SSR Type C 18x9 +40 - Clear Stage 1 by 15 mm
Volk GT-7 18x8 +43 - Clear Stage 1 and Stage 2
Enkei RPF1 18x8 +45 (bubble face) - clear stage 1 and 2
Wedsport TC105n 18x8.5 +42 - Clear stage 1 and 2
SSR type C 17x9 +45 - clear stage 1 and stage 2 with small 3mm spacer
720Form GTF1 17x9 +35 - clears stage 1 and stage 2
Enkei Kojin 18x8.5 +45 - clears stage 1 and stage 2
Canehda is offline
The Following 6 Users Say Thank You to Canehda For This Useful Post:
B T (05-06-2016), Carlos_M (02-29-2016), DAEMANO (03-08-2016), drewbot (04-25-2016), Lynxis (02-29-2016), MaximeT (02-29-2016)
Old 02-29-2016, 01:57 PM   #279
Carlos_M
Carlos_M's Avatar
Drives: 2014 BRZ Limited
So would it be reasonable to assume that the Stage II would fit behind an 18X8.5 with +35 offset?
-Carlos
Carlos_M is offline
Old 02-29-2016, 02:04 PM   #280
Canehda
Canehda's Avatar
-Carlos
it totally depends on the face design which makes it hard to give a yes or a no. For example the RPF1 18x8 +35 would not fit the stage 2 kit however the +45 model does which is totally counter intuitive but its just because the way the face of the wheel is designed
Canehda is offline
The Following 2 Users Say Thank You to Canehda For This Useful Post:
Carlos_M (02-29-2016), tato.valverde (03-01-2016)
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 08:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 06:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 05:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 12:31 PM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
